4.0 V6 intermittent misfire cyl 1
Discussion in 'Technical Chat' started by specter208, Jan 1, 2020.
  1. Jan 1, 2020 at 9:33 AM
    specter208
    specter208 [OP] Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    have an 05 Tundra with the 4.0 1GR-FE. Recently developed an inconsistent misfire on cylinder 1. Happens inconsistently but almost always at idle or very low speed. Truck also sometimes momentarily feels like it loses power for a split a second and "catches" itself and returns to idle. Exhaust also makes some puffing noises occasionally. I replaced all ignition coils, spark plugs, engine air filter, battery, load tested alternator and cleaned the MAF. I even swapped fuel injector 1 with cylinder 2 and still misfire on cylinder 1. Checked compression with cylinder 1 reading 175psi and all other between 160-165psi. Not sure what else to check. Truck has 150k miles and has a timing chain cover oil leak aswell.
