4.0 engine drops number 6 cyl,
Discussion in 'Technical Chat' started by creative6364, Oct 14, 2012.
  1. Oct 14, 2012 at 6:28 PM
    creative6364
    creative6364 [OP] New Member
    jay
    connecticut
    05tacoma4x4quad cab
    lift kit,custom20in wheels,custom made grill,dual exhaust.
    first off,im not good at the computer,sorry it'll show. I have an 05 tacoma 4x4quad cab sport.Ihave 172000 mileson it and take very good care of it. One week ago i left t a stop sign pullimg away very easy and hear a bang in the engine compartment,the truck goes to half power and the check engine light come's right away. Number 6 cyl. has an 70 percent air loss but cant see a darn thing in the borescope test.Im stunned. the engine was so clean that it looked like i just changed the oil. Any help please? thanx jay.
  2. Oct 14, 2012 at 6:33 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Headgasket?
  3. Oct 14, 2012 at 6:41 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    To me a bang sound probably means a bent valve or broken connecting rod. With that low compression you definitely have a problem. I'd pull the head and/or oil pan and have a look. Borescopes work great up to a point. Sometimes you just have to take stuff apart to see it.
  4. Oct 14, 2012 at 6:42 PM
    creative6364
    jay
    connecticut
    05tacoma4x4quad cab
    Thanks steve, but all the compression test air loss goes down the bottom of the crankcase. dahm man i love my truck!
  5. Oct 14, 2012 at 8:44 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Sounds like rings or a cracked piston.:mad: The good thing is that these engines are still in production, so you should be able to find a low mileage one out of a wrecked truck. That's probably your best bet unless you've got the time to pull your engine apart and inspect it. With the design of the engine block, you are going to be SOL if there is damage to the cylinder wall, not to mention the cost of fully rebuilding the existing engine.
    Whatever you do, stay away from parts store engines. I've sold them:eek:, you don't want one. My first choice would be a brand new crate engine, fully assembled (don't thing Toyota even does that), second would be low mileage salvaged engine, third would be a rebuild by a local, competent machine shop (hard to confirm reliability if you don't have previous experience with them).
    Good luck, tough place to be.
  6. Oct 15, 2012 at 5:42 PM
    creative6364
    jay
    connecticut
    05tacoma4x4quad cab
    Thank you,im just baffled,my truck is super clean. People still ask me if it's brand new! I still have a 1883 long bed 4x4 at home with 742000 original miles. Same care all it's life.???????????
  7. Oct 15, 2012 at 6:11 PM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    could you elaborate on this? :confused:
  8. Oct 15, 2012 at 7:42 PM
    joes06tacoma
    Joe
    Central Coast, CA
    From everything I have read on here, the 4.0 is an aluminum block with a paper thin iron liner in each bore. I believe the term is "spiney liner", so that they can't be pressed out and replaced. Some of the posts here about high performance engine builds have shown the block can be bored out and resleeved, but it's not a standard, stock rebuild type of thing. It looks like big dollar, go fast stuff. It's not like the 3.4 v6 with an iron block that can be easily rebored for oversized pistons.
    The OP sounds like his goal would be to get his stock engine back to stock running condition. If there's damage to the stock block, I don't see that being economical compared to starting over with an undamaged block.
    Edit: Here's a link: http://www.toyotatundraforum.com/pdf/1GRFE Engine4.0.pdf See page EG80 where it talks about the cylinder liners.
  9. Oct 16, 2012 at 10:02 AM
    B737
    Kevin
    Jersey Shore
    stock
    interesting read, thank you. i did not know any of that.
