4.0 L Engine Swaps?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by motogeek, Dec 7, 2017.
  1. Dec 7, 2017 at 7:54 PM
    motogeek
    motogeek [OP] Taco Tueday? Tacos Everyday!
    Tacomeat
    America
    Tacoma SR5 TRD 4x4
    2.5 Toytech Inch Lift 285 Cooper SST
    Hypothetically, how easy would a 2nd Gen engine swap and 2nd Gen trans fit into a 3rd Gen?
    PapaBear likes this.
  2. Dec 7, 2017 at 7:55 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Just get a 2nd gen :facepalm:
  3. Dec 7, 2017 at 7:57 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Should fit perfectly, but wiring may be an issue with all the new systems or whatever. Better to just buy a 2nd gen hypothetically...:goingcrazy:
    freddy2923 likes this.
  4. Dec 7, 2017 at 8:03 PM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    cheaper to get a 2nd gen then swap the bed/fenders/hood and grille.
    Mr-Paul, TireFire, 1bad2k and 2 others like this.
  5. Dec 7, 2017 at 8:03 PM
    Oreo Cat
    Youd be better of buying a 2nd gen and swapping the bed and front end
  6. Dec 7, 2017 at 8:05 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Buy new 3rd gen, buy 2nd gen with bad banged up body, swap 3rd body onto 2nd frame... Profit??
    Anything can be done with enough time and money, that said it probably wouldn't be worth it.
    As for easy hard factor, they're effectively the same platform so fit wouldn't be an issue, it would come down to how the different systems played together.
    You might have to have two completely independent electrical systems, one for all the 3rd gen goodies and the complete 2nd gen system to run the engine and trans.
    Sounds like a wiring nightmare to me.
    :notsure:
    tonered likes this.
  7. Dec 7, 2017 at 8:07 PM
    STexaslovestacos
    STexaslovestacos Well-Known Member
    Sam
    2017 MT TRD OR
    If I wanted to get myself into that much of a wiring nightmare I would put an LS engine in the dang thing.
    Mr-Paul, MOC221_, smuckers and 5 others like this.
  8. Dec 7, 2017 at 8:09 PM
    Hank Heel
    Hank Heel Well-Known Member
    WA
    Prairie Hawk, tonered and Key-Rei like this.
  9. Dec 7, 2017 at 8:18 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    I would have to agree that if I was going go through the trouble that I would go with the Ford 2.7 ecoboost.
    tonered likes this.
  10. Dec 7, 2017 at 8:25 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Jst bore out the 3.5 to 4.0? But seriously.....just push the ECT button and save yourself the grief.
    Key-Rei and CaptainBart45 like this.
  11. Dec 7, 2017 at 8:27 PM
    prohunter4
    prohunter4 Well-Known Member
    South Ga
    2017 BBP TRD Off Road
    Nitrous. Would be fun till it shits the internals out the tail pipe.
    ManBeast and Stocklocker like this.
  12. Dec 7, 2017 at 8:33 PM
    Key-Rei
    Key
    Florida
    Just gap the hell out of the rings, then your problem becomes will it blow the head off from compression?
  13. Dec 7, 2017 at 8:34 PM
    CaptainBart45
    Bart
    Work in progress...
    That low end torque is hard to live without once you've had it. I am still a big fan of the Jeep straight 6. But progress sometimes takes its toll I guess.
    Opihi59, Stocklocker and Dacon like this.
  14. Dec 7, 2017 at 8:34 PM
    prohunter4
    South Ga
    Sounds like fun.
  15. Dec 7, 2017 at 8:36 PM
    prohunter4
    South Ga
    I have a 4.6 stroker in my 83 Scrambler. That thing is a beast.
  16. Dec 7, 2017 at 8:39 PM
    BeaverNation
    BeaverNation Well-Known Member
    Turbos and SC’s on the 3.5 would be a way stronger motor
  17. Dec 7, 2017 at 8:42 PM
    CaptainBart45
    Bart
    Work in progress...
    I had a 94 Cherokee with the 4.0 straight 6. It was only like 180 hp and 230 torque but it felt like a mule.
  18. Dec 7, 2017 at 8:50 PM
    AWDDude
    AWDDude Well-Known Member
    2017 Tacoma TRD Off Road DCSB, QuickSand
    is the second gen 4.0 same as what is currently in the 4runners?
  19. Dec 7, 2017 at 8:54 PM
    Key-Rei
    Key
    Florida
    ... According to Wikipedia, yes it's still a 1GR-FE in the 5th Gen Runner, most likely the twin VVT-i version vs the single VVT-i us tacos have.
  20. Dec 7, 2017 at 9:04 PM
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
    Baby Cummins
