4.0L 1GR 2nd Gen Oil Change Guide
Discussion in 'Technical Chat' started by chris4x4, Jul 8, 2008.
  1. Aug 22, 2010 at 7:28 AM
    #361
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    The first time I saw it, that Fumoto looked so cool and easy! just find an old gallon jug and rotate it for changes...WOW...no more pouring from the drain pan into the jug and cleaning up the inevitable mess!
    But...I have recurring nightmares about someone twisting it open in the parking lot at the mall. Crazy, I know...but...well...crazier things happen all the time.
  2. Aug 22, 2010 at 7:42 AM
    #362
    buddywh1
    Philly PA
    07 DC SR5 4x4
    I've never had problems with THAT part. Maybe 'cause I'm not stingy with it so it's a tight fit as the threads cut through it and pretty careful to torque it good and tight (but still NEVER as tight as the gorillas at the shops do it). I also keep the crush washer anyway; but don't worry about changing it, cracked or not, since that's what the tape is for.
    I've heard some people are concerned about little strings of it cutting off by the threads and coming loose in the oil. That's worth worrying about I suppose: just make sure to keep it several threads back from the tip of the bolt and clean off the old before putting on new.
  3. Aug 22, 2010 at 11:02 AM
    #363
    28ØØ3
    28ØØ3 Well-Known Member
    boss
    somewhere endlessly searching for ways to offend B
    08 DCLB SR5 4WD
    VatoZone Especial
    does anyone else have a problem with the oil launching over the sides of the drip pan when you pull the drain plug? i've had it happen to me twice. this last time it shot all the way to the tire :confused:
  4. Aug 22, 2010 at 4:04 PM
    #364
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Hell yes. I would say that 60% of all the oil ended up OUTSIDE the drip pan. It absolutely sucked.
  5. Aug 23, 2010 at 5:37 AM
    #365
    Larry
    Larry CARL
    CARL
    Yes.
    I'm gonna get me one of those giant drain pans with the lip curled inward. The one I saw also has a pour spout to pour the used oil into the jug for drop off.
  6. Aug 29, 2010 at 10:52 AM
    #366
    gstell
    gstell New Member
    Gary
    2010 preRunner double cab
    OK, so just how do you get to the drain on the oil filter reservoir? So much "stuff" around it I can't get my fingers on it. Can't come from the bottom either due to the skid plate and all the other connectors and braces in the way.
  7. Aug 30, 2010 at 3:10 PM
    #367
    TacoTimmah
    TacoTimmah New Member
    Timmah
    Pottstown, PA
    07 Tacoma V6 TRD Sport Package
    Hey all, I'm new to the Tacoma family and did my first oil change yesterday. This sticky made it very easy and by far the easiest oil change I have ever done. I used to own a 2003 WRX and it was a PITA to change with how it was set up underneath. This was nice and easy and I love how the oil filter is up top and easy to get to.
    I'm sure I'll have more questions about the Tacoma but I'll be sure to post them in the appropriate threads.
    Thanks for the sticky!!!!
  8. Aug 31, 2010 at 9:46 AM
    #368
    Cortland
    Cortland Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    Great write up!
  9. Aug 31, 2010 at 7:03 PM
    #369
    tony9120
    tony9120 New Member
    tony
    houston, texas
    06' prerunner
    none yet,
    i'm new to the tacoma family, just finished my first oil change... problem: oil not showing up on the dipstick yet. any thoughts?
  10. Aug 31, 2010 at 7:10 PM
    #370
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Im sure its there, just hard to see.
  11. Aug 31, 2010 at 7:45 PM
    #371
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    I must say I have a hard time seeing the oil on the dipstick as well after an oil change, I just make sure to add what is specified and I can usually find the oil a little below the top mark.
  12. Aug 31, 2010 at 7:57 PM
    #372
    Nightstr
    Nightstr Well-Known Member
    Felipe
    Sacramento CA
    05 prerunner sr5
    BLHM BLWM 3" TOUGH COUNTRY LIFT TRD SEAT COVERS THULE RACK M/T KM2 265/65/16
    Sh*t!! I just did my oil change, After finishing the oil change i went to toss the box and saw 10w30! i thought i had bought 5w30, is that bad.
  13. Sep 1, 2010 at 5:56 AM
    #373
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can scuff up the end of the dip stick with some coarse gritt sand paper to make it easier to see.
    You should be fine.
  14. Sep 11, 2010 at 11:22 AM
    #374
    IATACO
    IATACO Member
    Central US
    2010 DC TRD OR
    I've got a 2010 OR and did a search but didn't seem to find an answer.
    Does anyone know what type of oil is put in by the factory - is it regular or semi-synth? I assume it's not full synthetic because of the cost.
  15. Sep 11, 2010 at 11:50 AM
    #375
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Regular oil was in mine.
  16. Sep 12, 2010 at 7:05 PM
    #376
    cwagly
    cwagly Active Member
    I normally get the dealer to do my oil changes, and thought I do it myself. I am by no means and expert, but not a novice either. I have to say, Chris 4X4 step by step was great. :thumbsup: As like most of you, I had my share of oil mess too. Also, the idea to use the 5/16" 5ft tube was a huge blessing. GREAT IDEA. I did have one issue and I have to say I was not a very happy camper at the time. Getting the old oil filter off. The dealers had that one so tight, I almost broke my oil filter wrench. Dealer put it on way to tight. I took my time and it took me a little over an hour. I worked out a great system and I am sure it can be done 20 to 30 mins tops. So thanks to you all for your help!!!!!
    :yay:
  17. Sep 14, 2010 at 10:52 AM
    #377
    Oskie_78
    Oskie_78 Well-Known Member
    Texas
    1998 4Runner, 2016 4Runner, 2023 Tacoma
    Great write up, lots of great info!
    I'm planning on do my 1st old change the next time it's up...I only had 2 free ones from the dealership.
    BTW, where's a good site to order some OEM oil filters?
    Thanks.
  18. Sep 14, 2010 at 11:19 AM
    #378
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    Ebay... Can get a case of 10 90915-YZZD3 filters for $40 here
  19. Sep 14, 2010 at 11:39 AM
    #379
    Oskie_78
    Texas
    great price! thanks! :)
  20. Sep 25, 2010 at 10:39 AM
    #380
    JoeN 267
    JoeN 267 Active Member
    Joe
    Central NY
    Tacoma - TRD Sport 2010
    Getting ready to do 1st oil change, will be using Mobil 1 Oil and filter -
    Questions: The 5/16 tubing, is that ID or OD measurement ?
    I have 2500 mi. on truck, 1 yr. old, can I go ahead and reset the "maintenance reminder" and expect it to reset itself for another 5000 +/- miles ? I will be changing oil and filter at 5000 mi. intervals after this 1st change -
    Also, what do you think about using a product such as Lucas gas treatment ? I have used this product about once a year in previous trucks ?
    Thanks guys
