4.0 V6 Differences
Discussion in '2nd Gen. Tacomas (2005-2015)' started by coolreed, Aug 11, 2010.
  1. Aug 11, 2010 at 12:21 PM
    coolreed
    coolreed [OP] Well-Known Member
    Reed
    OKC
    2019 Toyota Tacoma TRD Pro
    Goodyear Wrangler Dura Track Pro Tires, K&N Cold Air Intake, Pedal Commander.
    I noticed the Horsepower Differences in the 4 Liter V-6 Toyota engines. I saw 235 HP in my 06 Tacoma and 265 HP in another Toyota 4WD FJ and now I hear there is a 270 HP 4.0 V6 coming out.
    I wonder what exactly is the difference in the engines that give a higher HP rating. I may want some of that. :cool:
  2. Aug 11, 2010 at 12:34 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    I think dual VVT-i
  3. Aug 11, 2010 at 2:35 PM
    bagster
    bagster Well-Known Member
    I wonder what the difference in gas mileage will be?
  4. Aug 11, 2010 at 3:15 PM
    JKD
    JKD Well-Known Member
    Look up a 2005 Tacoma 4.0. ;)
  5. Aug 11, 2010 at 3:19 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    The new 4 Runner 4.0 is rated at 17 city 22 highway. Those are the same numbers as my 2008 2.7L Tacoma.
  6. Aug 11, 2010 at 3:25 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    They are 245hp and I think it's because they are rated with premium gas as that's what's required/suggested. I think that the later ones are rated with 87 gas and that's why they are less. I believe that the newer one would have the same power if premium is used. This is they theory I believe.
  7. Aug 11, 2010 at 3:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    THey changed the way the reading were taken. Nothing is different between an 05' 4.0, and an '10 4.0, hp wise.
  8. Aug 11, 2010 at 3:38 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    A few things of note.
    1. The FJ Cruiser's current 260 hp / 271 lb-ft rating is on 91 octane, while the Taco's 236 hp / 266 lb-ft rating is on 87 octane. Put 91 octane and the ECU will advance ignition timing and achieve 239 hp / 278 lb-ft. So the Taco puts out more torque.
    2. There was a change in SAE hp testing method in 2005 that caused a small drop in hp ratings across the board. If you find a 2005 Taco brochure, it may claim higher hp than the 2011 Taco.
  9. Aug 11, 2010 at 3:48 PM
    KenLyns
    Belly of the Beast
    I read it here:
    http://en.wikipedia.org/wiki/Toyota_GR_engine#1GR-FE
    Obviously not all engines automatically produce more power with premium fuel. The Taco's ECU is supposed to recognize premium fuel and adjust timings accordingly. Whether you can feel that extra bit of power by seat of the pants is debatable. I think dyno runs would be needed.
  10. Aug 11, 2010 at 3:57 PM
    myname150
    myname150 Well-Known Member
    Im pretty sure the 270HP is due to the addition of Dual VVT-i.
    Currently the tacoma doesnt have that, and i think the FJ doesnt have it either. Only the new 4Runner.
  11. Aug 11, 2010 at 4:15 PM
    KenLyns
    Belly of the Beast
    12 lb-ft is less than 5%. I don't think its noticeable by feel even if you ride two trucks back-to-back in identical temperature / wind / altitude.
  12. Aug 11, 2010 at 4:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The FJ was tested on 87 octain fuel. Its also a dual VVT-i engine.
  13. Aug 11, 2010 at 4:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    My manual states exactly that. "FOr best performance, use 91 oct. fuel".
  14. Aug 11, 2010 at 4:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Could be. I noticed a godd difference when testing different grades of fuel.
  15. Aug 11, 2010 at 4:25 PM
    Tobogan9610
    Tobogan9610 Member
    California
    TRD Off Road
    5% is a noticeable improvement
  16. Aug 11, 2010 at 4:29 PM
    Tobogan9610
    Tobogan9610 Member
    California
    TRD Off Road
    Wikipedia is not a reliable source.
    You have to look at the proof of where the information comes from. At the end of any information that is put on Wiki you need to look for the footnote and then go to that information to find out if it is bunk or not. If there is no footnote (proof of information) then the info is most likely bunk.
  17. Aug 11, 2010 at 4:34 PM
    Tobogan9610
    Tobogan9610 Member
    California
    TRD Off Road
    It is not reasonable for the horsepower to go up 3 and the torque to go up 12 without some change in the exhaust or intake.
    Just changing the fuel usually results in relatively equal increases by percentage. For instance, in a diesel you may have 200hp and 400ft-lbs. If a more high performance fuel is used the increase would look like 10hp and 20ft-lbs (a 5% increase).
  18. Aug 11, 2010 at 4:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    HP is just a number. Torque is the actual work being performed. Yes, it is reasonable for the torque to go up 12, and hp to only go up 3. Look at where the torque is produced. HP = Torque x RPM / 5250. If the torque is boosted in the lower range, and flatens out near the top end (where the HP number comes into play), then the HP gain may not seem like much, despite the boost in torque.
  19. Aug 11, 2010 at 5:48 PM
    coolreed
    Reed
    OKC
    I read somewhere on the Taco Forum that the 2011 would have more HP and get redesigned. I looked on the Toyota web and it seems here are really no changes to the 2011 model. HP is listed as the same.
    But I was just curious how they were obtaining the extra HP in the FJ with the same engine. I thought maybe they used different cams or exhaust or intake.
    Thanks for the replies.
  20. Aug 11, 2010 at 8:26 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    FJ and the new 4Runner get dual VVTi which adjusts the timing on both the exhaust and intake camshafts. The Tacoma only has VVTi which only adjusts the timing on the intake camshaft.
