4.0L 1GR 2nd Gen Oil Change Guide
Discussion in 'Technical Chat' started by chris4x4, Jul 8, 2008.
  1. Dec 13, 2009 at 11:20 AM
    #241
    jandrews
    '09 FourDubDee TRD OR
    Then buy one from the dealer and go home and bulk order online.
    Jesus, is this really that hard? Google probably has the answer as well.
    There's no law that says you can't get information about your vehicle from the dealer. That's kind of their role.
    Yolotaco likes this.
  2. Dec 13, 2009 at 12:11 PM
    #242
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I did Google it. Why don't you make out like Bambie, if you don't have anything nice to say don't say anything at all. This is supposed to be a friendly forum. Chill, I'm done with you enjoy your life.:(
  3. Dec 13, 2009 at 12:30 PM
    #243
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Maybe post up on the main forum. Hopefully someone with a 2.7 who recently changed their oil can verify the part number?
  4. Dec 13, 2009 at 12:43 PM
    #244
    jandrews
    It's not nice or un-nice, friendly or un-friendly, it's simply stating a fact.
    You seem like you'd rather have someone else do the footwork of finding out the info for you rather than take one of the many options provided to you for you to acquire the information you need yourself.
    I tried to assist you, twice, with a question that didn't need to be asked in the first place, and you still insist no solution is present. Yes, I'm out of patience with you. Good luck with your oil filter, and have a nice day.
  5. Dec 13, 2009 at 12:44 PM
    #245
    george3
    New Jersey
    Thanks Chris. Always constructive, informative and positive. That's why Ya Da Man. :D
  6. Dec 16, 2009 at 7:54 PM
    #246
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    I just hold an empty beer bottle under the filter drain while removing the filter. Works fine and every shop has empty beer bottles.
    Any tips out there for getting a better read on the dipstick? Mine seems to drag oil and usually half of it ends up being covered in oil. Sometimes one side reads well but it's not always ideal.
    Should you be checking the oil level while its running or wait for it to settle after stopping the engine.
  7. Dec 16, 2009 at 7:56 PM
    #247
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Scuff up the end of the Dipstick with emmery cloth, or the like. I run the engine, then let it sit for a couple mins. then check the level.
  8. Dec 16, 2009 at 8:14 PM
    #248
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
  9. Dec 16, 2009 at 8:40 PM
    #249
    mitiko
    mitiko Well-Known Member
    lax
    05 prerunner trd
    I use a empty botle of water for drain oil filter or anything small ,is not a big deal.
  10. Dec 17, 2009 at 2:22 AM
    #250
    george3
    New Jersey
    Good suggestion but I don't think It's going to work 4 me. I drink Yuengling Porter, it's the same color as old, dirty, used motor oil and has a similar taste, I am easily confused :confused: I might drink half a bottle B 4 I know it. :rolleyes:
  11. Dec 17, 2009 at 1:09 PM
    #251
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    I didn't see an answer to this in the thread...
    In cold weather, does it take a long time for the oil to drain from the engine? If I change the oil first thing in the morning (in 30-ish weather) w/o running the engine, is the oil going to take forever to drain?
    Thanks!
  12. Dec 17, 2009 at 1:12 PM
    #252
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You should change the oil when the engine is at operating temp.
  13. Dec 17, 2009 at 2:45 PM
    #253
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    no it wont take forever cause its thin oil.but what chris said is the best for the task at hand.
  14. Dec 17, 2009 at 3:03 PM
    #254
    The Parts Whore
    The Parts Whore Slinging parts since '03
    Answer in #2 post of this thread. :)
  15. Dec 17, 2009 at 3:31 PM
    #255
    george3
    New Jersey
  16. Dec 21, 2009 at 6:09 PM
    #256
    C-Hawk
    C-Hawk Active Member
    Just changed the oil &filter on my sons '10 2.7L 4wd reg cab for the first time. After a quick assessment my first idea was to remove the engine skid plate before attempting the job but as we all know, lazy trumps everything so I skipped that step. Bad move. I ended up removing it anyway except it was much messier with a couple ounces of oil on top. Next time that will be the first step. On the 2.7L 4wd its much easier removing the skid plate first, unless of course you have the luxury of a lift and have a little more mobility than lying down.
    The factory O/F on the 2.7 was a 90915-20003 and the replacement from the dealer is 90915-YZZD1 for around $5.50.
  17. Dec 22, 2009 at 1:15 PM
    #257
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    So when you removed the old oil filter, were you able to use the tubing as described for the v6, or do 4-bangers not have the luxury of that particular item? I got under my truck, saw the filter (upside-down), saw the main drain plug, but didn't see the oil filter drain plug as described.
  18. Dec 23, 2009 at 8:46 AM
    #258
    nurseboy
    nurseboy Well-Known Member
    Jan
    Riverside, Ca
    I was discussing with a friend regarding the steps to this oil change. In my old car i would usually just drain the oil from the oil drain plug located on the oil pan. In this tutorial it states to
    Connect a 5/16" 5 foot long tube to the filter drain, and run it to your Oil catch pan. Useing a filter wrench, remove the filter:
    Then you replace the filter, and you remove the oil drain plug and let the rest of the oil out. What are the consequences if there is any IF you just remove the oil drain plug and let the oil drain from there INSTEAD of the oil filter first?
    ( this was discuss because if someone doesnt have a 5/16 foot long tube)
    Thanks
  19. Dec 23, 2009 at 9:50 AM
    #259
    pittim
    Pennsyltucky
    Boujee Prius
    Heres what I do.
    Remove drain plug, let oil drain out for like 20min or so.
    Remove old filter.
    Drain plug back in with new crush washer.
    Lube new filter, put it on.
    Put new oil in.
    I dont use hoses or anything.
  20. Dec 23, 2009 at 11:49 AM
    #260
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats because you have a first gen. On the second gens, the oil filter is on the top/driver side of the engine.
