4.0L 1GR 2nd Gen Oil Change Guide
Discussion in 'Technical Chat' started by chris4x4, Jul 8, 2008.
  1. Nov 11, 2008 at 9:22 PM
    HWALLEN48
    HWALLEN48 Member
    SEATTLE,WA
    08 REG CAB4X2
    How do you turn out that Maintenance light ??
    Hal in Seattle
  2. Nov 12, 2008 at 5:03 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    From elsewhere on TW.com...
    To reset you Maintenance Required light:
    1. Turn the ignition key to the "OFF" position with the odometer reading shown.
    2. Turn the ignition key to the "ON" position while holding down the trip meter reset knob.
    Hold down the knob for at least 5 second. The odometer indicates "000000" and the light goes off.
    NOTE: You will see a series of dashes that count down while the system resets itself
    If the system fails to reset, the light will continue to flash!
    You must re-perform the procedure
    TacomaCZman likes this.
  3. Nov 23, 2008 at 5:50 PM
    pidro_el_pirata
    pidro_el_pirata Well-Known Member
    Can we get some pics of a first gen 4 cyl? I've never done this before and I don't want to f*** it up.
  4. Nov 23, 2008 at 5:53 PM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I dont have my 2000 2.7 anymore, but the filter is near the exhaust manafold. Drain the oil, then remove the filter. Easy as pie. :)
  5. Nov 23, 2008 at 5:56 PM
    pidro_el_pirata
    Sounds good, I'll give it a go. Thanks!
  6. Nov 23, 2008 at 5:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    OOOOO!!!!!
    You have the 2.4. I cant remember where the oil filter is on it. I think its in the same place, but Im not sure. :eek:
  7. Nov 23, 2008 at 6:03 PM
    pidro_el_pirata
    Right, yea I didn't really read what you wrote lol but I'm sure it'll be obvious. And if not.. I don't need the oil changed RIGHT away lol
  8. Nov 23, 2008 at 6:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It WILL be obvious, I just cant remember the exact location. Get some rags handy, as oil will seep out when the filter is removed. :)
  9. Dec 11, 2008 at 6:01 PM
    scott214
    scott214 Member
    va beach
    05 PreRunner SR5 Offroad
    k&n, ARE Cap, heela xenon headlights leather seats
    no need for the 5/16'' tube. just punch a hole on the top of the filter with a phillips head screw driver and hammer and this breaks the suction and the oil will drain out by itself. i do it all the time with very little mess.
    Wessty, Canyon lands, PzTank and 2 others like this.
  10. Dec 11, 2008 at 6:15 PM
    warrantbird
    warrantbird Member
    Romeo
    El Paso, TX
    08 TRD Sport, DC, LB
    2.5 Suspension Lift, TRD Cold Air Intake, Banks Monster Exhaust, Doug Thorley Short Headers, Toyota Brush Guard & Running Board, BAK Flip Tonneau Cover, XD Hoss 17X9 Wheels, Elusive Elements Grille
    Thanks for the info. I did not know that there is a drain plug by the oil filter. I just changed my oil without know the plug and I make a mess when removing the oil filter.
  11. Dec 11, 2008 at 7:00 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Quick question, Just purchased some Mobil 1 Full Synthetic, but for some reason grabed 10w30. Noticed you are using 5w30. Whats the difference between the two. Been a while since I had a brand new vehicle, and just always assumed 10w30.
    Edumacate me..:D
    Thanks...
  12. Dec 11, 2008 at 7:38 PM
    rdcowan
    rdcowan Member
    Robert
    NW Florida
    2017 Silver Tacoma Access Cab, SR5, 4 cyl, Automatic
    Although oils have come a long way and in general, modern premium brand oils are all very good, the wider viscosity range (5w30) is stretching the limits of the viscosity index improver additive further than the 10w30 is. In other words, the ability to maintain the 5w30 characteristics would likely breakdown before the 10w30 would. Note: I have 30 years of experience as a maintenance engineer in a chemical plant and am also a certified machinery lubrication analyst. (Doesn't mean a lot really....experience is the best teacher! :D)
    Hay Lobos likes this.
  13. Dec 11, 2008 at 9:00 PM
    roxspin72
    NC
    Oh Yeah!!!
    Makes sense...
    Thanks.
  14. Dec 12, 2008 at 4:56 AM
    Meeocky
    Meeocky GEAUX TIGERS!
    Louisiana
    Black '05 Tacoma
    I've had a rubber fuel line hose as my drain for a few years now and it works great. I have it strapped down so it always stays on my truck. The end of the hose sticks out about 3" right past my skid plate. Once it finishes draining, I wipe the end of the hose and tuck it behind the skid plate. You'll never know its there. :D
    Malinosan and Flhighby like this.
  15. Dec 12, 2008 at 7:19 AM
    #35
    fendertweed
    fendertweed Member
    05 Tacoma base
    on the 2.7 the filter sits upside down so there's no filter drain, but you will get leakage so best to take a plastic bag and surround it to catch the drips as you unscrew the filter.
  16. Dec 12, 2008 at 8:43 AM
    #36
    warrantbird
    warrantbird Member
    Romeo
    El Paso, TX
    Thanks for the great information. This a great forum for new tacoma owners.
  17. Dec 12, 2008 at 8:46 AM
    #37
    PRS
    PRS Member
    I'm another ignorant dyi that did not know about the drain port until I asked here. The list of necessities the initial post provides does not make mention of the new plug gasket that nobody ever takes care to replace anyway. If you did want a new gasket, where do you get those plastic ones? All of mine are the soft aluminium type. I guess an "O" ring would do in a pinch.
    prs
  18. Dec 12, 2008 at 3:17 PM
    #38
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Being as the mount that the filter sits in/ attaches to, is cast aluminum, and when hitting the filter with a hammer and screw driver is transfering some of that energy to the mount, I dont think that is a good idea. I dont think it could take many hits before it would start to crack.
    Yolotaco likes this.
  19. Dec 14, 2008 at 6:33 PM
    #39
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    I'd one up your rep for that last comment but I already did on another one today, good point, brute force + cast aluminum(or steel for that matter) ='s more $$ and a bunch of FU#K sh*t words yelled in the garage, making your neighbors think you have Torrets
  20. Dec 14, 2008 at 6:41 PM
    #40
    Monkeysuncle
    Kevin
    Florida
    Only in a pinch, the crush washer(called that way back in my air cooled VW days) was a one time use, back then they were brass or copper because they are softer metals. Now aluminum washers are used. Honestly I have used the same washer for over a year with no oil leaks on the oil pan. And I hate oil leaks( I did mention I had an old VW aka oil leak a plenty)
