3Rz Turbo
Discussion in 'Performance and Tuning' started by Sir Badwrench, Apr 6, 2011.
  1. Apr 6, 2011 at 8:43 AM
    Sir Badwrench
    Sir Badwrench [OP] Member
    Aaron
    Fallbrook, CA
    06 Access Cab 2wd
    K&N intake tube and heat sheild w/ HKS super mega flow, 2.75" exhaust, 1.25" front spindle drop, 2" rear block drop, silver grille, silver rear bumper, all badges removed, 18 rays wheels.
    Going to be building a race motor for a 1450 truck and am new to these motors. Currently truck has a 22R w/ a billet precision turbo, but the motor is near the end of its service life, so we are going to switch to a 3RZ. Already purchased a motor, but am trying to figure out the best (most reliable) setup that will put down a consistent 500hp.
    My main questions are:
    1) Which head to use - 4 port or 8 port (currently have an 8 port). The head we have already has some mild porting, but we are weary of the way the injectors fire into a flat portion between the 2 ports. We will be using 1100cc custom intectors as we are running on E85. Considering closing up the factory injector location and running 8 - 750s?
    2) Good setup for the manifold to maintain a forward throttle body. I realize that the 3RZ is backwards from the 22r, but as long as the TB faces forward, intercooler piping is not an issue.
    Any info is greatly appreciated as is recommendations to reliable parts suppliers and builders.
    Here is a link to our website so that you can see what we are working with:
    http://wopracing.com
  2. Apr 6, 2011 at 10:39 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
  3. Apr 6, 2011 at 4:03 PM
    Sir Badwrench
    Aaron
    Fallbrook, CA
    06 Access Cab 2wd
    What do your manifolds run? Also, already have the 3RZ so gonna stick with that. Does anyone make rods for it?
    What failed on your motor? The block we picked up already has the arp head studs and has Arias 8.5:1 pistons. Motor is already stripped so that we can inspect all the parts (gonna take the pistons to Arias this week for checks). Also removing the balance shafts.
