4.0 Fusebox Wiring Upgrade
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rngrchad, Feb 18, 2012.
  1. Feb 18, 2012 at 2:32 PM
    rngrchad
    rngrchad [OP] Yankee Oscar Tango Alpha
    The former USA now USSA (United States Socialst Am
    08 Rugged Trail TRD
    Rockwell 30 ton axles.
    Hey gang, long time no chat. Glad to see everybody still active and kicking ass. I just recently installed dual group24 batteries in my 2008 Tacoma and upgraded to 1/0 wire from alternator to the fuse box hot. Then from the fusebox there is another hot wire that goes to the + battery terminal. I need to upgrade this wire as well but I'm having trouble figuring out how to get the fusebox apart to do this....anybody???
    I'm sure lots of CAR AUDIO guys have done this, but I can't find much for it online. And just to answer ya'lls question in advance: I'm going to upgrade to a 270 AMP alternator to power some massive radio Linear Transmitters that draw near 210 amps.
    Thanks gang.
  2. Feb 18, 2012 at 3:41 PM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    Holy Crap! :eek: Sorry I can't answer your question OP, but are you also planning to weld the guy next to you at the stoplight's door shut? With that much juice, just keep her below 88 mph...
  3. Feb 18, 2012 at 3:45 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    X2! Sorry can't answer you, but I'll give you a bump, at the same time asking, What are you powering these things for?
  4. Feb 18, 2012 at 4:12 PM
    rngrchad
    08 Rugged Trail TRD
    There being powered for long distance radio communications. One of the transmitters draws 30 amps the other draws 180 amps. The radio alone draws 10 amps. So that's almost a grand total of 220 amp MAX draw from my radio setup. That leaves me with 50 amps to run the truck with a 270 amp alt.
    I currently have a dual battery setup, but will add 2 more group 24 batteries in the bed soon. I have 1/0 welding cable powering the transmitters, and 1/0 used for parralleling the batteries, and 1/0 for added grounds. VOLTAGE drop is my enemy. Radio transmission makes SPL audio boys amp draw look like a fucking joke. This is a small mobile station compared to some of the heavy keydowner's I run with. Anyhow, take care, and I'm hoping to get some info on upgrading the + wire coming from the fuse box to the + on the battery still.
    Take care guys. Thanks for bump'n the thread.
    Peace.
  5. Feb 18, 2012 at 4:19 PM
    rngrchad
    08 Rugged Trail TRD
    Here's the dual group24 battery install I just finished. It turned out nice. These are BIG batteries, not the tiny group 34 or 43? that most offroaders are using. I had to move the fuse box towards the firewall 6", then rewire everything else to lengthen the connections from the alternator, fuse, grounds etc. PITA...but it turned out PIMP.
    I'm adding two more (total of 4 batteries then) soon to help keep up with the power demands of a CONSTANT draw of 230 amps (this is NOT like car audio draw, this shit is constant...not a quick bass hit...there is little to no recovery during a radio keydown like hardcore audio guys have)
    I know I know, most think I'm over killing but far from this. I'm trying to keep amp demands ok while keeping voltages along the lines constant. a few volts of loss = hundreds of lost watts of output.
    I'm adding two more soon to help keep up with the power demands of a CONSTANT draw of 230 amps (this is NOT like car audio draw, this shit is constant...not a quick bass hit...there is little to no recovery during a radio keydown like hardcore audio guys have)
  6. Feb 18, 2012 at 4:27 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    Wow that is serious.
    270a x 12v= 3240w though I would think they would use more power than that? I know nothing about radio transmission though.
  7. Feb 18, 2012 at 4:36 PM
    rngrchad
    08 Rugged Trail TRD
    You can't just do the math on the voltage and amperage and get output. Efficiency is a big deal......but thanks Fracture, I do appreciate the euqation amps x volts = watts -;)
    Here is the radio gear that is sucking so much juice. It's AMP hungry I tell ya ! It destroys VOLTS like no other. Hence 1/0 Welding cable.
  8. Feb 19, 2012 at 4:47 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Damn! Do you even need to turn on heat in the Winter? All that has to put out some heat! What are you transmitting? Ham radio or something along those lines?
  9. Feb 19, 2012 at 7:21 AM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    clean your truck
  10. Feb 19, 2012 at 7:24 AM
    rngrchad
    08 Rugged Trail TRD
    Thanks for the "clean my truck" thread bump. I make my girlfriends clean my truck....06Sr5, sweetie, pumpkin, do you wanna do it? Thanks hun.
  11. Feb 19, 2012 at 7:30 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    :laughing:
  12. Feb 19, 2012 at 7:43 AM
    06SR5canada
    Saskatchewan
    06 dblcab SR5
    Those shemales you get to clean them dont count, i dont care what you say, just cause they got tits and wear lip stick dosent make it ok.....now go wipe your chin.
    oh and the new sundown ns-1's pull 984amps at .7 ohms
  13. Feb 19, 2012 at 8:06 AM
    rngrchad
    08 Rugged Trail TRD
    I'd like to see you mount those in your Tacoma and still beable to stuff enough alternators under the hood to power them.....you see 06sr5, I actually own what I'm talking about. I can throw some other homebrew linear transmitter's electrical draw specs at you that I don't own and that would make those ns1's look like Childs play. Don't make me prove it to you. So unless you have some knowledge or are interested in this thread, you just shutup and CLEAN MY TRUCK.
  14. Feb 19, 2012 at 9:26 AM
    Bobbb
    Bob
    Bob
    Bob
    Tundra TRD/OR
    Just out of curiousity OP, looking at your dual batt setup, do you think you'll have any heat issues with those? I know that high heat eats batteries like they're going out of style.
  15. Feb 19, 2012 at 9:33 AM
    joes06tacoma
    Joe
    Central Coast, CA
    Why not just run another wire direct from the alternator to the batteries? You're going to run your radio equipment directly from the batteries, right? I don't see why you'd have to mess with the stock fuse box.
  16. Feb 19, 2012 at 9:51 AM
    4wd Boss
    4wd Boss Shake and Bake
    Jefferson
    Big D
    07 4dr 4x4 V6
    Fog Light Mod
    are you, or are you not, trying to contact ALIENS!!!? :alien: :popcorn:
  17. Feb 19, 2012 at 11:30 AM
    rngrchad
    08 Rugged Trail TRD
    The alternator on the truck now is only a single pole alt. There is absolutely no room for more than one positive lug feed off this oem 130 amp unit. I'm currently trying to squeeze every bit of efficiency I can out of it....the radio equipment is only being run at half power because of my lack of available current. When I get my Ho 270 amp unit I'm going to see if they offer it in a dual stud design, although I don't think they do.....
    Oh, and about the batteries getting hot....and losing their life expectancy; I keep a voltage meter in the cab so I can monitor the drop. I let off the key before drawing the batteries below 12 volts. After I order the new alt, and do some 1/0 cable upgrade I should all but eliminate voltage drop along my supply lines...
    If I keydown at night For too long at night my lights almost shutoff lol
  18. Feb 19, 2012 at 11:35 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    This made me LOL.
    Seriously OP, what are you doing with this mobile radio (station)? Why not just have a set up at home for all this equipment?
  19. Feb 19, 2012 at 12:28 PM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    Hmm.. do you have to wear lead plates over your junk to operate those? Yikes! Doesn't a normal amateur radio pull less than 10A in a mobile install?
  20. Feb 19, 2012 at 1:55 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    How about a pair of T605's they will give you 225 amps. Just before I retired from the PD's the Crown Vic's alt. was at 280 amps and they are not a lot bigger then the stock Toyota alternator with a single wire. That's a lot of smoke what are you using for an antenna? ( by the way I do have a clue 73's N3LYT)
