3yr/36k warranty expiring. What should I check?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by topochico23, Sep 21, 2024.
  1. Sep 21, 2024 at 9:05 AM
    topochico23
    topochico23 [OP] Well-Known Member
    2022 DCSB SR5 V6 4x4
    My 3 year/36k mile basic warranty is expiring soon. 15k miles on the clock but will hit the 3 year mark. Any advice on what I should check, look for, listen for, etc. so I can address with the dealer before clocks runs out?
    Thanks in advance!
  2. Sep 21, 2024 at 9:22 AM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    Anything from bumper to bumper that could be considered a defect in materials or workmanship from the factory, except for things like normal wear parts (tires) or damage caused by accident or failing to do normal maintenance.
    topochico23[OP] likes this.
  3. Sep 21, 2024 at 9:35 AM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    Poke your head around and look for anything wet.
    topochico23[OP] and Tocamo like this.
  4. Sep 21, 2024 at 10:31 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    Not what you can check, but get an extended warranty, IMO
    You can get a extended warranty up until you go over the 3yr/36K miles.
    if you think you might want to check around on this forum for the info on Jerry that sells them
    Again just my opinion.
    Also i had the 8yr 75K warranty on my 2016 and 2 months before it expired i had to replace the famous "coolant crossover pipe"
    warranty covered it, a $1600. job.
    PS, at least check that. crawl under behind front tire passenger side. shine a light up behind the block and look for pink corrosion.
  5. Sep 21, 2024 at 10:51 AM
    InThePlains
    InThePlains Well-Known Member
    Start with checking on Timing cover leak Coolant bypass leak. They are pretty simple, would take couple minutes to do both.
  6. Sep 21, 2024 at 10:21 PM
    brigsby99
    brigsby99 Member
    Montana
    2022 TRD OR MT
    Check power steering fluid level and power steering rack boots for any wetness. Just caught my power steering rack leaking at 30k miles.
  7. Sep 22, 2024 at 5:51 AM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Is that covered by the powertrain 5/60?
  8. Sep 22, 2024 at 5:59 AM
    jdjones
    jdjones Well-Known Member
    2022 TRD Off-Road DCSB
    The Toyota plans say that they exclude “heating hoses, lines, and tubes”. Would that exclude the cross-over pipe?
  9. Sep 22, 2024 at 6:06 AM
    InThePlains
    That is not covered. I knew that first hand when mine leaked at 40k.
  10. Sep 22, 2024 at 6:13 AM
    jdjones
    That’s my concern. It’s clearly a pipe but the parts schematic calls it a “water by-passenger hose”.
    Hoses are flexible and pipes are not.
    Those bastards! :D
  11. Sep 22, 2024 at 6:35 AM
    jdjones
    On the other hand, the platinum brochure says that it covers seals and gaskets in the cooling system. It’s that what leaks?
  12. Sep 22, 2024 at 6:49 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Yep, check underneath, and in the engine compartment :crapstorm:
  13. Sep 22, 2024 at 7:22 AM
    brigsby99
    brigsby99 Member
    Montana
    2022 TRD OR MT
    Just the bumper to bumper as far as I know.
  14. Sep 22, 2024 at 7:23 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    NO, they fixed mine under extended warranty
  15. Sep 22, 2024 at 7:24 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    Well they fixed mine under warranty.
    topochico23[OP] and jdjones like this.
  16. Sep 26, 2024 at 6:29 PM
    topochico23
    Thank you, great idea
  17. Sep 26, 2024 at 6:30 PM
    topochico23
    Thank you!
  18. Sep 26, 2024 at 6:34 PM
    MGMDesertTaco
    I would flush the power steering system if you haven't yet. Only takes about 3 quarts. The reservoir is so small the fluid overheats too easy and degrades really fast causing wear to the system.
    Buy the extended warranty before 36k if you're worried about future issues.
  19. Sep 26, 2024 at 11:21 PM
    InThePlains
    It's a manifold connecting multiple coolant ports and a temp sensor boss. A pipe has two ends.
  20. Sep 27, 2024 at 2:57 AM
    T.BROCK
    T.BROCK Well-Known Member
    NorthEast Tennessee
    2022 Barcelona Red 4x4 Off Road
    MOST DEFINITELY THIS ^^^^^^
    The extended warranty is piece of mind...it just takes 1 thing to go wrong with your truck (Crossover pipe,transmission etc. ) and having to take it to a dealership and you'll be glad you have it.
