4.0 motor in 3.4
Discussion in '1st Gen. Tacomas (1995-2004)' started by SuperTaRD9904, Dec 17, 2010.
  1. Dec 17, 2010 at 1:26 AM
    SuperTaRD9904
    SuperTaRD9904 [OP] Well-Known Member
    Brandon
    FortWorth
    04 long travel supercharged Taco
    TRD supercharger, +3 control arms, long travel, king coilovers, glassworks unlimited fenders, hood and bedsides, deaver j59 leafs sprung under, custom exhaust out of bedside, kartek bedcage with spare tire carrier, full sound system, completely rebuilt with 17k miles.
    :confused: Well I want to do a motor swap. I want to take out my supercharged 3.4 and swap a newer tacoma 4.0 in it. Is this posible? If so, what will it take to do it? My motor feels like its about to blow up so I want to upgrade.
  2. Dec 17, 2010 at 1:37 AM
    SuperTaRD9904
    Brandon
    FortWorth
    yea im going to do it myself. its a lot easier to just buy a different one and sell my supercharger (only has 17k miles on it) that will cover the cost of my new motor. and will run a lot smoother.
  3. Dec 17, 2010 at 7:30 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Well this has been covered before...
    1) ANYthing is possible with enough time and money
    2) The 1GR-FE puts out about 235hp max. I've read the TRD S/C brings the 5VZ's power from 190 to 265. Why would you spend so much time/money to decrease your power?
    3) Instead, just get a 5VZ with low miles...
    I don't know what it would take, but it is not worth it in any way.
    Hamer95USA likes this.
  4. Dec 17, 2010 at 7:41 AM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    no. dont do it. like stlharry said its not worth it. you will spend alot more money swapping it than just rebuilding your engine your gonna have to change your transmission, the computers, your drive train, some fab work for mounts and its heavier than the 3.4 so you will likely squat the front of your truck some..
  5. Dec 17, 2010 at 7:42 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    let's see it done....you will be the first
  6. Dec 17, 2010 at 7:50 AM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
  7. Dec 17, 2010 at 7:55 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    The 4.0 is faster than a 3.4 SC. We did some...tests up here.
    Besides, then he can SC the 4.0 later. Remember, just cause it makes 265 at the flywheel doesn't mean it's putting that down to the ground.
  8. Dec 17, 2010 at 8:07 AM
    98tacoma27
    Ben
    Not Beech Creek
    HHHmmm................need the engine and trans and ECU and all of the second gen sensors and harness. Need to pull the old stuff out and install the "new" stuff. Probably change the heater/AC out as well, a lot of splicing required inless you swap connectors.........fuel pump swap?.........fab, fab, fab work..........new drive line(s)........yadda yadda yadda
    Not saying it can't be done; like others have said......time + $$$ = :D
    It's just more practical to by a spare 3.4 and rebuild it. Then install when yours finally dumps
  9. Dec 17, 2010 at 10:10 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I thought it has been proven physically impossible for a 3.4 to conk out?
  10. Dec 17, 2010 at 3:31 PM
    SuperTaRD9904
    Brandon
    FortWorth
    Well i know I could sell my motor with the supercharger on it and not have to pay any more for the 4.0 but I didnt know if the tranny and whatnot would bolt on. I did the 5.3 to 6.0 swap on my silverado and it was a direct bolt on. I was hoping this was the same way. If i have to get the 4.0 tranny and whatnot im not going to even bother. Thanks for all your guys help.
  11. Dec 17, 2010 at 3:32 PM
    crf69
    Ohio
    ummm yeah
    dont bother......unless you have money pouring out your ass
  12. Dec 17, 2010 at 3:33 PM
    SuperTaRD9904
    Brandon
    FortWorth
    haha yea i definitely dont. i cant even afford to tune my motor with the s/c. if i could get my s/c and motor tuned id probably keep it.
  13. Dec 17, 2010 at 11:19 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    do a turbo 3.4 get all the power you want.
  14. Dec 17, 2010 at 11:27 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    sweet sig picture... where at?
  15. Dec 17, 2010 at 11:51 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    Yeah, it would take quite a bit of modification to say the least to do the swap. It would definitely not be a 'bolt in' type of deal.
    In the end though, I would bet that your supercharged 3.4 would still feel more punchy then a stock 4.0l in there unless you were to s/c it as well.
  16. Dec 19, 2010 at 3:23 PM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    I was actually doing a 2.4 to a 4.0 swap, if you try your in for a LOT of fab, and also the motor sits VERY high so you will need to modify your hood, you will need an oilpan from an Xrunner to get it to even get close to clearing the steering rack.
    The motor is just plain HUGE, and I decided to go with the LS1 instead, its so much smaller...but sooo much bigger.:D
    But putting the 4.0 can be done, but not worth the work IMO.
    Pabloeeto likes this.
  17. Dec 19, 2010 at 3:28 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Yes, but I've looked at your list of mods and all I can say is: Holy fuck balls.
    Maybe, but having driven the 3.4 and 4.0, the 4.0 is a beast by comparison. Just raw.
  18. Dec 19, 2010 at 5:44 PM
    SuperTaRD9904
    Brandon
    FortWorth
    yea im not going to bother doing the swap. i just want something more meaty thats not all built up. too many problems. just a smooth running powerful motor. and thanks, its back in the hills in moorpark, ca. only the locals know about it because its on private property and you have to drive through their yard to get down there. if they see somebody they dont know they call the cops. luckly we know the owners because i went to school with his son.
  19. Dec 19, 2010 at 6:38 PM
    95.5 taco
    95.5 taco Well-Known Member
    Kyle Osborne
    Cochran GA
    1995.5 Tacoma, 1998 4runner, 2003 Tacoma
    so im guessin thats a no on sellin the sc or the motor?? :(
  20. Dec 19, 2010 at 7:16 PM
    SuperTaRD9904
    Brandon
    FortWorth
    im still selling the s/c.
