4.0 Swap into 2.7 shell?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pierce2006V64x4, Aug 14, 2024.
  1. Aug 14, 2024 at 3:32 PM
    Pierce2006V64x4
    Pierce2006V64x4 [OP] Member
    Pierce
    1996 Tacoma 3rz Regular Cab
    12 inch Subwoofer Aftermarket radio
    hey yall, i was wondering if I could get any info from you guys about possibly swaping my 2006 4.0L into a 2006 2.7 rolling shell. I just dont know if the 2.7 5speed manual would bolt up to the 4.0. My 4.0 was auto and was in a double cab, would i be able to also swap the auto transmission into the 2.7 body, the 2.7 is the extended cab. both are 4x4, and both dont have the rear locker
  2. Aug 14, 2024 at 4:07 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    It can be done yes but there's more to it than just the engine and trans, the R155F will not bolt up to the 4.0 so you will need the engine and trans from the donor in addition to at a minimum the engine & transmission harness, shifter, PCM, instrument cluster, and possibly the interior harness among other things.
    Also the 2.7L has 4.10 ratio axles and the 4.0 has 3.73 ratio axles which if your going to oversize tires/wheels may be a plus.
    super_white and GilbertOz like this.
