3rz TRD supercharger on 2trfe
Discussion in '4 Cylinder' started by TireFire, Oct 30, 2017.
  1. Apr 9, 2018 at 12:09 PM
    #81
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    It utilizes the 2TR port shape entirely
  2. Apr 9, 2018 at 12:10 PM
    #82
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Cool, so does the gasket and 3RZ port of the SC just kinda sit on the edge or is there an extra lip for it.
  3. Apr 9, 2018 at 12:15 PM
    #83
    05Taco4x4
    2TR-FE Enthusiast
  4. Apr 9, 2018 at 12:18 PM
    #84
    Speedytech7
    I just wondered how mmuch overlap there is since the 2TR port is larger than the 3RZ port. I know what the SC flange looks like, since you said you're using the 2TR port all the way through I figured that would leave less mating surface on the 3RZ side for the gasket and SC manifold to sit on...
    GDT likes this.
  5. Apr 9, 2018 at 12:27 PM
    #85
    05Taco4x4
    2TR-FE Enthusiast
    Looks the opposite of that to me. Also, looks like the gasket sits nicely on the 2TR surface.
    Speedytech7[QUOTED] likes this.
  6. Apr 9, 2018 at 12:29 PM
    #86
    Speedytech7
    Ahh, okay then. I would have never thought the 2TR would have smaller ports. Cool, that'll make it real easy. Only other thing that looks like it might throw a small wrench in is the belts on the 2TR look like they have an extra rib or two and are farther out. So cool to see this materializing.
    bijick likes this.
  7. Apr 9, 2018 at 12:34 PM
    #87
    05Taco4x4
    2TR-FE Enthusiast
    Yeah, so the 2TR uses a 7-rib- I assumed @Silver_Back already figured out a pulley swap
  8. Apr 9, 2018 at 12:35 PM
    #88
    Speedytech7
    Hopefully one of the URD ones can be made to work. 7 rib has much less chance of belt slip which would be a major plus.
    05Taco4x4[QUOTED] likes this.
  9. Apr 9, 2018 at 12:43 PM
    #89
    05Taco4x4
    2TR-FE Enthusiast
  10. Apr 9, 2018 at 12:45 PM
    #90
    Speedytech7
    Up until I found a 3RZ TRD charger for a decent price I had been as well for the 3RZ. I was going to adapt a Previa supercharger to it. They're 1.45L per rotation, way more than the little M62. But I had to get the 3RZ charger when I saw the price.
  11. Apr 9, 2018 at 3:37 PM
    #91
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Since the holes for the 3rz flange don't go all the way through, I'm assuming they're threaded for studs?
  12. Apr 9, 2018 at 4:09 PM
    #92
    05Taco4x4
    2TR-FE Enthusiast
    Yes, M8x1.25 20mm deep
  13. Apr 9, 2018 at 4:37 PM
    #93
    bijick
    bijick such mods much want
    E
    Stl
    2013 MGM Singular Cabular Selectable
    OME 884’s ,Dakar hd’s, Jba uca, lce header, 4.88’s, Arb locker , j shift tcase-T4R, arb bumper, leer topper, 3500w inverter, mad wife, scratched paint, skid plates, snorkelerer, led flush mount reverse lights, etc..
    I was going to buy an intake spacer but I’m definitely buying one of these adapters once the fitment is hashed out, you guys are the shit and I salute you.
  14. Apr 9, 2018 at 5:44 PM
    #94
    Silver_Back
    Silver_Back Well-Known Member
    Nate
    Washougal, WA
    2006 Tacoma Pre-Runner
    Rancho 3" suspension lift Eaton Truetrac Torsen Locker URD short shifter Dual Optima Yellow Top Battery Setup with Separate Electrical Systems Spyder Industries Front Bumper Fabfour Rear Bumper Onboard Air Compressor System 1800 Watt Power Inverter Smittybilt Competition 10k LBS Winch Bushwhacker Pop It Fender Flares Striker 10-Band Radio Homelink Mirror Viper Alarm Frame Mounted LED Bars EBay Headlights & Taillights Better Built Truck Box Fire Stone Ride Rite Air Bags Eaton elocker in front Dual case tacobox Etc...
    There are multiple solutions to the pulley swap but the best course of action is to first mount the SC and then measure the variance with respect to the belt alignment.
    Let's not get to far ahead of ourselves. The adapter comes first. Then corrections to the prototype and finally addressing the pulley and support of the SC concerns.
  15. Apr 9, 2018 at 5:51 PM
    #95
    Silver_Back
    Nate
    Washougal, WA
    05Taco4x4,
    Did you find time to get a quote from the machine shop for the first prototype?
  16. Apr 9, 2018 at 5:59 PM
    #96
    Speedytech7
    I'm eager to see how it works out. Super easy to support it by the way, it just uses a single stud that you should be able to brace to your engine mount. I think I remember seeing your truck around Spokompton. I just moved away from Eastern WA a couple months ago.
  17. Apr 9, 2018 at 6:52 PM
    #97
    05Taco4x4
    2TR-FE Enthusiast
    Awaiting reply, will be later in the day (HI time)
  18. Apr 9, 2018 at 6:56 PM
    #98
    Silver_Back
    Nate
    Washougal, WA
    Great. Let me know what the bill is.
    bijick likes this.
  19. Apr 9, 2018 at 8:48 PM
    #99
    05Taco4x4
    2TR-FE Enthusiast
    PM inbound
  20. Apr 10, 2018 at 6:33 PM
    #100
    Silver_Back
    Nate
    Washougal, WA
    Tacoma community,
    05Taco4x4 and I have good news. The first prototype has been sent to the machine shop for fabrication. The lead time is approximately 2-3 weeks. Once complete, we will test fit with the templates and finally on the vehicle. There will be delay between the two test as 05Taco4x4 and I are in two different locations. He is utilizing his local resources for production and offered to test fit with the templates. If it passes his quality control then he'll ship it to me for test fitting on the truck.
