3rz valve adjustment/idiotic Toyota dealer
Discussion in '1st Gen. Tacomas (1995-2004)' started by 96_taco, Jan 16, 2016.
  1. Jan 16, 2016 at 2:58 PM
    96_taco
    96_taco [OP] Well-Known Member
    Clayton sandgren
    Northern va
    1996 Tacoma 2.7 4x4 extended cab
    33" bfg mud terrains, cold air intake, flowmaster with side exhaust, manual swapped, manual hub swapped, lifted on bilsteins
    So went to miller Toyota in manassas va today to get some valve shims as I needed to adjust exhaust valves. Pretty simple right? Nope. The parts guy told me he didn't know what I was talking about so I went to service and asked for help. That guy talked on his phone with someone and I asked for the manager, he said he'd go get him but he never came back. I went into their service lane and found a tech, and asked if they kept a set of shims in the shop and he said they don't do valve adjustments... What?! So I asked him what they do if a client comes in and needs a valve adjustment on a 1st gen and he said they just REPLACE THE ENGINE. Said in the "12 years he's been a tech" he's never done an adjustment. Wtf so I went back to the parts counter, took control of the guys computer and pulled up a diagram of the head and clicked on the shim, pointed at the sizes I needed and said order these. Payed and left, last time I'll ever get anything at that Toyota, bunch of arrogant pricks.
  2. Jan 16, 2016 at 7:06 PM
    RustyVT
    RustyVT Well-Known Member
    Vermont
    98 4Runner limited, 12 S60 T6
    OME overload springs, airlift bags, Hayden 679, 33x12.5 X-ATs
    Same deal with my dealer. It's a joke getting shims, I talked to 3 people on the phone and not one knew what they were. Never ended up buying any, still need to do that job to this day lol.
  3. Jan 16, 2016 at 7:41 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    theres a reason for this. rarely does the valve clearance ever really need to be adjusted. honestly, unless the pressure is so high that it crushes the metal caps, or squishes the metal valve stems, or bends the metal cam lobes, there really is never a reason to swap out the shims. there's just not much that can go wrong with this design.
    however, the reason i was mentioning earlier. when you rebuild a head and do a valve job. you're literally cutting the seat for the valve and the valve to the point where it sits higher inside the chamber.
    this is really the only reason one would need to change the shims. because the top of the valve stem is now sitting a fraction of a millimeter higher than it was before.
    also, next time, you'd be better off calling some machine shops and seeing if they have any they can give or sell you. I know my machine shop has like 3 trays full of shims just sitting around collecting dust.
  4. Jan 16, 2016 at 8:17 PM
    96_taco
    Clayton sandgren
    Northern va
    Well I'm coming from a working on motocross bikes and mine and my buddies bikes, either the valves stretch or the valve seat sinks into the head which is why I wanted to check mine. 225k miles and 3 of my exhaust valves are tight which I'm assuming is from worn valve seats cause I never really hear of steel valves stretching like the titaniums do. But to say they don't do valve adjustments when I know of other dealerships that keep shims on hand cause they do them is appalling
  5. Jan 17, 2016 at 6:36 AM
    98tacoma3rz
    98tacoma3rz Well-Known Member
    lancaster, pa
    2002 Double Cab Trd
    Could you hear your valves or did you just check the clearances for preventative maintenance? I should probably check mine :/
  6. Jan 17, 2016 at 8:24 AM
    96_taco
    Clayton sandgren
    Northern va
    Just checked them when I was doing a valve cover gasket, I know when we do valve adjustments on Hondas they come in rumbling and leave purring lol
  7. Jan 17, 2016 at 10:08 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    No shock there, from an old Centreville man.
    The 4 cyl's needing a little help on the exhaust valves between 100K-200K is very common. Equally common is the folks that let it go until they burn valves and/or crack the head/seat.
    The V6 is much easier on valves, the 03-04 even more so. They still should not be forgotten.
    That being said I am doing an adjustment on a 6 right now and just got 2 shims in for the job. Only 2 exh valves were just under spec. Anyhow the shims seem to be different than the last one I did 4 or 5 years ago. They have a light coating, looks like a very light "parkerized" type finish and they measure exactly the stated size where in the past they were just pretty close.
  8. Jan 17, 2016 at 10:14 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    I went to Toyota of Somerset in Somerset Kentucky a while back to find out about buying the metal adjustable bed cargo divider shown in the accessories catalog. The parts guy said he couldn't find it on his computer, it didn't show up on the search, and he wasn't sure it was made to fit an 06. I didn't even argue with him, just called and had Toyota Knoxville where I bought the truck order one for me, and told him I would pick it up in a week or so when I went down for my regular maintenance.
    Some dealers are good, some are not. :annoyed:
  9. Jan 18, 2016 at 5:45 PM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Years ago I took my 1987 2.7l Toyota to the dealer for a valve adjustment. When I got the truck back the valves were still noisy. I asked the service manager if they adjusted the valves when they are hot or cold, and he told me they adjust them when they are hot. The service manual says to adjust them when they are cold.
    Then I called my old Toyota repair shop (Enterprise Toyota Repair in Canoga Park, CA, an EXCELLENT and honest mechanic), told him the problem, and he said that the valve cover was probably too tight and that I should loosen the nuts a bit and see of the problem went away. I did, and the noise went away.
    The cover nuts screw onto stems that screw into the cam supports. So if you put the nuts on the cover and tighten them to much they will pull the cam ever so slightly away from the valve stems and cause them to clatter. So only tighten them up to their torque specification.
  10. Jan 18, 2016 at 10:19 PM
    96_taco
    Clayton sandgren
    Northern va
    I thought the first 2.7 was 95.5? Anyways yeah my valve cover only screws into the head
