4.0L 1GR 2nd Gen Oil Change Guide
Discussion in 'Technical Chat' started by chris4x4, Jul 8, 2008.
  1. Sep 18, 2009 at 8:58 PM
    #221
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
  2. Sep 23, 2009 at 10:39 AM
    #222
    TuRDVan
    TuRDVan A.K.A slosurfer
    Los Osos, CA
    07 DCAB TRD OFFROAD
    Dents and my wife drives it!
    Edit: Nevermind, I searched around some more and saw that it should work fine. Now if this one will fit my van, then I can just buy one filter for 3 of my rigs. :)
    1348 is the called for replacement, 1516 is the same spec but longer, 1068 is short, but large diameter, and 1515 is long and large diameter. All of these share the same anti drainback, and are equipped with an 8-11lb bypass, have 3/4"-16 threads and all at some time have been specified on older Toyota cars/trucks.
    I guess this is as good a place to ask as any. I am in the process of an oil changing marathon and got my napa gold filters. Already changed my 93 4runner and my 89 Toyota van (that was a bitch to change the filter), and was getting ready to do my wife's tacoma. Up till now, I've always had the dealer service it, since I got some free services when I bought it. Anyways, the napa gold filter #1348 is what I was given for the tacoma (which incidentally is the same one for my 4runner), and I noticed it is much shorter than the toyota oem one that is on the tacoma right now. I looked up online Napa and that is the correct filter # that is given. Is this the correct filter? Looks like it is the correct diameter and everything, just shorter, so it holds less volume.
    Thanks
  3. Oct 9, 2009 at 5:15 PM
    #223
    dannythefrenchie
    dannythefrenchie Member
    Danny
    gatineau,quebec,canada
    2006 tacoma 4x4 4 drs long bed
    a tousand thank you... save me a mess for tomorow......oh yes going under tomorow morning...
  4. Oct 9, 2009 at 5:34 PM
    #224
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    :woot:
  5. Oct 15, 2009 at 3:37 PM
    #225
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    Thanks again for the detailed thread- I wouldn't have known about the filter drain hole sleeve/tube idea without it.
    MAN that oil came out fast. I had my drain pan right underneath it and it still went everywhere.
    A semi related question - whats the lifespan of the stock air filter?
  6. Oct 15, 2009 at 3:38 PM
    #226
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think they say every 15K miles....
  7. Oct 15, 2009 at 4:45 PM
    #227
    EricT
    Arizona
    Not gonna worry about it now then! Again, much help here. All I need is a better oil drain pan, it came out so fast it bounced off the pan and went everywhere. Next oil change I'm getting a fumato drain valve.
  8. Oct 15, 2009 at 5:07 PM
    #228
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    Trial and error. I did the same thing. Bounced right up into my face.
    $25 later and the next change it's getting directed straight into an empty bottle. Fumoto is a great product. I bought one for both vehicles.
  9. Oct 15, 2009 at 5:10 PM
    #229
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  10. Nov 30, 2009 at 6:06 AM
    #230
    Gwest1967
    Gwest1967 Active Member
    Gregg
    S.E. Kansas
    SR5 V6 4x4 Ext Cab
    16 inch tires/wheels
    I got that crap all over... Can hardly reach the filter. I pulled the filter off and it dripped off of everything...
  11. Nov 30, 2009 at 7:12 AM
    #231
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    try using a sandwich bag next time you change the oil.....just get the filter loose enough to turn, slide the bag on, then take it off......save a good bit of the mess for the bag.
  12. Nov 30, 2009 at 7:13 AM
    #232
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Or put a shit load of rags under the filter. :eek:
  13. Dec 6, 2009 at 7:17 PM
    #233
    cornwall325
    cornwall325 Toyota newbie...
    Jonathan
    Virginia
    09' D.C. TRD Sport 4x4
    Seatbelt chime turned off, Toyota bedmat, Wet Okoles, stock other than that.
    I didn't look all the way through this thread but was wondering what the p/n for the drain plug gasket is?
    thanks
  14. Dec 6, 2009 at 7:47 PM
    #234
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Just go to the dealer and say you need a oil drain plug gasket. I've never had to tell the parts guy what kinda vehicle I had. They're like $1.50.
  15. Dec 6, 2009 at 8:06 PM
    #235
    jandrews
    '09 FourDubDee TRD OR
    My dealer *gave* me like 5 last time I was in there picking up some oil/air filters. I've been going to them for parts for years so they know me, and anything under a buck they usually just throw in for free. That's how you keep business!
  16. Dec 11, 2009 at 8:43 PM
    #236
    themaine1
    themaine1 Member
    South Carolina
    00 TOY
    alarm, speaker upgrades
    I just like the fact that I KNOW the drain plug was put back in, and I did everything right, had a issue once where that was not the case and almost blew the engine!
  17. Dec 12, 2009 at 6:48 PM
    #237
    JKD
    JKD Well-Known Member
    Noticed tonight that the drain plug gasket is apparently metal with a rubber coating.
    I thought it was a fiber washer. A little of the rubber is ripped on mine, but not across the sealing surface, so I guess I'll break down and buy a few at the dealership.
  18. Dec 13, 2009 at 8:51 AM
    #238
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    OK I read the entire 12 pages looking for the part # for the 2.7 oil filter. Is it the same as the 4.0 ? If not could someone post it ? If I missed it beat me up and post a link. Thanks.:confused:
  19. Dec 13, 2009 at 9:48 AM
    #239
    jandrews
    Just go to your dealership parts dept. and ask for some filters for the 2TR-FE. They should be able to look it up.
  20. Dec 13, 2009 at 10:45 AM
    #240
    george3
    New Jersey
    That would be nice but then I'd feel obligated to buy from the dealer and what I want to do is buy them in bulk for a better price on line.
