4.0 Timing chain replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JohnQ public, Jun 28, 2017.
  1. Jun 28, 2017 at 1:47 PM
    JohnQ public
    JohnQ public [OP] Member
    Corpus Christi, TX
    09 Taco Prerunner 4.0
    Yeah I'm curious myself. I did everything I could to try and locate the broken piece, long magnet, a wire and a good spot light. I was even considering to bring home a micro boroscope to try and find it. I did a thorough inspection of the area to see signs of damage from the piece coming off but no dings or smeared metal anywhere. As much as I hate working under the truck I would have peace of mind to pull the oil pans and find it.
  2. Jun 28, 2017 at 2:28 PM
    j8food
    j8food Well-Known Member
    Jay
    2009 Tacoma TRD Off Road
    After two Galant VR4's and three motors, I wouldn't put any DSM part near my tacoma. Those half moons are notorious for leaking.
  3. Jun 28, 2017 at 2:39 PM
    JohnQ public
    Corpus Christi, TX
    I don't like the idea of cutting away material especially when oil is on the otherside.
  4. Jun 28, 2017 at 2:40 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    While you have your truck apart make sure to seal the hell out of the timing chain cover when you put it back on. There is a major issue with them leaking
    hresendiz25 likes this.
  5. Jun 28, 2017 at 2:52 PM
    JohnQ public
    Corpus Christi, TX
    Yes sir, I have extensive experience in trying to seal toyota engines.
  6. Jun 28, 2017 at 2:58 PM
    10MGM
    10MGM Well-Known Member
    2010 AC MGM 4x4
    I haven't been inside a 4.0, but is it not possible to elevate the cam to remove bolt?
  7. Jun 28, 2017 at 3:20 PM
    JohnQ public
    Corpus Christi, TX
    I thought about that myself and that was my original plan. The thing that I'm worried about is the chain slipping a few teeth and causing me to remove the cover anyways.
  8. Jun 28, 2017 at 5:12 PM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
  9. Jun 28, 2017 at 9:38 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I have rebuilt many 1GR's. I have seen only 1 member or individual possess the ability to remove the intake cam gear without having to remove the timing cover. 1. It was not I. That is a tricky dance.
    You do not have to remove the oil pan. You MUST remove the two studs near the bottom and silicone the mating surfaces between timing cover to oil pan well. As well as replace that oil pan o-ring. Well every o-ring that you find when you remove the timing cover.
  10. Jun 28, 2017 at 9:44 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You should be able to find it with just removing the lower oil pan. Such a strange problem. 1st time seeing this one.
  11. Jun 28, 2017 at 9:46 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The words roll off the fingers effortlessly. Antonym to that task.
    Dragons Taco likes this.
  12. Jun 28, 2017 at 9:51 PM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    T-Shirt.
    :hattip:
  13. Jun 29, 2017 at 7:16 AM
    JohnQ public
    Corpus Christi, TX
    Thank you Torspd!
    I know the service manuals always say remove everything and are written as if the engine is on a stand out bench.
    Torspd likes this.
  14. Jun 29, 2017 at 8:49 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    At 225,000 miles why not just put a brand new long block in.
    Bebop likes this.
  15. Jun 29, 2017 at 9:21 AM
    #35
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Brand new, brand new refurbished, or low mileage used?
  16. Jun 29, 2017 at 9:22 AM
    #36
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Don't buy a long block from advanced auto parts. I've had 4 bad ones from them out of 5
    Shelf Life likes this.
  17. Jun 29, 2017 at 7:03 PM
    #37
    JohnQ public
    Corpus Christi, TX
    Not in my budget. This Tacoma still has a strong engine with good compression in all 6 cylinders and good oil pressure. I just need to fix the cam gear so I can get rid of the codes and the engine sputtering when the computer tries to adjust. Still getting over 18 MPG in the city. Motor still has life in it.
  18. Jun 30, 2017 at 4:22 AM
    #38
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    How the heck did that piece come off? Or did I miss that already?
  19. Sep 26, 2017 at 5:06 PM
    #39
    N/Es06
    N/Es06 Well-Known Member
    06 icons inchworm rotrex
    I've been having issues with my 06 throwing misfire codes and occasionally actually fisfireing. Is that the "sputter" your referring to? Since it has the stage 1 mk3 s/c from URD I as well about to open her up to make sure they installed the cam gears correctly. What are you experiencing specifically with your truck to suggest a timing issue. My truck is about 15% rich on bank 1 and throws code p300, ocasionaly p306, obdll and another once for timing.
  20. Sep 26, 2017 at 7:53 PM
    #40
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Have you contacted tech support at urd?
