4.0L 1GR 2nd Gen Oil Change Guide
Discussion in 'Technical Chat' started by chris4x4, Jul 8, 2008.
  1. Apr 9, 2010 at 1:00 PM
    #321
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    The last time I changed my oil, I drained it directly into an empty window washer fluid container. I waited until it stopped dripping and closed up the drain plug. Put 5.5 quarts in and checked the dipstick. It was halfway up the damn thing!
    Then it hit me, the empty container (which I filled to the very top) is only 1 gallon (or 4 quarts). I then had to drain out 1.5 quarts to get an accurate reading - which I did.
    Any way to measure how much oil you took out?
    Also, I scuffed up my dipstick with sandpaper so the oil would stick to it a little better. It worked great. Be sure to clean it off after sanding it - don't want that dust in your engine.
    No need to crank down on that oil filter when you put it back on. I go hand tight + 1/2 turn.
  2. Apr 13, 2010 at 2:38 PM
    #322
    Taco4x4NC
    Taco4x4NC Well-Known Member
    David
    Western North Carolina
    2010 4x4 DC/LB "Pytrite Mica/Katzkin leather
    3m clear bra or Venture, stant locking gas cap, Shield, front windows tinted, weathertechs, ARE "Z" topper. Sockmonkey decal, Billy 5100's x 4 corners, Eibach coils, Toytec 1.5 AAL. Michelin 265/75/16 MS2's, Grillcraft MX series/TOYOTA badging. FJ/SE TRD Anthracite gray wheels. Katzkin leather/heated seats.
    X2 water bottle works great!
  3. Apr 13, 2010 at 5:46 PM
    #323
    MassTaco
    MassTaco Well-Known Member
    Massachusetts
    V6 4x4 SR5 DC AT5
    That's a great idea Veccster
  4. Apr 14, 2010 at 9:53 AM
    #324
    JUJtacoma2010
    JUJtacoma2010 Well-Known Member
    Fresno
    Tacoma 2010 Dbl Cab. OFF Road Package
    nice writeup
  5. Apr 27, 2010 at 5:54 PM
    #325
    eschonle
    eschonle Well-Known Member
    eric
    Seattle, WA
    2006 V6 SR5 4x4
    TRD Cat back Exhaust, Leer Shell, BHLM, Satoshi Grill
    the mechanic at Car Quest gave me 5W-20 for my tacoma but the manual says 5W-30...
  6. May 8, 2010 at 11:01 AM
    #326
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    I have always changed my own oil (at least on vehicles I can get my fat belley under) but anyways I have never had the situation where they even used a gasket for th eplug let alone change it every oil change. Whats up with that? Can I just buy some gasket material and make one myself? I would hate to spend an hour going back and forth to the dealer for a 50 cent gasket....thanks, also why is there a plug on the oil filter housing anyways?
  7. May 8, 2010 at 11:47 AM
    #327
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Oil filters have a rubber gasket that seals against the block.
    Drain plug has a crush washer that should be changed every oil change (they're like $1 at the dealer, I've gotten them for free from mine a couple times)
    Guessing theres a plug on the filter housing because whenever you take the filter out it'll drip some (4th pic down...first gens dont have this (not v6s at least)) so there is a way to drain that oil aswell.
  8. May 8, 2010 at 12:17 PM
    #328
    coffeesnob
    VA
    I am assuming you can only get these at the dealer correct?
  9. May 8, 2010 at 9:26 PM
    #329
    Hootbro
    Hootbro Omnipotent
    Delaware
    2019 SR/SX Tacoma Access Cab 4x4 3.5L
    Yes you can get them at the dealer. Just get a bunch at one time to make the trip worth the gas. You can also get a second use out of it by flipping it over so long as you torque the drain bolt to spec.
  10. May 9, 2010 at 12:28 PM
    #330
    coffeesnob
    VA
    Now are you talking about thr 4 cylinder engines cuz I crawled underneath mine and I could not find no drain valve by the oil filter.
  11. Jun 5, 2010 at 10:32 AM
    #331
    Hipster
    Hipster Nothing beats a Butter Shave..
    Tom
    Tucson
    '10 DC trd 4x4
    Billy's @ .85 w/ Eibachs front, TSB w/ 5100's rear + 1.5" AAL & shims, Debadged, Avid Bolt On Sliders, NFab Light Bar w/ (2) Lightforce 170's. Weathertechs, ATO bed bars.
    Just did my own "First" oil change on the Taco. Thanks TacomaWorld and Chris 4x4 for the simple & easy instructions. She's sitting with 5.5 qts of Mobil 1. I used the water bottle instead of the tube. Piece o cake.
    Now to dispose of that oil...
    Have a great weekend. Supposed to hit 106F today. Giddyup.
    hip
  12. Jun 23, 2010 at 10:40 AM
    #332
    PineBarrenTaco
    PineBarrenTaco Active Member
    South Jersey
    Super White TRD Off-Road
    Clear bra, TRD catback, TRD skid plate
    I just did my first oil change on my 2010 Taco (4.0) and there was no oil drain plug crush gasket. My Subie had one....
    Weird...
  13. Jun 23, 2010 at 11:28 AM
    #333
    amati5
    amati5 Well-Known Member
    2010 Prerunner TRD
    I didn't see one when I removed the plug because it stuck on the oil pan. I had to use a flat screw driver to pry it off.
  14. Jun 23, 2010 at 11:43 AM
    #334
    PineBarrenTaco
    South Jersey
    Maybe that's what happened. I'm definitely going to change it and check for it better next time around.
  15. Jun 23, 2010 at 7:35 PM
    #335
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    Mine stuck as well on my first oil change.
  16. Jun 25, 2010 at 5:39 AM
    #336
    coffeesnob
    VA
    That is good advice about putting in 5.5 qts of oil. I changed my oil for the first time this a.m. I drew a sharpie mark of the side of the vessel I used to catch the oil dumped it into a bucket and poured water up to that sharpie mark it was around 5.5 qts give or take a little. I am going to inspect the washer on the oil plug Monday at work with a microscope. From the naked eye I really do not see any difference between it and the new one. I know for the sake of a dollar it's probably wise to change it,however If I don't see any difference I will probably reuse at least 1 more time...
  17. Jun 25, 2010 at 8:42 AM
    #337
    Hootbro
    Hootbro Omnipotent
    Delaware
    I have used both types and really recommend the extra coin be spent with the Fumoto valves. The other type based on the FRAM Suredrain design just has extra parts to keep track of. Also the poppet design not the best and can leak.
  18. Jun 25, 2010 at 10:39 AM
    #338
    coffeesnob
    VA
    Do those Valves ever leak? I think I got one of those things on my Husqvarna riding mower and it was a piece of junk, took it off at first oil change.
  19. Jul 5, 2010 at 5:07 PM
    #339
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Where do I find a tube? Thought about it, can't come up with anything.
  20. Jul 5, 2010 at 5:10 PM
    #340
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    For the filter drain? You can get one at any Home Depot, or Ace Hardware.
