4.0 V6 .... Love the power, hate the sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Apex1, Nov 14, 2018.
  1. Nov 14, 2018 at 8:38 AM
    Apex1
    Apex1 [OP] Well-Known Member
    Central CT
    2011 DCSB TRD
    So I have had my 2011 DCSB TRD for about a week. 72k miles, one owner all maintenance done. Truck is mint.
    Love the power curve. Perfect truck motor, torque comes on soon and hits with every up-shift. It actually feels better than the hp/tq rating in my opinion. I am coming from a 2010 MDX which has 300hp but is soft on the bottom. I prefer the Toyota power delivery for a truck.
    But.... This motor sounds kind of gritty. The ticking was apparent when I bought it. I did the research and mine sounds like a sewing machine in the wheel wells. My understanding is this is typical. But overall under acceleration the motor just sound a bit rough. Cruising at 2k or less is fine or even under low rpm load.
    First, I do not think there is anyway to make the engine sound quieter or smoother. I did the evap valve mod already and that helped a little. Now the ticking sounds valve or injector related and is the same on both banks. My guess is the engine will always make these noises.
    So my options are:
    1) Do nothing, chalk it up to first world problems and move on.
    2) Try to make the sound of accelerating more appealing. Thinking of an exhaust or CAI. I like some of the ones I have heard watching vids.
    3) Insulate the engine compartment for noise. Add an acoustic hood blanket and maybe inner finder liner. The material is cheap enough, but the results may be limited.
    Let me know if you guys have tried any of the above, and/or what you think.
    Thanks!
    george101 likes this.
  2. Nov 14, 2018 at 8:41 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    You didn’t think of these things before you test drove and then bought it?
  3. Nov 14, 2018 at 8:44 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Excellent point. No need for any further ideas.
    BassAckwards and Capt. Obvious like this.
  4. Nov 14, 2018 at 8:47 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Never seen this one before. But you can fit 265/70-17 tires without a lift.
  5. Nov 14, 2018 at 8:47 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    @Apex1 Instead of insulating the engine compartment, why not insulate the cab. I believe the name is dynamat. This way not only are you going to reduce the noise from the engine bay, but you will also reduce road noise and any other sound from outside of the cab.
  6. Nov 14, 2018 at 8:48 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Fart can exhaust
  7. Nov 14, 2018 at 8:51 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Use sound deadening in the cab. Keep outside noise out and improves acoustics for your music inside. Worth it.
    Alexely999 and Biscuits like this.
  8. Nov 14, 2018 at 8:52 AM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    This is one of the best things I've done to the truck especially running Duratracs as they are noisy tires.
  9. Nov 14, 2018 at 9:10 AM
    Apex1
    Central CT
    2011 DCSB TRD
    Absolutely, but didn't seem that bad during the test drive. I guess you learn and notice more things after driving a vehicle for a few days.
    Alexely999 likes this.
  10. Nov 14, 2018 at 9:12 AM
    Apex1
    Central CT
    2011 DCSB TRD
    Probably a good idea. I used this before installing speakers in a door. Pull up the carpet and lay this down underneath.
  11. Nov 14, 2018 at 9:39 AM
    jeepsrwack
    jeepsrwack Well-Known Member
    2014 Tacoma trd sport
    I actually installed a TRD exhaust because the truck was too quiet for me. Decent sound with no drone.
  12. Nov 14, 2018 at 9:45 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Truck prior to my Tacoma + 1GR had a 22R-E that sounded even more like a sewing machine for the 287,000 miles I put on it. I assume it still sounds like a Singer for the guy putting more miles on it since. I don't care about the ticks and taps Toyota engines make. When the ticks and tap sounds change then I worry.
    Biscuits likes this.
  13. Nov 14, 2018 at 9:48 AM
    eon_blue
    Azusa, CA
    Better than loving the sound but hating the power, lol. At least your issue with it can be fixed rather inexpensively in comparison.
    DavesTaco68 and Biscuits like this.
  14. Nov 14, 2018 at 9:50 AM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    People armchair quarterback all the time when they're outside of the situation. It's easier to pick up on things once you've been in a previously unfamiliar environment for awhile. Lord knows it's happened to me plenty of times.
    Bottom of the cab, door panels, rear cab... Even the roof if you're inclined. Throw some CLD, CCF, and MLV mats in there and be done with it.
    george101 and Gogetter303 like this.
  15. Nov 14, 2018 at 9:50 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    1st world issues. Just live with it.
    Gogetter303 and Biscuits like this.
  16. Nov 14, 2018 at 9:57 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Check the oil
    Check the exhaust. Are the heat shields loose?
  17. Nov 14, 2018 at 10:06 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    That's helpful
  18. Nov 14, 2018 at 10:14 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    This might sound dumb but run some boutique synthetic engine oil? That tends to quiet things down a little.
  19. Nov 14, 2018 at 10:20 AM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    option 2. The supercharger makes it sound different. :burnrubber:
    BassAckwards and Master Z like this.
  20. Nov 14, 2018 at 10:22 AM
    BuddyS
    BuddyS Well-Known Member
    Maryland
    2013 TRD Sport 4x4 MT
    Put some good music on the stereo, turn it up a tad and drive on. After a little while you won't really notice the noises anymore. It's just part of these trucks. I swear that the lawn tractors you can buy at home depot are probably more refined mechanically.
