4.0 V6 Reliability
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ravistae, Sep 15, 2015.
  1. Aug 6, 2017 at 5:05 PM
    #81
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    I've done a lot of reading and cut open a lot of oil filters. There are guys on Bobistheoilguy pushing their filters to 20k or more, while changing the oil several times in between. I'm not advocating going that far, but I have no issues running a filter for a full reasonable OCI. I change my oil and filter both every time at ~3k, but I run a lot of hours up in that 3k... I'm averaging about 13 mph. My daily commute is less than 1 mile, I make that trip 4-5 times daily and idle a lot in between trips usually.
    They say that the average person will average around 33 mph (say 30-35mph), there's some debate about this, but that's the number I keep coming back to.
    Most people , in the same amount of runtime I accumulate on an OCI will have been around 7,500 miles.
    I have a friend that has 186,000 on his truck, over it's lifetime it has averaged 57mph, all of his miles are highway/interstate. In the runtime it takes me to accumulate 3,000 miles he puts over 13,000 miles on his truck.
    There are a lot of variables that go into oil and filter changes, ultimately you have to figure out what is best for you, and do what best suits your circumstances and usage. You are correct, oil analysis will tell you a lot... everyone uses their vehicle differently.
    sgtnewundies and Partzguy like this.
  2. Aug 6, 2017 at 5:11 PM
    #82
    09BlueBeast
    09BlueBeast Well-Known Member
    Cody
    Denver
    09 Speedway Blue TRD Sport 4x4
    I'd rather just pay the $6 for a new filter... it's like saying yeah man just reuse your condom it's good man.... like yeah it will work, but why?
    KeystoneGoodie and Sterdog like this.
  3. Aug 6, 2017 at 5:17 PM
    #83
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    I get mine for around $4, I'm not trying to change your mind, I'm just saying that a filter is fine for a full OCI. Do you pull your condom off in the middle of a romp and put a new one on? No...
    Cut your oil filter open at your next oil change and post pics, I'll do the same.
  4. Aug 6, 2017 at 5:19 PM
    #84
    09BlueBeast
    Cody
    Denver
    No but I use my condom for the suggested interval
  5. Aug 6, 2017 at 5:20 PM
    #85
    09BlueBeast
    Cody
    Denver
    And I'm not cutting shit open, I'm gonna fo what I've done for the last 20 years and just put a new filter on and call it a day.
    Sig45 and TRDSport10 like this.
  6. Aug 6, 2017 at 5:32 PM
    #86
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    :rofl: We went from engines>oil>condoms.... I'm done. My whole point was that 1 OCI = 1 filter for me. 1 oil change, 1 filter. If a filter isn't capable of going a full OCI I need to change to a better filter or change my oil more often. The most damaging particles are in the 5-7 micron range, a stock oil filter is usually rated at like 30-40 micron nominal, some of the best are 20 microns at 99% efficiency. If you want a good filter, go to a bypass type setup. A stock oil filter, new or used is not going to clean the oil to an acceptable degree for extended use. That's why we change oil so often, look at ships... some of them never change the oil, they run a massive bypass oil filtration system to capture all the harmful wear contaminants and some even boil the moisture out of the oil, preventing the additives from breaking down, the only oil that is added is makeup oil as it is burned off by the engine.
    Tarheel22, sgtnewundies and Sig45 like this.
  7. Aug 6, 2017 at 5:38 PM
    #87
    09BlueBeast
    Cody
    Denver
    I change oil and filter when the light comes on and I use Mobil 1 full synthetic... normally about 5-6k
  8. Aug 6, 2017 at 5:40 PM
    #88
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    My original comment wasn't even directed at you then, it was directed at the people who change their oil at 8k and filters at 4K (not picking on anyone in particular, that's just an example). The oil light is set to come on every 4500 miles, assuming you reset it when you change your oil.
  9. Aug 6, 2017 at 5:48 PM
    #89
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    Arguing about oil will go on for 400 pages, whether it's snowmobile forums, atv/sxs, truck, car, etc etc, people never see it the same way.
    I ran whatever oil was on sale in my old z24 and I sold it with 350k on the odo, so do what you want, it really doesn't matter this day and age.
    Sig45, NM Lance and 07 sport 4x4 like this.
  10. Aug 6, 2017 at 5:49 PM
    #90
    Avsfreak18
    Avsfreak18 Now 5% less disappointing
    Robert
    2015 AC
    Sidebar, What is the easiest way of turning that light off short of having the dealer do it?
  11. Aug 6, 2017 at 5:54 PM
    #91
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    With the key off, hit the button to show the odometer reading. When the odo reading is showing, hold down the button and continue holding the button down while you turn the key on, don't start the truck. Continue holding the button until you see 6 zeros.
  12. Aug 6, 2017 at 6:04 PM
    #92
    Avsfreak18
    Robert
    2015 AC
    Thank you sir!
    07 sport 4x4[QUOTED] likes this.
  13. Aug 6, 2017 at 6:28 PM
    #93
    Victory
    Victory Well-Known Member
    St. Pete, FL
    2016 White Tacoma TRD Off Road
    Your right, probably one of the cheapest parts to buy, but very labor intensive to fix. I didn't have the time to tackle that myself.
  14. Aug 6, 2017 at 8:51 PM
    #94
    gearcruncher
    Canadain bumper technician
  15. Aug 7, 2017 at 4:22 AM
    #95
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Currently at 7K on Mobil One 0W30 and stock filter. I disregard the maintenance light. I'll be closer to 8K when I change it in the fall.
    sgtnewundies likes this.
  16. Aug 7, 2017 at 4:27 AM
    #96
    GONE HAWKIN
    GONE HAWKIN Member
    David
    07 Tacoma TRD 4x4
    Just traded in my 07 4.0 with 353,000 miles. Changed the oil every 5000 miles with Penzoil 5w-30 conventional oil. The engine still ran perfect. She would drink about a half qt between changes. Awesome engine!!
  17. Aug 7, 2017 at 7:33 AM
    #97
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    What parts did you have to replace? Water pump?
  18. Aug 8, 2017 at 12:28 AM
    #98
    Shark18
    Shark18 Well-Known Member
    Daniel
    2007 White dbl cab Tacoma 4x4 TRD
    260k the only thing i have changed is the u-joints and front wheel bearings and 1 Battery...Mobil 1 in everything except trans she gets red line she uses about a 1/4 quart between oil changes at 6k...:cheers:
    07 sport 4x4 likes this.
  19. Aug 8, 2017 at 6:49 AM
    #99
    hmsailor
    hmsailor Well-Known Member
    Florida
    2015 DCSB 4X4 TRD spORt
    Dont worry about it. 2015 V6 4.0L is the best Toyota gasoline engine so far.
    Shark18 and RyanL like this.
  20. Aug 8, 2017 at 7:05 AM
    #100
    Northern Taco
    No the 2017 4.0l is even better. :D
    (none) and TireFire like this.
