4” Rough Country with 5” bilstein 5100
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MammothTaco1234, Jul 27, 2021.
  1. Jul 27, 2021 at 2:35 PM
    MammothTaco1234
    MammothTaco1234 [OP] Member
    Matthew
    Miami
    2006 Toyota Tacoma 4x4 Double Cab
    31” tires 20” rims 3”/2” rear leveling kit Spyder auto headlights
    Hello everyone,
    prob a dumb question but can I fit 5” bilstein 5100’s on a 4” lift kit from Rough Country? I got a 2006 Tacoma and I’m not going to be taking it on no serious overlanding or off-roading but I do want a quality ride and maybe a bit of off-roading capability. And I want some lift in the taco. So do you guys think that’ll fit? And what do you guys recommend for a 3-5” lift kit for Tacoma’s?
    bilstein 5100 SKU: E122-B110
    Rough Country lift SKU:746.20
  2. Jul 27, 2021 at 2:55 PM
    Clearwater Bill
    Billy
    Largo Florida
    So you are aware that both the 4" and 6" kits require cutting a slab out of your frame, right? And you're up for that? (pun intended)
    How will you raise the back end? Jumbo blocks or beefy springs?
    Mark77 and Mastiffsrule like this.
  3. Jul 27, 2021 at 2:56 PM
    ndmak
    ndmak Well-Known Member
    it is unlikely to have a quality ride and 4" spacer lift on the same truck.
    what do you like and dislike about your current set up? why do you want to add more lift than 3"?
    in general if you go more than 2.5" it is recommended to get UCAs that can provide proper alignment.
    save up $1,500 more dollars, get a better set up with longer coils, UCAs, and leaf pack. you will be disappointed if you dont.
  4. Jul 27, 2021 at 2:57 PM
    MammothTaco1234
    Matthew
    Miami
    No I wasn’t, thanks for that info. Reason why I ask on here before I do something I’ll regret
  5. Jul 27, 2021 at 2:57 PM
    MammothTaco1234
    Matthew
    Miami
    Now what 3” lift kit do you recommend?
  6. Jul 27, 2021 at 3:02 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Eibach
  7. Jul 27, 2021 at 3:36 PM
    DG92071
    DG92071 Well-Known Member
    Probably the biggest problem with the OP's post is 99% of the replies will be people re-writing what they've read instead of writing what they experienced.
    4" lift front knuckles will lift it 4", won't require any cutting of the frame, and with the same size tire as before (in comparing apples to apples) it'll ride exactly the same as before.
    8"+ lift, 37's, and rides like a caddy from the 1960's which is great in my opinion but probably not so great in other people's opinions.
    IvanhoeTaco likes this.
  8. Jul 27, 2021 at 3:56 PM
    Clearwater Bill
    Billy
    Largo Florida
    Sku provided by OP is for a drop bracket lift.
    Provided instructions read
    Starting from the edge of the cam bolt plate on the back side of the rear cross member make a mark at 3" and another mark at 12”.
    This is where the rear cross member needs to be cut
    Take a reciprocating saw and cut straight through the marks at 3” and 12”
    Sounds like your taking a 9" chunk out of the frame to me.
    Thunder Fist likes this.
  9. Jul 28, 2021 at 6:06 AM
    DG92071
    1. I was giving the OP an option that hadn't yet been presented to get a 4" lift without any cutting.
    2. It's *you're*.
    MammothTaco1234[OP] likes this.
  10. Jul 28, 2021 at 6:15 AM
    Clearwater Bill
    Billy
    Largo Florida
    I was unaware that lift spindles/knuckles were available for 4wd version like the OP has.
    I thought those were only for 2wd.
    Any chance you have a link to a site with the parts you reference?
    MammothTaco1234[OP] and trdmtb like this.
  11. Jul 28, 2021 at 12:32 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Yep giving an option that doesn’t exist. Worthless.
