4.0 Throttle body
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06stex, Mar 29, 2010.
  1. Mar 29, 2010 at 9:28 PM
    06stex
    06stex [OP] Well-Known Member
    Alex
    Corpus Christi, Texas 361
    06' TRD 6" Fabtech..limo tint
    6 inch Fabtech, Dirt Logic 2.5 coilovers, Light Racing UCAs 17x9 XD spy, 305 65 17 Extreme ATs, Limo all around, Kicker speakers,Kicker L5 10 inch sub, 400 watt kicker mono amp In dash Pioneer with Ipod cable, Flowmaster 50, bedmat, toolbox, K N Filter, cheapo seat covers, 6000k HIDs upfront, bhlm,DDM 5000K fogs, tailgate mod, and many more to come.
    So Tw my 2006 tacoma has 65,000 miles and i just replaced the second set of spark plugs at 60,000 miles.
    So here is what i did for Sunday, went to the auto parts store and bought some non chlorinated brake cleaner and a really good throttle body cleaner.
    First removed engine cover and removed 2 bolts holding air cleaner assembly and throttle by wire plug.
    Next i removed the air flow sensor and cleaned it carefully with the non chlorinated brake cleaner and let it air dry on my kitchen table while i performed the next small service.
    Ok, so here i removed the 4 bolts that hold the throttle body to the intake manifold so i could clean on both sides of the butterfly flap.
    Let me tell you after 65,000 miles and a throttle body that has never been cleaned, man o man was the throttle body and intake dirty from air fuel mixture.
    So next i cleaned the throttle body as perfect as i could with a clean rag and some throttle body cleaner. Keep in mind i cleaned both sides of the butterfly, something you cant do with the throttle body mounted. Then i got another rag and sprayed throttle cleaner directly on it and cleaned the inside of the intake the very best i could as far as my big hand would allow me too.
    Finally i reassembled everything the same way it came apart.
    TW keep in mind that i just replaced the plugs and oh my gosh i never realized how much power was lost with a dirty throttle body and probably gas mileage.
    My uncle who owns a shop told me to do this and oh my goodness what a difference it made. Made my engine feel somewhat new again!!!
    Simple service that can be done in about 20 minutes and makes a huge difference oh and if you do this be really careful with the air flow sensor( it costs a lot), and make sure to disconnect the positive battery terminal to kinda reset the computer and allow for adjustment.
    Just some simple thought, try this and your truck should run a lot smoother and have some more pep or throttle response. Thanks Alex
  2. Mar 29, 2010 at 9:49 PM
    nuckinfuts
    nuckinfuts NyQuil on the rocks.
    Pacific NW
    '06 AC TRD Off-Road
    DT Long Tube Headers, Empire O2 simulator, catback, Shrockworks Sliders, Old Man Emu 3" lift with 885 coils (with 1/2" top plate spacer and Dakar Leaf packs), Hi-lift mounted in bed with 4XRAC mounts, WT floor liners, other stuffs
    Where's the pics? I need to do this, just turned 77k and I'm sure it's a bit dirty. It helped a ton on my old car with 300k+ miles.
  3. Mar 29, 2010 at 9:55 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    im totally doing this
  4. Mar 29, 2010 at 10:34 PM
    NewMexiTaco
    NewMexiTaco Abron Cabron
    Abraham
    Santa Fe, NM
    2007 4x4 DC LB TRD Sport
    Weathertech mats; Wet Okole seat covers; Kobalt Lowpro truck box,(sitting in the shed) Snugtop Hi-liner camper shell; AFE Pro Dry air filter, Tailgate Hoseclamp mod; 5100s all around, Light Racing UCAs, OME 885 coils, OME Dakar Leafs, CB Drop, Driveline spacer. Epoxy Satoshi; Redline Hood Struts. 4x Mil Spec. bed D rings; Brute Force Fab custom DCLB Hybrid Sliders, ARB w/ Warn M8000 wench, Diff Breather mod, Alpine Deck w/ ipod cable. Iphone ziptie to rearview mirror 4wd-cam mod!
    Nice...+1. Helpin us learn some shite! Thanks! Too soon At 46,xxx ?
  5. Mar 29, 2010 at 10:37 PM
    memario1214
    memario1214 Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    Photos please! I wouldn't know wtf was up if I started rootin around in there...
  6. Mar 29, 2010 at 10:47 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Eh, maybe. It wouldnt hurt either way and it gives you time to spend with your truck. So I would lol. And yes, if any photos were taken post them!
  7. Mar 30, 2010 at 12:42 AM
    JKD
    JKD Well-Known Member
    I'm sure it was dirty, probably mostly from the PCV/MUA system, but no fuel passes the throttle body--only air and anything coming from the PCV/MUA.
  8. Mar 30, 2010 at 1:24 AM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    I cleaned my throttle body about 35,000 miles ago. It did make a huge difference in the power. Took it for a test drive & was spinning the wheels on take off.
    I need to clean it again. It has been lagging a bit. Was planning on cleaning it this week, since we will have 80 degree weather.
    I didn't remove mine as the op did. And probably won't.
  9. Mar 30, 2010 at 1:27 AM
    genxer36
    Sean
    Bethlehem,GA
    DO NOT WIPE THE MAF sensor wires, for anyone planning on cleaning it. The sensor wires are thin & can easily break. Just spray it with MAF cleaner & let it dry.
    Or you will be out a few hundred for a new MAF.
  10. Mar 30, 2010 at 1:37 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    Did you replace the throttle body gasket? Or use the same one?
  11. Mar 30, 2010 at 2:56 AM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    x2?
  12. Mar 30, 2010 at 3:16 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    I had my throttle body off on Sunday to make some changes, the oem setup on my 2010 uses a preformed packing similar to an "O"ring. Didn't remove that from the throttle body mounting flange but assume you could.
    So basically no gasket, more of a rubber seal.
    PK
  13. Mar 30, 2010 at 7:48 AM
    aces2
    aces2 Senior Arshole
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    Flowmaster 40, K&N CAI, RED brake light bulbs, BHLM, Rear dif breather line, Factory Skidplate painted BLACK, DRL's, YELLOW bulbs in Fogs Turn Signals and Marker lights, Custom "Toy Machine" center emblem, Sockmonkey "Nor-Cal" decals all BLACK, Redline tailgate damper and hood sruts, Painted steering wheel emblem BLACK, 12V always on, Foglight mod, 16" Pro-Comp 7089 rims BLACK powdercoated acorn lugnuts, BFG KM2's 285-75-16, Painted exhaust pipe BLACK, BLACK emblems all the way around, Rear BLACK bumper from base model, Radical RED "sport" grille-surround, Factory Toyota Bed extender, RED maglight mounted on each seat's side, TRD ball-type shift knob, Custom mounted Scangauge II under stereo, Aftermarket HU, Hardwired Garmin GPS 260W, TSB w/AAL and 2.5" 5100's, Weathertech floor liners, Removed front mud flaps, 95-04 "4WD" rear mudflaps, 3rd Brake light "TACO", BLACK front lip
    Negative battery cable... not pos
  14. Mar 30, 2010 at 8:04 AM
    OCTaco
    OCTaco Well-Known Member
    OC
    '16 TRD Sport DCSB
    PIC'S please. Also, maybe a little better description of where the parts are located, and what to look out for. Thanks, my throttle response has really been off, im wondering how much this actually helped for that? Also, would using seafoam do the same thing?
  15. Mar 30, 2010 at 12:49 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    If your talking about seafoaming your engine, then no, it will not clean the throttle body. But I have heard of people useing some type of seafoam spray to clean it out...
  16. Mar 30, 2010 at 12:57 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    X12 brazillian
    ALSO, USE ONLY MAF CLEANER OR ELECTRONIC CONTACT CLEANER ON THE MAF.
  17. Mar 30, 2010 at 2:00 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    Can anyone be a little clearer about what exactly to do. His explanation was a little vague, especially for first timers like me.
  18. Mar 30, 2010 at 2:37 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    ^ aw c'mon, they are a step by step, he even included how many bolts you have to remove!!
    pics would help, but not needed to get the job done.
  19. Mar 30, 2010 at 6:55 PM
    06aztaco
    06aztaco Screw you guys, I'm going home.
    Cole
    Phx AZ
    06 Prerunner 2.7
    Someone should do this and post before and after pictures. I could possibly do it this weekend, but not betting on it.
  20. Mar 30, 2010 at 10:51 PM
    genxer36
    Sean
    Bethlehem,GA
    I have pictures, but haven't had a chance to post them. Just for the basic cleaning. Not removing the throttle body.
