4.0 spark on 1,2,3 No spark on 4,5,6 I am losing my mind.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 36tacundra, Feb 28, 2019.
  1. Feb 28, 2019 at 1:39 PM
    36tacundra
    36tacundra [OP] Well-Known Member
    I got toyota with a blown 4.0v6. Number 4 rod had come apart. I put in another 4.0. It has good compression. It has spark on 1,2,3, but not 4,5,6. I can get spark from the all coils on 1,2,3. I have power and ground at all coils. on the coils, I checked for continuity and the other 2 wire's that are not power and ground make there way to the ecm plug. I even got a second ecm with the same problem. I am frustrated. Any help
  2. Feb 28, 2019 at 1:48 PM
    420taco
    420taco Well-Known Member
    Justin
    PA
    PzTank likes this.
  3. Feb 28, 2019 at 6:11 PM
    36tacundra
    I read that the STA fuse will have power when the engine is cranking. It does not. I checked the STA relay and it had burn marks on it. I tried the relay in my DD and it worked.
  4. Feb 28, 2019 at 6:27 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    First thing to do - swap your 1 2 3 coil packs to 4 5 6 (and 456 to 123). See if 456 fire or fail to fire.
  5. Feb 28, 2019 at 6:32 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Are there spark plugs installed in those cylinders?
  6. Feb 28, 2019 at 6:57 PM
    36tacundra
    All the coils work. It seems the STA fuse does not get power when cranking. My dd does.
  7. Feb 28, 2019 at 6:58 PM
    36tacundra
    I put a second set of plug's in it today thinking the other set were fouled.
  8. Mar 1, 2019 at 4:01 AM
    ARB1977
    North Texas
    Cool. Sometimes the easiest things can be missed. Is it working now?
  9. Mar 1, 2019 at 8:56 AM
    36tacundra
    I ended up switching out a vvt-i Cam Camshaft Timing Oil Control Valve to match the the truck. It probably had nothing to do with it. So I had spark at all 6. I put in new plugs, but it only begins to start. The STA 7.5 fuse that should have power during engine cranking does not have power. Immobilizer???, or ignition, I am going into the dash today. I do want to burn this thing to the ground, LOL? I have a second steering column. I guess the idea is now is find out why STA 7.5 has no power.
  10. Mar 2, 2019 at 10:50 AM
    36tacundra
    I think I have to walk away for a while. I have to start over. Engine cranks and seems like it is about to run, then don't. I tried a second ecu, I tested the wires to the coils, checked spark, it has fuel as the spark plugs are wet when pulled, tried a second set of plugs, and I do not know were to begin. Who would have thought an engine swap would have been the easy part.
    Sidney Vicious likes this.
  11. Mar 2, 2019 at 10:54 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Does your truck have an immobilizer on it?
  12. Mar 2, 2019 at 11:02 AM
    36tacundra
    Yes, I didn't change the immobilizer or the key. I tried the paper clip at the obd11 port for 30 min, With no change. IDK would the dealership be my only option?
  13. Mar 2, 2019 at 11:04 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    A couple of points to make. You replaced the engine and the ECU. The VIN and the ECU must match. Your issue may be as simple as resetting the ECU registered VIN.
  14. Mar 2, 2019 at 11:07 AM
    36tacundra
    The ecu is the original now. The engine is the only part that is not original. Does the ecu need resetting when swapping out an engine? Or did the ecu get cleared when taken out.
  15. Mar 2, 2019 at 11:09 AM
    36tacundra
    Maybe if I lift it and put tires on it, it will run then, LOL!!! The days when I do not like working on stuff my self are now here.
  16. Mar 2, 2019 at 11:11 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    The VIN in the ECU, Immobilizer and engine should all match. It wouldn't hurt to get it checked to make sure...
  17. Mar 2, 2019 at 11:20 AM
    BassAckwards
    Im running an ECU in my truck with a UCON that doesnt have a matching VIN. I just had to reset the immobilizer for 30 minutes and then it cranked right up. Did you follow this procedure?
    1. Disconnect battery
    2. Swap new ECU into truck
    3. Paperclip across pins 4 & 13 of 16-pin DLC3 (AKA: OBD2) connector
    4. Reconnect battery
    5. Hook up battery charger
    6. Turn on ignition
    7. Wait 30 minutes (use a timer, has to be at least 30 minutes)
    8. Turn off ignition
    9. Remove jumper from DLC3 connector
    10. Try to start the truck
    bax, Torspd, MolonLabeTaco and 2 others like this.
  18. Mar 2, 2019 at 11:54 AM
    36tacundra
    It won't heart to try one more time!
    BassAckwards[QUOTED] likes this.
  19. Mar 2, 2019 at 11:55 AM
    BassAckwards
    :fingerscrossed:
  20. Mar 2, 2019 at 1:16 PM
    36tacundra
    Nope did not work. Sounds like it fire's then not, fire's then not.
