3RZ windshield fluid reservoir
Discussion in '1st Gen. Tacomas (1995-2004)' started by lineman4tacos, Feb 26, 2025.
  1. Feb 26, 2025 at 4:15 PM
    lineman4tacos
    lineman4tacos [OP] Well-Known Member
    Placer County, CA
    2000 Regular Cab (3RZ / W59)
    Yes, manual everything...even mirrors...
    So we all know the 1st gens have a really crappy fluid reservoir. I see plenty of aftermarket options for the 5VZ-FE, but nothing for my 3RZ. Mine is cracked/low fluid indicator light always on, etc.
    I never really use it anyways (empty currently), how could I go about completing the circuit/bypassing electrical so dash light goes off? I'd like to remove the entire reservoir as well since it's simply taking up space.
    Unless there's a better relocation option I missed, then i'm all ears. Thanks!
  2. Feb 26, 2025 at 5:24 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    You can get a decent replacement pretty cheap, but pretty sure you just need to disconnect the sensor and perhaps jump it with a wire. Frankly, I couldn't go without a washer, I use it all the time especially in the dirt. I like seeing where I am going.
    sonoran likes this.
  3. Mar 4, 2025 at 2:29 PM
    lineman4tacos
    Placer County, CA
    Yeah I know replacements are cheap but they all hang just as low and crack just as easily. I could try to modify an aftermarket aluminum one, but not right now - too busy
  4. Mar 4, 2025 at 3:27 PM
    MadNachos
    Then just get an aftermarket one and put it in the engine bay. That is what most people do that need to move it for large wheels. My first one was good for 23 years so when it got brittle I didn't see a need to relocate it. The Taiwanese one that I used seems to be of similar quality. The sensor didn't fit for crap though, used some FIPG.
  5. Mar 4, 2025 at 3:32 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Lots of different universal reservoirs in different shapes and sizes on ebay. it gives you the option to relocate to wherever you have space
    i stuck the factory washer pump into the side of an old Nalgene bottle and stuffed it in between the core support and 5vz factory airbox. has done the job for years now
    MadNachos likes this.
  6. Mar 4, 2025 at 8:20 PM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    If it's the usual toyota level sensor. Just spin it 180, it probably has a float switch.
  7. Mar 4, 2025 at 10:21 PM
    MadNachos
    Mine didn't fit because the hole was slightly too large...
  8. Mar 5, 2025 at 2:30 PM
    C_tanner
    C_tanner Well-Known Member
    Cam
    Oxford , AL
    1998 ex cab Tacoma, 5speed, 4wd
    here was my solution...
    lineman4tacos[OP] likes this.
  9. Mar 5, 2025 at 3:42 PM
    lineman4tacos
    Placer County, CA
    Now that I like!! compact and pretty simple
  10. Mar 5, 2025 at 4:18 PM
    Speedbeagle
    Speedbeagle Well-Known Member
    I got a little cube one like that in my baja bug. It works great. No level sensor, just a pump motor. Holds plenty of fluid and you can put it anywhere. just figure out how to defeat you level sensor or pull the bulb out of the dash if it even has a bulb and not an led.
    C_tanner likes this.
  11. Mar 6, 2025 at 7:55 AM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    Where can I get one of these?
  12. Mar 6, 2025 at 8:48 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    This one is a good replacement
  13. Mar 6, 2025 at 9:47 AM
    C_tanner
    Cam
    Oxford , AL
    https://a.co/d/1E2RrAI
    For 20 bucks you can’t beat it. And it’ll skeet washer fluid from here to ‘yonder. It’s impressively strong
  14. Mar 6, 2025 at 10:07 AM
    Toyoda213
    Jimmy
    SoCal
    Good looking out. Will also take a look at this one.
    Thanks for the info. 20 bones its not bad at all
  15. Mar 6, 2025 at 10:46 AM
    Speedbeagle
    that's quite the endorsement:D
    C_tanner[QUOTED] likes this.
  16. Mar 6, 2025 at 3:15 PM
    CoWj
    CoWj Lost and Found at the same time.
    Wyatt
    Northern CO
    Burt: 1998 2.7 Regular 5 speed 4x4
    Bilstein 5100, ARB Bumper, Warn VR EVO 8, 34x10.50 Toyo 4.88s ARB Locker
    I made a new one that fits in the factory location using an aftermarket bottle and putting an extended neck on it.
    For the level sensor, I found just leaving the wires disconnected and capped off the heat shrink made the light stay off.
    PXL_20240907_220546657.MP (1).jpg PXL_20240907_220540796 (1).jpg PXL_20240907_215734161 (1).jpg
    StreetTaco95, MadNachos and C_tanner like this.
  17. Mar 6, 2025 at 5:45 PM
    Speedbeagle
    Nice job on that. Looks good.
  18. Mar 8, 2025 at 12:29 PM
    MadNachos
    Don't forget the Honda Odyssey sprayers while you are 'in there', huge upgrade on the cheap, so much better.
  19. Mar 8, 2025 at 3:16 PM
    C_tanner
    Cam
    Oxford , AL
    I didn’t know this was a thing…
    MadNachos[QUOTED] likes this.
  20. Mar 8, 2025 at 4:08 PM
    MadNachos
