4.0 knocking?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by afp98926, Sep 13, 2023.
  1. Sep 13, 2023 at 11:10 AM
    afp98926
    afp98926 [OP] Member
    2012 Tacoma TRD Sport 4x4
    I bought the truck a few months ago, it's a 2012 tacoma with the 4.0, had 145,000 miles, runs great. I change the oil every 5000 with full synthetic. It makes this sort of knocking/metal on metal sound only about 50-60% of the time when idling or at RPMs below 2000. When I rev it up or when accelerating I don't hear it. It seems to be worse when it's cold outside but not necessarily whether the engine is cold or not. I've read a lot about these 4.0s being noisy, can anyone who owns one confirm if theirs sounds the same?
    https://youtube.com/shorts/Scl--xfjN3I?si=UgJYCNhDVom-TN3E
  2. Sep 13, 2023 at 11:17 AM
    AwArD
    AwArD Well-Known Member
    2012 Tacoma Trail Teams TRD sport Double Cab V6 4.0
    Icon Rxt rear leaf option 2 Elka 2.5 DC Reservoir Front/Rear with 600lbs/14inch coil JBA Offroad STD high caster UCA Whiteline LCA inner bushing Mevotech TTX LCA Ball joint Woodward U-Joints Intermidate steering shaft mod Uni filter mod TRD Cat-Back Exhaust Timbren Active Off-Road Bumpstops Front/Rear Overland Torque Tune (OTT) by Yotatune Amsoil signature engine/transmission Amsoil SEVERE GEAR 80W-90 Front/rear diff and T-case Tacoma bed mat Weathertech mat front and rear cabin Summer BFG Ko2 265/65r17 E rated / Fuel Rebel 6 Bronze wheels Winter Nokian Hakkapeliitta 10 studded, 265/65r17 / oem Toyota wheels
    Sound like this one. They are noisy, mine is noisy don't worry about it.
  3. Sep 13, 2023 at 11:40 AM
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    OP sounds more like rod knock than the 2nd one. Check oil pressure? Maybe throw something thicker in there to see if it quiets down?
  4. Sep 13, 2023 at 11:46 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Do a used oil analysis
    Sterling_vH111 likes this.
  5. Sep 13, 2023 at 12:19 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
  6. Sep 13, 2023 at 12:43 PM
    Logger
    Logger out for a rip are ya bud?
    Sam
    '13 TRD OR Double Cab
    FWIW my '13 sounds the same. I especially notice it when I idle my fat ass up to a drive-through window; it seems to echo off the wall. I'm at 201,000 and the 4.0. From what I've gathered, the "Taco knock" is fairly well-known, but not widely accepted as the "Taco tick" though. I'd be a little more concerned if it mine stayed consistent with the increase in RPM but it doesn't. So until that happens, I'm going to just keep changing my oil at 5k and eating fast food.
  7. Sep 13, 2023 at 12:53 PM
    AwArD
    You can't miss a rod knock. I don't think it's that but an oil analysis is a great tool to see if realy something is going bad. If there enough oil and changed frequenly i don't see why out of the blues a rod knock can start for no reason on these engine. Crack the oil pan under, if it's sludge town inside you will need to worry.
    Williston likes this.
  8. Sep 13, 2023 at 12:59 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    That sounds normal to me.
    The fact that the sound is sometimes more prevalent than others, makes it even more “more normal” in my experience.
    I does NOT sound like rod knock.
    Don’t get worried. I think the truck is just fine.
    TireFire likes this.
  9. Sep 13, 2023 at 1:45 PM
    Ted Striker
    Ted Striker Well-Known Member
    2 WHEEL DRIVE!
    The top end of the 1GR is ticky/rattly, and that's normal.
    Can't really hear a rod knock in that vid (doesn’t necessarily mean it's not there) If you move your head around to locate it, rod knocks emanate from lower in the engine, and sound a little more "intentional" like hitting a hammer on metal. IME you hear (almost feel) rod knocks when the load changes, i.e. when you're just on or off the gas while driving.
    How much do you know the history? Has a head gasket been replaced?
  10. Sep 13, 2023 at 2:49 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    I have this noise on my 2014. 4.0L 104k with 5K synthetic oil and OEM filter changes since new. No oil use, smoking, etc. It's not rod knock. You'll know that sound when/if you hear it: hurts your ears to listen to it. To me it sounds like exhaust noise and coming from the down pipe and cat on my truck. The mechanical lifters don't help and add to the "symphony" of these engines. I don't hear it at all in the warm weather months.
    Comataco likes this.
  11. Sep 13, 2023 at 3:12 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    FWIW, there are no lifters on the 1GR. 2 overhead cams on each bank (1 ea for intake & exhaust) directly open valves with only bucket shims in between.
    It does make for a notoriously noisy valve train tho, but that’s a feature,not necessarily a flaw
    Comataco, vtown and Williston[QUOTED] like this.
  12. Sep 13, 2023 at 3:31 PM
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    I always used dino oil until it became hard to find locally and I switched to a synthetic blend. Engine is definitely noisier, especially for the first several miles after an oil change. How fresh oil makes an engine noisy is beyond me, but in my case, it's a fact. Maybe, just maybe, your full synthetic is causing at least some of what you hear. A different brand of oil might be quieter, or even a switch to a blend.
  13. Sep 13, 2023 at 4:30 PM
    afp98926
    Thanks for all the replies. I'll probably do an oil analysis just to see what shows up if anything. It must just be normal but it honestly drives me crazy! Guess I'm just gonna have to get used to it.
    4WDTrout likes this.
  14. Sep 13, 2023 at 4:36 PM
    Williston
    New England
    Thank you for the clarification: never realized that.... It makes so much noise I just as*umed they were solid lifters. :thumbsup:
  15. Sep 14, 2023 at 5:43 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Trucks fine. They all sound like that.
  16. Mar 19, 2025 at 2:49 AM
    Comataco
    Comataco Well-Known Member
    Jerry
    Nine Mile Falls , WA.
    2013 double cab 4.0 bronze / brown
    nothing much yet , wheels , seat covers , larger tires , tool box
    My first Tacoma trying to get used to the engine noises . Just sold my 2002 Tundra & having regrets ,only had 125K . Everyone says ignore it their loud & after pestering some unknowledgeable shops I'm reading these threads is helping . Still trying to find a good Tacoma shop around Spokane ,WA. if anyone can recommend. Tacoma World is a great source for info ! Thanks Y'all
  17. Mar 19, 2025 at 11:09 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    My 1gr is noisy like shown in the thread when it's cold. Then after warming up, it's super smooth and quieter.
    paulgrim and Comataco like this.
  18. Mar 20, 2025 at 7:21 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    To me that's a combination of normal engine noises and an extra noisy serpentine belt system. I'd pull the belt off and check the idler and tensioner pulleys.
    Comataco and XSplicer62 like this.
  19. Mar 20, 2025 at 9:49 AM
    Comataco
    Jerry
    Good idea ,Thanks. I had it changed last year but I'm sure he never checked the idler & tensioner pulleys. Hard to find a through mechanic anymore , remember when they would go the extra mile & didn't have to be told plus they put the cheapest parts on & cry like a baby if you bring anything with you. I'm pushing 82 & can't crawl around in the new engine compartments ! ha ha
  20. Mar 20, 2025 at 12:57 PM
    ridefreak
    NM
    2006 DCSB TRD
    minor tweaks
    The difference (reduction) in engine noise when I swapped out the pulleys was pretty amazing, I could easily hear the injectors ticking again at idle, I hadn't noticed that sound for a long time. On mine there was a slight amount of play in the pulleys that I took off and I could feel the bearings in them were a little dry, they didn't roll with the slight drag a greased bearing has. They were definitely on their way out but outwardly they weren't critical yet, I could see where a mechanic not looking for worn pulleys might not catch it.
