4.0 leaking coolant waterpump
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vacajar, Feb 13, 2011.
  1. Feb 13, 2011 at 5:32 PM
    vacajar
    vacajar [OP] New Member
    06 prerunner sr5
    06 tacoma with the v6 im almost at 60000 miles and went out this morning and found colant leaking down the front of the engine. Is this a known problem or am i just lucky?? also any good links for the removal and repalce of the water pump since that seems to be the coulprit. Thanks for reading
  2. Feb 14, 2011 at 5:49 PM
    nick
    nick MURDERED_TACO
    Green mountain ,nc
    - 2003 trd
    thats the first ive heard of that happening. replacing a water pump is a big job and big money.
  3. Feb 14, 2011 at 5:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Shouldnt be too hard. Just time consuming. Check out.
  4. Feb 14, 2011 at 6:53 PM
    vacajar
    06 prerunner sr5
    thanks for the link i have not pin pointed the leak yet but will try to look for it this weekend when i have time.
  5. Feb 15, 2011 at 5:55 PM
    MushyB
    MushyB Well-Known Member
    MA/CT
    05 Taco TRD Off-Road
    goodluck, keep us posted.
  6. Feb 15, 2011 at 6:34 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    At 60000 miles? Its a bit early, but not unheard of. SO yes, known problem
    Any waterpump you don't have to have a special tool for or remove the radiator is an "easy" water pump to replace. But holy shit with the bolt pattern on that piece. AND 5 bypass hoses...
    Yea. Not hard, but I bet it's a bit of a 3 legged one. Bet there's a lot of "tricks" getting in there and getting room to move etc.
  7. Feb 15, 2011 at 6:54 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Toyota's water pumps normally fail at the seal. Mine went at 30k. Of all the pumps I have replaced, the front wheel drives were the hardest; very little room for your hands. RWD vehicles are much easier.
    Drain, pull belts and hoses, remove fan, replace pump... Reverse. Take your time and have a friend with a running vehicle! Oh yea... and verify you have the right parts BEFORE you start;)
  8. Feb 15, 2011 at 8:00 PM
    hopkins
    hopkins Member
    NS Canada
    05 TRD DC LB
    Jack Rabbit Tonneau Cover 18" BFG A/T on KMC Addicts XD Series TRD Cat Back Grillcraft upper with TRD Emblem
    The waterpump replacement should be covered by powertrain warranty up to 60,000mi or 5 years. If your not over 60k I would check your in service date to see if it's under 5 years. (it is covered in Canada up to 100,000kms or 5 years).
  9. Feb 19, 2011 at 6:22 AM
    vacajar
    06 prerunner sr5
    found out first day of use on my truck was in april so i was still within warranty by the seam of my pants. Waterpump r2 no questions asked. Just another reason why i love toyota..
  10. Feb 19, 2011 at 6:35 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    :D +1 for extended warranty. I can work on my truck, but I'd have to pay for parts, special tools, rental, auto hobby shop..... It was a safe bet for me.
  11. Feb 19, 2011 at 7:13 PM
    mickyd9990
    mickyd9990 Well-Known Member
    marc
    ri
    07 tacoma off road
    I just went thru this at 65000. I bought an oem waterpump but found out it was covered thru my extended plan even tho it was an absolute nightmare and they fucked me hard lol... should have done it myself.. would have been done faster
    But anyway I do have a brand new oem Toyota waterpump ill give ya a deal on lol... dealer wants crazy restock fee.. rather just give someone a deal
  12. Feb 19, 2011 at 7:46 PM
    nick
    nick MURDERED_TACO
    Green mountain ,nc
    - 2003 trd
    hate to see that happen good luck
  13. Feb 19, 2011 at 8:06 PM
    mandzach
    mandzach Well-Known Member
    Very common, had my weep hole start to show the "red crust" at around 53k.
    Anyone reading this who is still under 60k should be checking the water pump often to ensure they catch it as soon as it shows signs of leaking. Just shine a flashlight down under the pumps pulley.
    The replacement job is not hard, just time consuming. Have a torque wrench, couple cans of break cleaner and bunch of patience.
  14. Feb 19, 2011 at 9:15 PM
    island808
    Jedediah
    hawaii
    Lucky you don't have to look for it to know its leaking. Unlike oil, coolant has a strong odor and you smell it immediately.
  15. Feb 19, 2011 at 10:11 PM
    mandzach
    Ya, not so much.
    Look for it and if it has a seal that recently went bad, you will see the red residue. The leaking starts a while later.
  16. Feb 20, 2011 at 7:09 PM
    island808
    Jedediah
    hawaii
    You can't smell antifreeze? I do have a reputation for smelling it "first". But its pretty noticeable.
  17. Feb 20, 2011 at 9:55 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Gotta have a good nose. I can only smell leaky heater cores. Engine bay leaks have to be big for me to smell it.
  18. Feb 20, 2011 at 10:48 PM
    island808
    Jedediah
    hawaii
    I'm always smelling them. Checking my car after following someone down the highway. Must be a smell I'm particularly sensitive to.
  19. Apr 27, 2011 at 7:58 AM
    Watari06V6
    Watari06V6 Faster than a speeding ticket
    Wounded Knee
    TRD-V6-SR5-06
  20. May 15, 2011 at 8:41 PM
    taco084gb
    taco084gb No matter where you go there you are.
    Galen
    NorCal
    I know this is kinda an old thread but just noticed I have the pink antifreeze drunning down the front of the motor. It dont look to fresh since its kinda white in some spots where it might have been there a while. So I assume this water pump needs to be replaced. It looks as though the stuff is coming from behind the fan. So does the drain hole for the water pump drain behind the motor fan. Im not quite sure. Any help would be appreciated. Thanx
