4.0 Tensioner (pulley only) part #
Discussion in '2nd Gen. Tacomas (2005-2015)' started by devkurf, Jan 18, 2020.
  1. Jan 18, 2020 at 12:35 PM
    devkurf
    devkurf [OP] Member at Large
    midwest
    Has anyone just replaced the pulley on the Serpentine belt tensioner? Is one of the idler pulleys a direct bolt on?
  2. Jan 18, 2020 at 12:39 PM
    Bubbarut
    Bubbarut Well-Known Member
    2011 Super White Access Cab V6 4x4 6SPD Manual
    You have to buy the whole assembly. You can’t buy just the pulley. You can however replace the bearing in the pulley as long as the pulley itself is in good shape. I ordered a 5203-2RS bearing just last week and replaced mine.
    devkurf[OP] likes this.
  3. Jan 18, 2020 at 12:41 PM
    devkurf
    midwest
    @Bubbarut Where did you get the bearing from?
  4. Jan 18, 2020 at 3:32 PM
    Bubbarut
    I ordered it from one of our vendors at work. I’m pretty sure you can order them from Amazon.
    bearing distributors inc was the name of the place I ordered mine.
  5. Jan 18, 2020 at 4:05 PM
    TacoTuesday1
    FL
    How hard it is to replace the entire tensioner vs. just the pulley bearing?
  6. Jan 18, 2020 at 4:54 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
