4.0 Y pipe bolt size?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by knottyrope, Oct 4, 2019.
  1. Oct 4, 2019 at 10:54 AM
    knottyrope
    knottyrope [OP] Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Mine are so rusty they look like a 5mm and my gaskets are leaking so bad it wont pass the test.
    Stress of dropping trans must have made them leak when doing steering rack.
    Bought gaskets and work has hardware.
    What size are the bolts?
  2. Oct 5, 2019 at 10:22 AM
    knottyrope
    Knotty
    Bahstun
    Stumper
  3. Oct 5, 2019 at 2:04 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I did my best to look for you.
    Are you talking about the ones with the spring on them?
    If so, Advanced Auto says they carry them.
    Parts # 36454
    knottyrope[OP] likes this.
  4. Oct 8, 2019 at 7:56 AM
    knottyrope
    Knotty
    Bahstun
    Thanks for looking.
    I did do the slippery doughnut where the spring bolts are. Need to get a nut on them as the 4 little tangs barely have threads left
    Needed the flange bolts on the Y Pipe. I ended up not replacing that gasket as it barely leaks/makes noise.
    I did replace the cat to Y gaskets before the O2 sensors. Those came out easy with a 14mm deep. looked like rusted wire loops instead of a gasket.
    Seems to be running a bit better now too. Was leaking so bad that I got CEL for a bad CAT when parked idling .
    TnShooter[QUOTED] likes this.
