4.0 1GR-FE Swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by Nbea03, Apr 30, 2025.
  1. Apr 30, 2025 at 5:05 PM
    Nbea03
    Nbea03 [OP] Member
    Nevin
    1999 red tacoma TRD SR5
    I have a 1999 Toyota Tacoma 4x4 5-speed. I am wanting to get more power and a side project by swapping out the 3.4L with the 4.0L . I am wondering if someone has done this or how difficult it is to install?
  2. Apr 30, 2025 at 5:12 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If you have to ask, then it's going to be "really difficult".
    Super charge the 3.4. It will be easier and less expensive.
    A good used 1GR is $4,000+ last I looked.
    BartMaster1234 likes this.
  3. Apr 30, 2025 at 5:15 PM
    Nbea03
    Nbea03 [OP] Member
    Nevin
    But what if I just wanted to research about the swap and see what other people know and decide what I do with it?
  4. Apr 30, 2025 at 5:18 PM
    TnShooter
    Deogee
    STOCK
    Then by all means do your research.
    You say 4.0 swap, remember you need a transmission too.
    Do you know how to weld?
    Are you ok with having a custom driveshaft made?
    You're going to need to do a lot of fab work to even get it to fit.
    Then you'll need figure out the wiring.
    Do you have wiring diagrams and ECM pinouts for both the truck and engine and transmission?
  5. Apr 30, 2025 at 5:19 PM
    02hilux
    Planet: EARTH
    If you’re in a smog restricted state, make sure to chat with a state referee first before committing. If smog isn’t an issue, why not go with a ls3 or 2uz?
  6. Apr 30, 2025 at 7:07 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    I doubt you’ll find many people, if any, that have swapped a 4.0 in place of a 3.4. Simply because it’s not worth the cost and effort, for an extra 50-60 HP that you could get by supercharging the 3.4.
    If you already had the 4.0, the 3.4 was on its last legs, and you have the space, tools, etc to do the swap, then go for it. Otherwise, spend the effort to get some real gain.
  7. Apr 30, 2025 at 8:02 PM
    Glamisman
    Glamisman Well-Known Member
    Dont want to poo poo your project and if my words are too harsh, please accept my appolgies in advance...having said that, there are so many things that can go wrong that you dont think of right now, cooling and exhaust come to mind immediatly. If your truck is a rolling wreck and you have unlimited time and money then go for it. The way your truck is right now, it has some value to someone, if you do the mod and it is sucessful no one is going to want your frankenstein truck after you are done.
    BartMaster1234 and OLDHMECH61 like this.
  8. May 1, 2025 at 10:43 AM
    Papa Surf
    Papa Surf Well-Known Member
    Galveston, TX
    1999 3.4L Prerunner. 2nd Owner since 2001.
  9. May 3, 2025 at 10:33 AM
    02hilux
    Planet: EARTH
    I wouldn’t say poo poo but your targeted buyer will be limited. Many may think it’s a Frankenstein because there’s modification that cannot be reverse but personally, that’s what makes it “unique and attractive.” If I didn’t live in a smog stricken state, I would have gotten rid of the gutless SC 5vz if I didn’t turbo and went with a SC 2uz or turbo ls3 swap. The rumble a v8 make is awesome. Even a SC 1gr would be a worthy contender.
    Years ago, I CA BAR/REF a 22ret into my 83 that had a 22r. Many said it was a waste and should had went with a 22re instead but the factory fist size turbo made some difference and I had a BOV and watercooled intercooler. The digital cluster swap was oe looking that for those who looked inside had to do double take and wonder why it’s digital for an 83. Everyone has their own agenda and accomplishment, I say go for it and be different. Just accept faith for what it is and push forward.
