4.0 Tick
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stautert, Aug 9, 2020.
  1. Aug 9, 2020 at 3:24 PM
    Stautert
    Stautert [OP] New Member
    Tanner
    2012 Tacoma TRD Sport 4X4
    Bilstein 5100s
    I know all 4.0s tick. My 4Runner ticked but it was not nearly as loud as my Tacoma. Is anyone else’s this loud? It’s really starting to drive me crazy. Seems abnormally loud. It’s a 2012 with 152,000 miles
  2. Aug 9, 2020 at 3:27 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Does it need oil between oil changes? Any trouble with engine temps? Coolant leak?
    they’re loud little engines. Mine has ticked since I bought it 10 yrs ago. It now whines but that’s another self inflicted problem.
  3. Aug 9, 2020 at 4:04 PM
    Stautert
    Tanner
    Bilstein 5100s
    I’ve only had the truck for a month. So far it does not need oil. I’m thinking the previous owner used a light oil
  4. Aug 9, 2020 at 4:54 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    See oil cap 5w-30 and use a good filter. I use Mobile 1 syn oil and filter.
    You have many options and opinions out there.
    CNCPro and henryp like this.
  5. Aug 10, 2020 at 5:05 AM
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    Injectors and the valves. Nothing to worry about. If you are overly concerned drain the oil into a sample bottle and send it to a lab for analysis.
    SR-71A likes this.
  6. Aug 10, 2020 at 8:11 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    FYI 4 runners have more sound deadening in and out of the vehicle.
    henryp likes this.
  7. Aug 10, 2020 at 4:38 PM
    BS1
    BS1 Member
    09 tacoma dbl cab
    Just the injectors and valves. I have an 09 142000 on It and has had the same tick since i bought it 9 years ago with 23000 at first the dealer was telling me it was the gas etc but its just these 4.0 are like that and never had any problems but the damn tick and you will get used to it lol
  8. Aug 10, 2020 at 5:26 PM
    grizquad
    grizquad Well-Known Member
    Massachusetts
    12 Tacoma TRD sport
    Plasmaglow Firestorm lights, Westin Bull bar, Flyzeye interior console lights
    May be my imagination but my 12 just had the air pump/and valve switches done on the recall and the tic sounds softer to me.
