4.0 v6 hp difference?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jensent, Oct 13, 2011.
  1. Oct 13, 2011 at 2:40 PM
    jensent
    jensent [OP] Active Member
    What is the difference between a 4.0L engine in the Tacoma and in the Tundra? One is rated at 236hp @5200rpm while the other is rated at 270hp @5600rpm. Mechanically what are the differences? Do they use the same spark plugs, oil and filter etc?
  2. Oct 13, 2011 at 2:46 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    gay...so the tacoma has around 205rwhp
  3. Oct 13, 2011 at 2:51 PM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    220rwhp?
  4. Oct 13, 2011 at 2:55 PM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    lol
    3.4 make 190 @ flywheel :eek: Im pushing 33s, do the math :eek::eek::eek::eek::eek::eek:
  5. Oct 13, 2011 at 5:10 PM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    At 2000 rpm where most of you run with a V6 I bet they are making close to the same HP.
  6. Oct 13, 2011 at 7:47 PM
    jensent
    Is the element type oil filter on top of the engine where spin on has been or is down where the v-8 Tundras oil filters are? I sure like them up on the top.
  7. Oct 13, 2011 at 7:54 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Rob
    Pacific Northwest
    2005 4x4 DC TRD Off Road
    11 Color Matched Grille, Pro comp 7089s, 265/70/17 Wrangler Duratracs, Black Running Boards, Tinted Windows, Bed mat, Weathertech Floorliners
    I can tell you from owning both, the 4.0 has a lot more power. Towing a 3,500lb boat was where I can tell the biggest difference. Both good engines for sure, but I like the 4.0 better (assuming it turns out to be as bullet proof as the 3.4).
  8. Oct 13, 2011 at 8:00 PM
    sean266
    sean266 Mr. Clean Moderator
    Tacos are lighter (?)
  9. Oct 14, 2011 at 7:43 AM
    Kurdain
    Kurdain Well-Known Member
    Portland, OR
    I read this somewhere and it seems reasonable'ish:
    Drivetrain loss vs. drivertrain type
    10% loss for transaxle type cars
    (i.e. FWD type cars where engine and transaxle are basically 1 unit.)
    15% loss for front engine rear drive type cars/trucks.
    (like our Tacomas)
    20% loss on AWD cars or vehicles in 4WD mode.
    (like subaru AWD cars and such)
    Not sure if that helps at all as there are a million other factors but it has seemed to get me close for the most part when we build a motor and then go dyno it.
