4.0 V6 Reliability
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ravistae, Sep 15, 2015.
  1. Oct 17, 2019 at 11:59 AM
    #201
    surfandturf
    surfandturf Well-Known Member
    CT
    2014 TRD DCLB
    150k on my 2014. No issues with 5k oil changes. Could use more power when hauling
  2. Oct 17, 2019 at 1:02 PM
    #202
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    15K on signature series. I’m running XL every 6 months 6000-7500 miles. What oil filter are you using?
  3. Oct 17, 2019 at 7:22 PM
    #203
    TacTrd2007
    TacTrd2007 Well-Known Member
    2007 Tacoma TRD OR
    I've had my 07 since new. It has 301,000 miles currently.
    To date, I've had to have the pulleys and tensioner replaced, both wheel bearings replaced, tail shaft seal replaced, lower oil pan replaced, serpentine belt replaced, and timing cover gasket replaced.
    I've also gone through four sets of tires and three batteries. I've had oil changes done every 5k miles.
    I've had the "major service package" (which entails having all fluids replaced, new filters, and spark plugs) done every 100k miles.
    I've also had the front brakes done twice.
    The truck runs great and doesn't leak. I hope I can get another 100k miles out of it.
  4. Oct 18, 2019 at 4:58 AM
    #204
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Very nice. Just curious, have you replaced your alternator?
    Freeheelbillie likes this.
  5. Oct 18, 2019 at 5:07 AM
    #205
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Right. There tons of Jags out there with 300k on them.
    eherlihy and TheDevilYouLove like this.
  6. Oct 18, 2019 at 5:12 AM
    #206
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    :ohsnap:
  7. Oct 18, 2019 at 2:58 PM
    #207
    TacTrd2007
    2007 Tacoma TRD OR
    I haven't.
  8. Oct 18, 2019 at 3:38 PM
    #208
    TheDevilYouLove
    Marylandistan
    Wow that’s pretty incredible. Quality parts!!
  9. Oct 18, 2019 at 6:03 PM
    #209
    Lthompson
    Lthompson Well-Known Member
    im in the process of still trying to figure out issues with mine, whether its in the motor or what. at 100k now.. bad vibrations that nobody can explain. (not driveline related). bad drones at various rpms that nobody can explain. Now I have a light tapping/knocking sound that I don't know where its coming from at around 1000 rpm under low to no load. Hear it idling along, or if I rev it slightly its quite noticeable. In the process of trying to diagnose some issues with a local shop. He use to work at a Toyota dealership, but runs a wrecker service and is extremely busy.. So far,,, I really want to like this truck.. but I HATE driving it because of all these stupid issues that nobody can explain and I cant find any info about.
  10. Oct 18, 2019 at 8:46 PM
    #210
    LoneCynic
    LoneCynic Well-Known Member
    Ohio, USA
    NBM Tacoma 4x4 TRD Off Road & Towing
    SmittyBuilt Side Steps, DeeZee Bed Mat, TRD Shift Knob, Pop & Lock Tailgate lock, Stantz Locking Gas Cap, Marshall Instruments Oil Pressure & Oil Temperature Gauges
    Just shy of 80k on my 2013 Tacoma Off Road. I use Mobil 1 Synthetic 5w30 and change the oil and filter every 5k miles. I replaced the manual transmission fluid, transfer case, front and rear differentials all with redline fluids at 30k miles. Planning to change those all again at 90k. As far as parts replacements go, I've replaced the windshield wipers twice (that passenger side one seems to start to tear along the rubber blade edge every 2-3 years), I put on a new set of tires right around the 60k mile mark, and just recently replaced the battery for the first time. Bought the truck new at the end of 2012, and it is almost exactly seven years since then, so that battery lasted a good long time. I rotate the tires every time I do an oil change, and check the brakes when I do. Still running the factory pads, and they -still- look like they have about 60% pad left. All in all, I've been well pleased with this pickup, and not had any major issues to speak of with it.
  11. Oct 18, 2019 at 10:31 PM
    #211
    TacTrd2007
    2007 Tacoma TRD OR
    Tbh, and I know I'll get some heated feedback, but, I only get my truck serviced at a Toyota Dealership. Yes, they charge an arm and a leg for their service, but they know these trucks inside out, and can usually find the issue and fix it without wasting time. At least that has been my experience with my local dealership.
    So if you haven't, have a stealership do a diagnostic to see what they come up with, and have the repairs done elsewhere.
    07 sport 4x4 likes this.
  12. Oct 18, 2019 at 11:40 PM
    #212
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    Sounds like possibly a cracked flexplate.
  13. Oct 19, 2019 at 3:20 AM
    #213
    ARB1977
    North Texas
    Have your oil analyzed. It may tell you if somethings wrong.
  14. Oct 19, 2019 at 3:25 AM
    #214
    ARB1977
    North Texas
    Bought my 2015 with 30K miles, currently 83K. Typical stuff. Spark plugs, transmission oil twice. Just recently added a deeper transmission pan which added 2.5 qrts more atf. Suspension is due. Probably next year.
  15. Oct 19, 2019 at 12:32 PM
    #215
    wyotaco06
    wyotaco06 Well-Known Member
    Offroad 4x4 06
    196k on my 2006. Bought with 65k ten years ago.
    Not a single engine related issue. Original water pump/alternator/original everything.
    Rest of the truck: two front wheel bearings, one u joint. That’s it for repairs. Amazingly reliable truck. It is now mostly used for hunting and was my main truck for 7 years. It has NOT been babied at all but has been meticulously maintained by me.
    Spark plugs every 30-40k, Mobil 1 5/30 EP every 5k, drain and fill transmission every 40-50k, front/rear diffs every 25-50k with Amsoil severe gear same as transfer case. Coolant was drained and filled around 120k.
    Still getting 19-22mpg, best truck I have owned
    Still on original suspension as well as upper and lower control arms.
    I’m surprised it’s still got the original brakes....
    TheDevilYouLove likes this.
  16. Oct 19, 2019 at 1:09 PM
    #216
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    '05 auto w/179K (owned for 172K miles)
    '14 w/6 MT & 84K miles...(owned for 14K miles)
    5w30 synthetic Super Tech Walmart oil....Wix XP filters now
    regular scheduled service........garage kept......purty pampered lives
    gutless for towing even a loaded SxS trailer....3000#
  17. Oct 23, 2019 at 6:50 PM
    #217
    Lthompson
    Not a fan of my dealership. Basically blow me off, say its normal, then try to charge me. They also cracked my balancer replacing the front seal.
  18. Oct 23, 2019 at 8:00 PM
    #218
    jaydeebee
    jaydeebee Little-known member
    Wild West
    2010 TRDORDC
    Maybe go in like you're looking to upgrade, see what they find wrong with your trade-in at that point.
    Lthompson[QUOTED] likes this.
  19. Jan 4, 2020 at 1:50 AM
    #219
    Newpugface97
    Newpugface97 Member
    Tennessee
    2014 grey Tacoma trd
    189,000 miles on my 2014 4x4 running 65-80 almost everyday. Governed it out a few time racing anything on my way home gaining till it stops me lol. Great engine.
  20. Jan 4, 2020 at 6:12 AM
    #220
    pg_osborne89
    pg_osborne89 Well-Known Member
    Phil
    Savannah
    2012 Tacoma TRD Sport
    Bought my 2012 with 35k. Put 50k on it in two years. Just follow the maintenance schedule that comes with it and you’ll be good. I change my trans fluid more often because I tow frequently. But it has never skipped a beat.
