4” lift without cutting the frame?? 2018
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Brownstain, May 12, 2018.
  1. May 12, 2018 at 5:20 AM
    Brownstain
    Brownstain [OP] Member
    2018 Tacoma 95 supra
    Just bought a 2018 Tacoma today☺️ and I’m seeing “horror stories” of people haveting to cut their frames with a 6” lift.
    So I’m wondering if anyone is running a 4” lift without chopping, or if it’s even possible??
  2. May 12, 2018 at 5:28 AM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    Is the truck 4wd
  3. May 12, 2018 at 5:31 AM
    Brownstain
    Yea trd sport, 6 speed manual 4x4
  4. May 12, 2018 at 5:34 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Then the only way to lift above 3" is a drop bracket lift, which means part of the frame gets cut out and their bracket gets welded in.
  5. May 12, 2018 at 5:34 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    On another note, congrats on the new purchase and welcome to TW!!
  6. May 12, 2018 at 5:41 AM
    Brownstain
    Thanks! I’m very excited as I am a avid Toyota fan boy.
    So with cutting the frame that has to take a tole on the ol’ warranty then hey?
  7. May 12, 2018 at 5:46 AM
    TheGrayRider
    TheGrayRider MARANATHA !!!
    NW Florida
    2017 BBP DC 4X4 OR
    I was thinking of a 4” or 6” lift on my truck until I watched this video ... it’s very detailed and talked me right out of one of these lifts
    https://youtu.be/OKKeRZ1y8Og
    EatSleepTacos likes this.
  8. May 12, 2018 at 5:47 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah it definitely would. If later years were to ever have rust issues like first and second gens, then you'd probably have a hard time getting them to replace your frame. My recommendation would be to do a lot of research and reading and see if it's worth it to you.
    BuddyS likes this.
  9. May 12, 2018 at 5:47 AM
    JeffP213
    JeffP213 I used to do mods. I still do, but I used to, too
    Jeff
    Central, VA
    15 TRD OR
    Get 3” and big enough tires and before you know it you’ll be 4” high playa
  10. May 12, 2018 at 5:50 AM
    Clearwater Bill
    Billy
    Largo Florida
    Everything that's touched of course and anything the dealer can blame as a causality effect.
    Keep in mind that lift does not equal ground clearance, nor does it automagically create space for jumbo tires.
    Especially a drop bracket (typically 6") lift. Your clearance is still a function of the axle line. Even though your body may have better approach/departure angles.
    Tire fitment is much more affected by wheel selection (all fitment parameters), body cutting, pounding and chopping.
    You'll find, with some research, that a 2-2.5" lift is optimum for not too many side effects.
    You'll also find you can run a full 33" tire with no lift at all if you pick the right tire and wheel combo.
    PNW/TRD Steve likes this.
  11. May 12, 2018 at 5:52 AM
    GreeGunc
    Jacob
    North GA
    Or get out the saw and fit 35s on a 2.5"~ lift
  12. May 12, 2018 at 5:53 AM
    Brownstain
    Good point, rust warranty out the door basically. Thanks guys definitely going with a 3”
    Side note** looking to purchase 18” rims with a +20 offset, probably just stick with 265 33” rubber. Would I have rub issues? And would it stick of from the truck much? Don’t want rocks thrown at the truck as I travel a lot of gravel. Lol
  13. May 12, 2018 at 5:54 AM
    Tantaco37
    Tantaco37 Yes those are Cheech and Chong yard gnomes!
    Western Kentucky
    Had a 2017 TRD Off-road, now a GMC AT4
    Had these A.R.E. Overland Truck cap, Cover King Tactical seat covers, OME BP-51 full suspension and dakars, SPC adjustable UCA's, Husky Floor Mats, Mobtown Off-road sliders, Cali Raised light bar and ditch lights and bed stiffeners, mobtown off-road front ifs skid, uniden bearcat CB Amd firestick. Now a super fancy stock truck!
    I would just go with a 3 inch or less, plenty of clearance for anything offroad unless your trying to build a big rock crawler
  14. May 12, 2018 at 5:57 AM
    Tantaco37
    Western Kentucky
    The biggest tire you can do is a 255 85 16 for stock and that gives u a 33” tire basically. I guess with 18” wheels you could do a 255 65 maybe or 75. But if you don’t want skinnies and you go with 285 you’ll have to do a CMC
  15. May 12, 2018 at 6:06 AM
    Nettleberger
    Nettleberger Well-Known Member
    2017 Tacoma TRD Pro DCSB Super White
    CMC - cab mount chop = metal cutting and welding
    I'm happy with my 32s (265/70R17) and no rubbing or chopping needed... 33s can usually fit with no or minimal rubbing. Consider your bankroll and if you're okay being liable - go for it.
  16. May 12, 2018 at 6:57 AM
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    You can do a 3 inch suspension lift plus 1 inch body lift.
  17. May 12, 2018 at 9:24 AM
    Long Time Toy Fan
    Long Time Toy Fan Well-Known Member
    17 DCOR
    Cookie cutter Tacoma, 888/Dakars/LR/ECGS/Sliders
  18. Nov 19, 2018 at 2:42 PM
    FOUR2NO
    FOUR2NO New Member
    2018 Black Tacoma TRD Sport 4x4
    Some
    Look For Tuff Country 4" Lift. I have this lift on my truck now no cutting! LUV IT! Item #54905KN
