4.0L 1GR 2nd Gen Oil Change Guide
Discussion in 'Technical Chat' started by chris4x4, Jul 8, 2008.
  1. Aug 30, 2009 at 6:35 PM
    #201
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Not sure. I have always just drained first, then removed the filter. Never thought to think why not the other way. :eek:
  2. Aug 30, 2009 at 8:06 PM
    #202
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    I remove the oil filter while the oil is draining. So the advantage is that it gives you extra time to ensure all the oil has drained out of the crankcase.
    Also, if any oil comes out of the filter and into the engine, it will drain out because the plug is already removed.
  3. Aug 30, 2009 at 8:29 PM
    #203
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    I always drain the oil, wait for there to not be any type of stream, then pull the filter.
  4. Sep 4, 2009 at 9:34 PM
    #204
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    Just wanted to report that I was successful on my first oil change on my 09 and even reset the oil change reminder gizmo on the dash(thanks chris4x4!) This thread was a great help, it's really nice to have this site to share our thoughts and technical advice with each other.
  5. Sep 4, 2009 at 9:36 PM
    #205
    mitiko
    mitiko Well-Known Member
    lax
    05 prerunner trd
    [what oil you used/
  6. Sep 4, 2009 at 9:46 PM
    #206
    oldtimertoyota
    New Mexico
    I went with a toyota oil filter and castrol 5W-30W oil(non synthetic).
  7. Sep 4, 2009 at 9:47 PM
    #207
    mitiko
    lax
    05 prerunner trd
    for the price or just because
  8. Sep 4, 2009 at 9:58 PM
    #208
    THE TECHNICIAN
    THE TECHNICIAN Well-Known Member
    This thread is entertaining.
  9. Sep 5, 2009 at 5:42 AM
    #209
    oldtimertoyota
    New Mexico
    The filter to ensure a good fit and the oil because of past experience, my old toyota truck(86) has around 330,000 on it. I should say that I change my oil always at 3,000! So no it's not the price as I know you can go twice as far on synthetic, I'm probably just getting old:eek: and stuck in my ways:)
  10. Sep 11, 2009 at 8:15 AM
    #210
    AliOop127
    AliOop127 Newbie
    Ali
    Oregon
    96 4x4 3.4 V6 Ext Cab
    Intake & Exhaust
    As for Recycling, I read that every Wal*Mart Auto center will take used motoroil and properly recycle it and the filter for you!
  11. Sep 11, 2009 at 9:09 AM
    #211
    Veccster
    Veccster bass turds
    Eric
    2020 Pro
    Advance Auto takes it off my hands.
    Never thought to ask Wal-Mart.
  12. Sep 12, 2009 at 8:27 PM
    #212
    Crashmo
    Crashmo Well-Known Member
    Captain Dude
    Portland
    Was 03 TRD, Now 07 TRD
    Brush guard and Bed Storage and Karr Alarm.
    All you guys with your 2nd gen tacos have it good. I went to change my oil last weekend and had forgotten what a #*#@$% the filter was.
    It doesn't have that nice under mount catch thingy with the drain fitting. There is just a grounding strap and block there.
    Any heads up for my future other than shoving a rag under there and hoping? It always seems to drain some into the anti-scrape pan and there it sits for the next 5k miles.
    Our old BMW has the filter right up front, on top. It's the most killer convenient idea I've ever seen in a car.
  13. Sep 12, 2009 at 8:35 PM
    #213
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    take the filter off using a ziplock bag...it will catch most of the oil that comes outta the filter.
  14. Sep 13, 2009 at 2:47 PM
    #214
    JKD
    JKD Well-Known Member
    Inside warranty I will go with the OCI that keeps the warranty intact. I use regular oil up to about 5,000 miles, then switch to Mobil 1 for the rest of the vehicle's life.
    After a warranty is up, I use oil analysis and extend the OCI. On my last vehicle the oil was fine for well over 8,000 miles. I was changing it about every 10,000 to 12,000 in the past few years, since my highway commute has me putting a couple thousand miles on a vehicle every month. The engine is still in fine shape after 165,000 miles, but a deer jumped out in front of me and did enough damage to warrant a new vehicle.
    After warranty on the Tacoma I will probably do analyses with the goal of checking oil longevity up to 15,000 miles or so.
  15. Sep 13, 2009 at 2:51 PM
    #215
    JKD
    I do not understand how "engine vacuum" is going to tighten a drain pan bolt.
  16. Sep 17, 2009 at 9:23 PM
    #216
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    What happened with the way we all did it in the past: Filling the filter with oil to speed up the time till the oil get moving?
    Can't do it now. It is one of the reasons I choose synthetic oil.
    take care
    vbibi:(
  17. Sep 17, 2009 at 9:54 PM
    #217
    pittim
    Pennsyltucky
    Boujee Prius
    yep.
    i just use a grocery bag. put it over the filter, unscrew the filter with the bag over it, and it should drop inside the bag.
    oh, and make sure the bag doesn't have any holes in it....not that that's ever happened to me :anonymous:
  18. Sep 17, 2009 at 9:56 PM
    #218
    pittim
    Pennsyltucky
    Boujee Prius
    Also,
    Just curious as to how many of you put some oil in the filter before you put it on? It seems like some people do and some people dont.
  19. Sep 17, 2009 at 10:33 PM
    #219
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    Just around the filter gasket.;)
  20. Sep 18, 2009 at 8:23 PM
    #220
    oldtimertoyota
    New Mexico
    Just on the gasket.
    Have you ever started a vehicle without the oil filter on:eek:Not that I've ever done it:crazy:you understand, but in about a second you have about 2 quarts of oil over everything.
