4.0 chain break
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mark2005, Mar 3, 2021.
Timing chain break
  1. Help
    2 vote(s)
    50.0%
  2. Suggestions
    2 vote(s)
    50.0%
  1. Mar 3, 2021 at 2:51 PM
    Mark2005
    Mark2005 [OP] Member
    Mark
    Charlotte NC
    2005 Tacoma sport V6 4X4
    My timing chain broke this morning. Not sure on damage. It has 230,000 miles. Any suggestions?
  2. Mar 3, 2021 at 3:01 PM
    badger
    badger Well-Known Member
    07 SR5
    I don't know whether this engine is an interference design or not. It probably is. If so, you likely have damaged valves. With that many miles, I would look for a lower mileage used engine and call it a day. If the valves escaped damage, you could replace the chain and gears.
    whatstcp, TRDSport10 and Mark2005[OP] like this.
  3. Mar 3, 2021 at 4:25 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It isn’t an interference engine.
    https://www.toyotanation.com/threads/tacoma-4-0-v6.147979/
    But there still could be gear, guide, and timing cover damage.
    You’d still need to pull the timing cover at a minimum to see “what’s damaged”.
    TRDSport10 and Superdave1.0 like this.
  4. Mar 3, 2021 at 4:28 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Pretty sure it is just going by the compression ratio. Also 4 valves per cylinder right??@Torspd will know for sure as he’s had several apart
  5. Mar 3, 2021 at 4:37 PM
    TnShooter
    Deogee
    STOCK
    Typically, it is the valve that smacks the piston on an “interference” engine. (Not referring to valve float here)
    At least that’s my teaching. (I did own a Honda)
    Anyways you are most correct in saying “Torspd will know”.
    That guys is a wealth of information on these engines.
    whatstcp likes this.
  6. Mar 3, 2021 at 4:42 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
  7. Mar 3, 2021 at 4:58 PM
    TnShooter
    Deogee
    STOCK
  8. Mar 3, 2021 at 5:03 PM
    TireFire
    Olympic Peninsula
    With high compression you typically also have a smaller combustion chamber necessitating the interference design which is why a brought that up. And I didn’t mean valve float but that the intake and exhaust valves could potentially (again, not sure 100% on this engine) hit each other if the secondary timing chain is also kaputt.
  9. Mar 3, 2021 at 6:09 PM
    Bishop84
    Bishop84 Well-Known Member
    You need to remove it and tear it down. Or simply find a low mileage used motor. Start phoning wreckers and make sure to get some kind of warranty.
    Yukon DoIt and TnShooter like this.
  10. Mar 3, 2021 at 8:05 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Are you sure that the chain is broken?
    I'm not saying that it isn't, but in my short lifetime I have never seen a chain actually break. Stretch and slip a tooth yes, break a chain no.
    b_r_o, whatstcp, TnShooter and 3 others like this.
  11. Mar 3, 2021 at 8:55 PM
    Mtucker1972
    Mtucker1972 Member
    Michael
    Tacoma 2015 TRD sport 4x4
    None
    Tacos are non interference. Thats one reason I prefer them. Your motor was probably not damaged. Replacement of the chain should get it back to normal.
  12. Mar 6, 2021 at 8:08 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Yukon DoIt, TnShooter and tinker_troy like this.
  13. Mar 6, 2021 at 8:44 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Any pics OP?
  14. Mar 7, 2021 at 5:23 AM
    badger
    07 SR5
    TnShooter[QUOTED] likes this.
