4.0 V6 conventional to synthetic oil change at 150k miles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 23MGM, Jul 27, 2025.
  1. Jul 30, 2025 at 10:36 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The concerns about introducing leaks by switching to synthetic are a hold-over from back when cars had much simpler seal designs. Like rope crankshaft seals and cork gaskets.
    Those days are long gone
    4x4spiegel and 23MGM[OP] like this.
  2. Jul 30, 2025 at 11:09 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I don't understand why they still make conventional oil. No reason to ever use it and it won't hurt to change now.
  3. Jul 30, 2025 at 11:35 AM
    Owenhall
    Owenhall Well-Known Member
    Owen
    2009 Toyota Tacoma 4x4
    Lift 33s
    I run it in my diesel f250 7.3 witch takes like 4 gallons of oil conventional is recommended.
  4. Jul 30, 2025 at 4:35 PM
    Marshall R
    Marshall
    none
    That engine is 20+ years old. The recommendation for conventional oil is also 20+ years old. It won't hurt a thing to use synthetic in it. 4 gallons is a lot, but while synthetic costs more, it lasts longer and protects better. Overall cost ends up about the same.
    One of my wife's brother has a 1999 with about 300,000 miles on that engine. He switched to synthetic years ago.
  5. Jul 30, 2025 at 7:05 PM
    truckmike26
    truckmike26 New Member (2009)
    Toronto
    '21 DC TRD Off-Road, '94 Pickup (Hilux) V6/Auto 4WD
    Conventional oil is better if you do a lot of nighttime driving.
    4x4spiegel and b_r_o like this.
  6. Jul 30, 2025 at 7:30 PM
    Owenhall
    Owen
    Lift 33s
    Not saying it will hurt it to go senthetic just haven’t switched.
    b_r_o likes this.
  7. Jul 30, 2025 at 8:13 PM
    wdunnlee
    wdunnlee Well-Known Member
    Will
    Tidewater VA
    2010 Timberland Mica 4x4
    Would y’all suggest OP runs a couple cycles of valvoline RaP?
    I got my truck at 140k, 2 oil changes so far both done by me, full synthetic high mileage.
    Previous owner just would get the cheap stuff at jiffy lube. Would I (or OP) be opening a can of worms by running some of that? I wouldn’t mind spending the money maybe do a 500 change (filter and oil) then 1k then 2.5k then back to 5 k. Apparently that stuff frees up a bunch of gunk so oil filters won’t last the whole 5k.
    I’m so tempted :burnrubber:
  8. Jul 30, 2025 at 8:22 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Opening a can or worms? No.
    Wasting money? Probably.
    I don't recommended fixing problems that don't yet exist.
    If you aren't burning oil, I'd just continues to do regular oil changes.
    By all means, Do it if you want.
    It's not going to hurt anything. But will it help anything is the question?
    FWIW, I have a friend that runs a local service shop.
    He has used Valvoline Restore & Protect on a few customers cars.
    He said Honda and Subaru seem to be the ones that respond better.
    4x4spiegel likes this.
  9. Jul 30, 2025 at 8:27 PM
    wdunnlee
    Will
    Tidewater VA
    So your saying I need a car that is less reliable :rolleyes:
    I’ll probably do it becaude once I discovered it, and confirmed there is no downsides, I no longer have a reason not to.
    Besides I enjoy stuff like that, if it makes my car better and clears a ton out, great! If nothing happens, I can still lie to myself :rofl:
    TnShooter[QUOTED] likes this.
  10. Jul 30, 2025 at 8:36 PM
    TnShooter
    Deogee
    STOCK
    Nothing wrong with that...
    I too lie to myself. Mostly to convince myself "I can do that tomorrow"....
    I'm a master at procrastination.....:eek:
    wdunnlee[QUOTED] likes this.
  11. Jul 30, 2025 at 8:36 PM
    23MGM
    23MGM [OP] Well-Known Member
    2023 TRD Off Road
    That’s exactly what I thought. When my dad said he used conventional, I asked where the F do you find that? At a tractor supply store or you dig it out of the ground or something? Did you buy a 50 gallon drum in 1985 and you’re still using it up?
  12. Jul 30, 2025 at 8:42 PM
    TnShooter
    Deogee
    STOCK
    Almost all the 5w-30 I've seen was at least a synthetic blend.
    Even the Wal-mart stuff.
    Only Conventional I've found was straight weight. Like SAE 30.
    Then again, I haven't looked too hard. I'm not an oil snob.
    If it looks like oil, feels like oil, and smells like oil. It's oil to me.
    4x4spiegel and 23MGM[QUOTED][OP] like this.
  13. Jul 30, 2025 at 8:59 PM
    Owenhall
    Owen
    Lift 33s
    I’m trying the restore and protect will see if it actually works it’s not anymore expensive than what I was using before so I’m trying it.
    TnShooter likes this.
  14. Jul 30, 2025 at 9:20 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Conventional still exists to some degree but only in the more true to base stock viscosities. Such as 5W-20, 10W-30, 10W-40, 20W-50, etc. You can switch to synthetic and it will be fine, or you can run conventional and it will also be fine. While synthetic is touted as ‘better’, I have yet to see a single convincing argument that actually proves it does anything to help an engine last longer term. We didn’t have engine problems before synthetic came along that synthetic solved. The wear spot on project farm videos don’t count - those don’t prove anything useful. You can switch all day long, just don’t think it’s going to provide any measurable pros or cons either way.
  15. Jul 30, 2025 at 10:31 PM
    #35
    truckmike26
    Toronto
    Also, conventional oil doesn't contribute to reverse hysteresis in your MAF sensor.
    4x4spiegel, Sprig and b_r_o like this.
  16. Jul 30, 2025 at 10:41 PM
    #36
    TnShooter
    Deogee
    STOCK
    :confused::boom::smash:
    truckmike26[QUOTED] likes this.
  17. Jul 30, 2025 at 10:42 PM
    #37
    BadAndy10
    BadAndy10 Well-Known Member
    the 541
    '10 DC TRD OR
    Fox 2.5" extended travel coilovers, SPC UCA's, Wheeler's AAL & 5100's, Relentless front plate bumper, SCS F5's w/285's, Superbumps
    Lol... there are a lot of old pushrod V8's still running around that are better off running conventional vs. synthetic.
    BLtheP likes this.
  18. Jul 31, 2025 at 7:49 AM
    #38
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    And it smooths out the pulsations across the coolant temp sensor, resulting in better fuel calculation at startup
  19. Jul 31, 2025 at 9:35 AM
    #39
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [ED] Entune Audio+ [TO] V6 Tow Package
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    For the OP's truck, it started life with 3,000 mile oil changes. I wouldn't use any "clean out" additives nor any "high mileage", "stop leak" synthetic oil or anything else. Pick a name brand like Synthetic Mobil1, Castrol, or Valvoline in the recommended viscosity and an OEM oil filter for $5.50 and stop chasing Phantoms with 500/1,000,/2,500 oil and filter changes, additives or STP oil treatment if you can still find it.
    23MGM[OP] likes this.
  20. Jul 31, 2025 at 11:41 AM
    #40
    wdunnlee
    Will
    Tidewater VA
    Who’s gonna stop me :jerkoff:
    Edit: maybe I’ll do all at once, valvoline RaP, additives and short oil changes :quickdraw:
