4.0 1st gen: possible?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tb99trd, Apr 16, 2012.
  1. Apr 16, 2012 at 2:54 PM
    tb99trd
    tb99trd [OP] Well-Known Member
    Tom
    Petaluma CA
    99 TRD 4x4
    Bilstein 5100s (@ 2.5), Toytec 2" AAL, gray wire mod
    Has anyone heard of anyone swapping out the running gear (engine, tranny, etc) from a 2nd gen into a 1st gen? Buddy of mine has a smashed up 2nd gen with an apparently still perfectly good engine, tranny, driveshafts and rear axle. I wonder if it's worth holding onto to swap into my 99 when she finally blows.
  2. Apr 16, 2012 at 5:25 PM
    ethanfoy
    ethanfoy Well-Known Member
    ethan
    Little Rock AFB
    99 toyota tacoma xcab 4x4
    You will need to measure I'm sure that the 4.0 is bigger than the 3.4 and the engine bay seems pretty tight as it is in the 1st gens
  3. Apr 16, 2012 at 5:28 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    with enough time and money, anything is possible.
  4. Apr 16, 2012 at 5:39 PM
    ethanfoy
    ethan
    Little Rock AFB
    X2 the above
  5. Apr 16, 2012 at 5:41 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    This!
  6. Apr 16, 2012 at 5:42 PM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    I have no important input buuuuuut...will he sell his tailgate? lol I need one for a new project.
    I'll PM so i dont clutter this thread
  7. Apr 16, 2012 at 5:50 PM
    desert guy
    desert guy Well-Known Member
    Bryan Blagg
    o.c.
    toyota offroad truck
    FiberWerx Tacoma front fiberglass clip, currie rear 9 inch, 35 Spline axles, sick nicks fab steering, Beard Seats, King Coilovers, Bypass, & Hydraulic Bumpstops, DEAVER Springs
    X3 the above! You can do anything. How much cash you want to spend?
    We dropped a 4.0 in my friends Desert Race gen. 1 truck a couple years ago. This is a list of some modifications and parts:
    - 4.0 motor and Tranny
    - ECU/ Computer and ALL wiring for the 4.0
    -custom made motor mounts (they might have conversion kits now)
    -custom tranny mounts
    -Battery moved to back
    -modify engine area for 4.0 clearance & radiator clearance from front core support
    -new size DRIVE SHAFT because 4.0 tranny sits in different spot
    -Should I keep going???
  8. Apr 16, 2012 at 5:54 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    yes
  9. Apr 16, 2012 at 6:12 PM
    desert guy
    Bryan Blagg
    o.c.
    -Are you going to run headers?
    -new exhaust
    -need aftermarket intake (stock set up takes up a lot of room)
    -Is your truck stock or lifted? (the 3.4 is lighter than the 4.0, front might sag)
    -so maybe new springs/ or spring rate
    **Then you need to pay for a CHP VIN inspection for smog if you plan on driving in the street. You will Automatically FAIL the smog visual with a different motor from stock.
    ( Im going by california rules)
  10. Apr 16, 2012 at 6:17 PM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 3.4 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    My mechanic friends always say this however it looks like this:
    With enough time and money, anything is po$$ible
  11. Apr 16, 2012 at 7:56 PM
    Cvd2312
    Cvd2312 Well-Known Member
    Cory
    Oregon
    97 Tacoma 3.4L
    Bilstein 5100's all the way around, 2" shackles in rear, front diff drop, 32x11.50.15 BFG A/T, 15x8 Ultra 164 Wheels
    Why would you want to? The 3.4 is better!!
  12. Apr 16, 2012 at 7:59 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Good info.
  13. Apr 16, 2012 at 8:03 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    do what you want to do, but sounds like a no haha
  14. Apr 16, 2012 at 9:00 PM
    desert guy
    Bryan Blagg
    o.c.
    I know! lol... We learned the hard way a couple years ago. I hope I didnt make it sound shitty.
    But It did come out awesome!!!! It just took a lot of time and $$
  15. Apr 16, 2012 at 10:37 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    A tacoma 4.0 is probably about the same exterior size as a 4.8-7.0 chevy v8.
    If you're gonna go custom you might as well make it worth it. 3.4 to 4.0 is not worth the effort.
  16. Apr 16, 2012 at 10:38 PM
    tb99trd
    Tom
    Petaluma CA
    99 TRD 4x4
    desert guy,
    1. thanks for the info
    2. disgustingly awesome sig pic.
    3. sounds like quite a project. prob not worth it with my mediocre mechanical skills and shallow pockets, but it is good to hear it's been done and i can only imagine how awesome it would be.
  17. Apr 16, 2012 at 10:42 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Umm timing belts suck.
