4.0 V5 MANUAL taco owners, Need towing info.
Discussion in 'Towing' started by WheelinJ91, Dec 14, 2011.
  1. Dec 14, 2011 at 1:17 PM
    WheelinJ91
    WheelinJ91 [OP] Well-Known Member
    Edmonton,AB
    2012 TRD DCSB
    Airaid Intake, MBRP Exhaust, Toytec OME 3" lift w/AAL, Flip-kit, LR UCA's, Weathertech Floor mats, hood and window deflectors.
    Hi Everyone,
    So i have a 2012 TRD DCSB 4.0 V6 Manual w/ Tow package
    My question is, How much can you pull (i know the factory rateing), and was this on flat or in mountains (up and down hill), conditions, and your set up like trailer break, lift, tire size.
    i plan on getting an enclosed 8'x12' to haul the bike around and be able to use it for hauling other stuff aswell, i have herd that with a taco it would be best to go with a V nose and i think due to that i will be pulling somthing (big) i may just get a trailer break
    Ideas and oppinions, thanks
  2. Dec 14, 2011 at 2:31 PM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    You should have a trailer brake to be safe.
    You might also want to beef up your rear suspension. There are several ways to do this, I added Firestone Ride-Rite air bags to the rear axle and an air compressor under the hood with a controller and air gauge under the dash. This is a slick system as I can adjust the air pressure in the springs at any time stopped or driving down the road. Depending on how much stuff you have in that trailer, the rear end of your truck will sag and your headlights will blind oncoming traffic if you don't do something to level out your truck. Of course your truck will handle better and be safer this way too. You can also add heavier springs or spring boosters but they could give you a stiff ride when you are not loaded or towing.
    You should also consider towing mirrors too.
    Lots of good info in the towing bible stickey thread.
    I would suggest trying to keep your loaded trailer weight under 4000 lbs to be able to climb hills, keep highway speed up without getting completely horrible fuel mileage (its going to suck hauling a trailer anyway), and to be able to stop safely. My Taco is rated to haul 6500 lbs but thats a lot for it to handle for anything but short little hauls.
    Oh, and your title is funny, a V5?
  3. Dec 14, 2011 at 4:18 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    And 8'x12' enclosed!? Dam that is a big ass trailer for a taco!
  4. Dec 14, 2011 at 4:56 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    My camper is 8X18 no problems with that just don't fill the cargo trailer with bricks.
  5. Dec 14, 2011 at 5:06 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    What the hell is a V5? :rolleyes:
  6. Dec 15, 2011 at 9:40 AM
    WheelinJ91
    Edmonton,AB
    2012 TRD DCSB
    Yeah i was thinking of Airbags, i gotta look into them when the time comes =.
    not really i have a 8x12 flat tilt) deck right now and it is a little wide but i had no problems with my old explorer when it was loaded and that suv cant pull worth shit other then its auto
    It's when the and i quote "4.0" has one cylinder blows....-.- but yeah i didn't even know i did that until you guys pointed it out, and i don't think i can fix it
  7. Dec 15, 2011 at 10:20 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    i hauled a 8x12 uhaul trailer from ga to va and didnt have any issue. it was full with furniture and all my other crap from when i moved
  8. Dec 15, 2011 at 11:51 AM
    Goober
    Goober Earthlings are fun to watch!
    Utah - Why just have only one?
    '11 TRD Off-Planet AccessCab
    Altitude affects cooling capacity and my Ridgeline manual stated to reduce the tow capacity by 3% for every 1000ft. of altidude, unless you were towing a boat. (it really said that) I could only assume because a boat would have less wind resistance. Read the manual which has guidelines for brakes and hitch usage. Toyota supposedly meets the 2012 SAE tow ratings, read those for details on towing conditions under which the guidelines are met. http://www.tacomaworld.com/forum/towing/139258-new-tow-ratings-2013-s-e-j2807.html
  9. Dec 15, 2011 at 7:07 PM
    WheelinJ91
    Edmonton,AB
    2012 TRD DCSB
    How about with lifts on them ? will the reduce the towing cap?
  10. Dec 15, 2011 at 7:13 PM
    BARTRD
    BARTRD Well-Known Member
    Brian
    Monroe, Ga
    '07 RR TRD Sport
    Volant CAI with optional skoop, Magna-Flow exhaust, K&N drop-in air filter, WeatherTechs, Wet Okole, kenwood navigation head unit, de-badged, 15% tint all around, factory roof rack fitted with Thule fairing, billy 5100 on all 4 corners, ICON AAL, n-fab light bar with 4 hella 500s, rear lights mounted under bumper
    my friend uses 4.0 V6 to pull her EVO on a car hauler trailer with no problem
  11. Dec 27, 2011 at 7:30 AM
    fajitas21
    fajitas21 XMF - Extreme Mexican Food fo Life!
    Lee
    Collierville, TN
    4Runnerzzz
    Originally not Expo AF! Kinda Expo AF now...lame.
    A lift will increase wind resistance and raiser center of gravity. Might affect power some and stability alot.
    That said, I've towed a 6x12 V6 Tacoma like a champ. The extra width on the 8x12 is gonna make for more wind resistance, and as long as you don't have the trailer loaded to the brim it should be ok.
    Keep an eye on the tongue weight, but you should be ok. Make sure your trailer brakes are good and working properly.
  12. Dec 28, 2011 at 1:44 PM
    WheelinJ91
    Edmonton,AB
    2012 TRD DCSB
    So when going for a lift basically keep in mind everything else i will be doing with the truck before making a decision, i think for now im going to be carting the bikes around in the box of the truck so just a lift big enough to fit 33s on it which should allow me to still use a ramp
  13. Dec 28, 2011 at 1:53 PM
    97T
    97T Resident T100 guy
    Melt
    Littleton, CO
    97 T100 xcab 5spd 2wd
    soundstream 550.2 amp, 2 eclipse 10" subs, 4% tint rear window, 20% sides, 6" sunstrip, clear bumper lenses, avital 4103 alarm with keyless, BF Goodrich Rugged Terrain T/A 235/75/15, 15X7 6-5.5 0C Unique 298 rims
    3.4 owner chiming in .... biggest ive towed is a 94 acura integra on a dolly with the bed of the truck filled with shit .... the bumper says the trucks rated to 5000 lbs but not sure if i believe that
  14. Dec 28, 2011 at 2:12 PM
    WheelinJ91
    Edmonton,AB
    2012 TRD DCSB
    How did that go for you? like safety, did you feel safe about it? was it a good or bad experience?
  15. Dec 28, 2011 at 2:21 PM
    97T
    Melt
    Littleton, CO
    towed it from napa cal to portland oregon, no complaints and ca and or have a 55 mph speed limit while towing .... i was also suprised as hell that i got 17 mpg doing it (truck gets anywhere between 20 and 22 unloaded)
  16. Dec 28, 2011 at 4:10 PM
    WheelinJ91
    Edmonton,AB
    2012 TRD DCSB
    Thats good for towing on a small engine.
  17. Dec 28, 2011 at 4:13 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Only thing I've ever towed is my boat which is a little over 2000lbs boat/motor/trailer. But hey it handles that without breaking a sweat. If I had to tow anything close to the rating I'd probably just get a full size truck.
  18. Nov 8, 2012 at 11:49 PM
    aCab
    aCab Active Member
    would love more info on this
  19. Nov 9, 2012 at 5:58 AM
    BARTRD
    Brian
    Monroe, Ga
    '07 RR TRD Sport
    Her truck is a TRD sport. 2 wd. Double cab. She has an EVO for a track car and a big ass trailer to haul it on. Gas mileage sucks I'm sure, but she still pulls it
