4.0 manual transmission, stalled then wouldn't start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pigpen, Mar 18, 2025.
  1. Apr 26, 2025 at 3:40 PM
    #61
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Replace the relay to rule it out.
    Pigpen[OP] likes this.
  2. Apr 26, 2025 at 4:47 PM
    #62
    Waasheem
    Waasheem
    2007 xrunner
    Ahhaaa!
    Imagine an electrical female socket designed to accommodate a specific size male spade. You shove something in fatter than what’s supposed to be in it. The female opening bends outward to accommodate it. You take it apart & put it back to original. Now the two parts will sorta connect but it’s not a good connection that’s going to provide good continuity 100% of the time.
    To correct this problem you want to fix it so the relay can once again make good contact. I would have to see it to know what I would do. Perhaps depin the female connector. Or try bending it closed slightly in place. If you decide to try messing with it DEFINITELY disconnect the battery first.
    Still I would correct that bad connection on the starter.
    As I’m sure you now know, jam a wire into a connector, twisting & taping, wrapping wire around it are not good ways to get a good connection. Don’t feel bad, I fried a boost controller due to a bad ground connection myself. Live and learn.
    Once I worked on a Chinese machine with about 200 male/female spade connections. No wiring diagram, no manufacturer to call. No replacement parts available. Every female spade was spread open due to vibration, a bunch of males had fallen out, wire colors didn’t match. I was the third person to work on it, got lucky and got everything plugged in correctly. Advised we can make a homemade wiring harness which would probably cost more than they paid for the machine. Or next time it breaks down, throw it away and buy something better.
    Pigpen[QUOTED][OP] likes this.
  3. Apr 26, 2025 at 8:16 PM
    #63
    Pigpen
    Pigpen [OP] My truck is never clean
    Dan
    Northwest Montana
    I'll pick up a new relay. Seems like a good call.
    I also canceled the Denso OEM replacement fuel pump and ordered a URD kit because why not. I've already blown past my maintenance budget for the year, and I'm chipping into build money.
  4. Apr 26, 2025 at 9:56 PM
    #64
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Neither the starter relay or fuel pump could cause a p0335 though.
    The relay is cheap but I'd hold off on the fuel pump, that's more expensive and we havent seen any evidence this is a fuel related issue.
    You just put a crank sensor in it, wait and see if the symptom comes back before throwing more money
    SR-71A and Pigpen[OP] like this.
  5. May 18, 2025 at 6:41 AM
    #65
    Pigpen
    Dan
    Northwest Montana
    Took it for a rip yesterday. Lots of low range, low rpm crawling and a fair number of stalls in the process. Started right up every time!
    I think the crankshaft sensor was the major player in my issues. There's a good chance the starter relay wasn't making full contact too. I haven't replaced the relay. It's peculiar how often issues pop up in pairs.
    Thanks to all of you for your support and advice. TW is such a great community.
    Torspd and b_r_o like this.
