3rz wobbling harmonic balancer
Discussion in '1st Gen. Tacomas (1995-2004)' started by betterbuckleup, Jul 21, 2024.
  1. Jul 21, 2024 at 7:30 PM
    betterbuckleup
    betterbuckleup [OP] Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Noticed this when chasing down a small chirping coming from the drive belt area.
    Anyone encountered this before? Hoping I just need a new harmonic balancer. Never had it off before, so not sure what to expect.
    Hopefully not a damaged crankshaft...
    https://youtube.com/shorts/Qb9w3YTVYug?si=G27wxAxvz9tR3WRe
  2. Jul 22, 2024 at 7:13 AM
    ireymon
    ireymon Unknown Member
    Kenneth
    Winston-Salem, NC
    99 X-Cab 5 lug 5 speed
    Hyundai wheels, dings & dents...
    Mine was doing the same thing. I don't remember if it was quite as bad as yours but replaced the HB and no more wobble. As far as I could tell, there was no damage to the crank.
    To get that crank bolt off, I used the starter bump method and it worked beautifully.
  3. Jul 22, 2024 at 1:03 PM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    That's pretty rough I'd address it sooner than later.
    Like the other post mentioned... starter bump method is super easy. The HB is just popping off the belts and fan honestly nothing too horrible. Here was mine:
    https://www.youtube.com/shorts/zwOoN6jg9GA
    sonoran and ireymon like this.
  4. Jul 22, 2024 at 1:42 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Thats damaging the HB seal where it goes in timecover...
    Its on the verge of shearing the crankshaft key.......then it gets alot more expense/time/parts
  5. Jul 22, 2024 at 1:52 PM
    sonoran
    sonoran Big Loop
    Brob
    Flagstaffrica, AZ
    Tacoma 4X4 3RZ
    Tires: BF Goodrich TA KO2 235/85-16 Matching Spare (in rotation) Rear Suspension: King 2.5 shocks Custom Alcan springs OME greaseable shackles Front Suspension: King 2.5 coil overs Total Chaos UCAs New OEM LCAs Total Chaos Steering knuckle gussets Total Chaos Steering rack bushings Rear Diff: ARB locker (Zuk-Built diff) ARB HD Compressor Rear diff breather extended Armor: Custom full-coverage skid plates Stubbs sliders CBI rear bumper CBI Frame plates Engine: 3RZ Custom over leaf spring exhaust LCE Heavy Flywheel, Pro clutch LCE Stage 1 Head LCE Stage 1 Cams LCE Balance Shaft Delete Bed: Flip-PAC Camper Spray-in bed liner Footman’s loops Canyon Cooler KIST bottle opener Recovery: Custom and very complete tool/service kit including angle grinder and impact HiLift (I know how to use it) and/or Solo skid floor jack depending on trip Glock e-tool (shovel) Strap Interior: Fire Extinguisher Saddle Blanket seat cover Alpine sound Exterior: Anza Headlights WeatherTech wind deflectors “One Less Sprinter” bumper sticker
    Replace it ASAP.
    betterbuckleup[OP] likes this.
  6. Jul 22, 2024 at 2:00 PM
    O'Silver_Taco
    MD
    Mine wobbled that much and it cracked the inside of time cover....right around the shaft
    betterbuckleup[OP] and sonoran like this.
  7. Jul 22, 2024 at 2:06 PM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Same kinda thing on my 5vz, from the video it appears to be just the pulley separating from the inside/outside as it is rubber bonded.
    LCEngineering sells awesome billet aluminum replacements. Highly recommend, and make sure to get a new crank bolt and replace the front oil pump seal while your in there.
  8. Jul 22, 2024 at 2:17 PM
    sonoran
    sonoran Big Loop
    Brob
    Flagstaffrica, AZ
    Tacoma 4X4 3RZ
    Mine wobbled and the bold broke off in the crank nose. The LC pully is underdrive, BTW. Might not be your jam. I ended up buying an LC Stage 1 long block. Sweet motor!
  9. Jul 22, 2024 at 2:20 PM
    O'Silver_Taco
    MD
    I ended up buying the Dorman replacement HB from Oreily's for $120...
    that was 5 years ago....
  10. Jul 22, 2024 at 5:12 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    Fix ASAP before it bounces around and damages the crank or timing cover. Essentially the rubber that dampens the vibrations is worn out causing it to bounce around. The belt squeal is actually the outer part of the pulley slipping on the rubber part of the dampener. Replace the balancer, bolt and belts. I got mine off Amazon. The OEM ones are like $700.
  11. Jul 22, 2024 at 11:17 PM
    zooma-loom
    zooma-loom Well-Known Member
    RIGHT out of sight of SCOTTSDALE, AZ
    1997 Tacoma, Ext Cab, 4x4, 3RZ, A/T, Manual locking hubs
    Genuine toyota are $320.00
    13408-75030
  12. Jul 23, 2024 at 10:26 AM
    betterbuckleup
    Ian
    Concord, CA
    Thanks for the feedback everyone. I ordered a replacement OE HB, oil pump housing seal, oil seal, and seal saver from LCE.
    Hopefully it just needs that. I'll know more when I pull it off....
