4.0L 1GR 2nd Gen Oil Change Guide
Discussion in 'Technical Chat' started by chris4x4, Jul 8, 2008.
  1. Sep 25, 2010 at 12:15 PM
    #381
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Stay away from any Lucas addatives. You shouldnt even have to worry about anything like that for many thousands of miles. The tubing is 5/16" ID. And Yes, you can reset the maint. Minder now, and it will be good for another 5k miles.
  2. Sep 25, 2010 at 12:21 PM
    #382
    Eurosport
    Eurosport Well-Known Member
    around the world
    try sanding the oil dipstick with some 100 grit sandpaper or 60, then of course make sure you wipe it good before putting it back in. if still can't see it good, then just file it a little with a hacksaw blade, just a tiny bit so it makes scratches on it, this will help tremendously in seeing oil level. the dipsticks they use suck ass. too smooth at the end, should have used a marked plastic like other cars... oh well
    and for someone that asked about leftover oil in the oil filter housing tray, cleanest is to use a big plastic syringe with a rubber hose attached and just suck that baby up nice and slow ;p
  3. Sep 25, 2010 at 12:35 PM
    #383
    JoeN 267
    JoeN 267 Active Member
    Joe
    Central NY
    Tacoma - TRD Sport 2010
    Thanks Chris for the quick reply - will do as you suggest !!!
  4. Sep 30, 2010 at 4:14 PM
    #384
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    Just did my third oil change and I still refer to this thread, great work on this Chris!
    I put mobil 1 in my '09 v6 at 2800 miles, 7800 miles again, and today at 12,800 miles. I know I should probabaly have had one more change in there. It came out really black, should I be worried? I didn't think the mobile 1 would change color so much.
  5. Sep 30, 2010 at 4:24 PM
    #385
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You should be worried if it came out clean. Best way to find out is to have an oil sample performed. Check out Black Stone labs. :)
  6. Sep 30, 2010 at 5:15 PM
    #386
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    BAH! :p
  7. Sep 30, 2010 at 8:16 PM
    #387
    EricT
    Arizona
    Thanks Chris. Know why I check this thread every time? Because of that guy that did the whole tranny fluid drain/oil in coolant job. No joke, I just ran out and double checked the oil drain net pic for the third time. My synth came out dark and a little reddish... Ill have to send some in to test sometime. Good idea. Thanks!
  8. Oct 5, 2010 at 9:29 AM
    #388
    JoeN 267
    Joe
    Central NY
    Well I did the 1st oil and filter change yesterday - used Mobil 1 5w-30 and Mobil 1 M1-102 oil filter:
    Things I noticed -
    1 - 5 1/2 qts. Mobil 1 & filter with correct size filter cup wrench, about $70.00
    2 - Mobil 1 filter about 1/2 inch shorter than stock Denso filter
    3 - Denso filter had more holes in the base than the Mobil 1 filter
    4 - Denso stock filter was not that hard to remove as some posts here have said, again, correct size filter cup wrench, short extension on a 3/8" drive - yes it was tight but I certainly did not need a cheater on the drive handle
    5 - When removing the drain plug from the oil pan I was prepared for a huge gush of oil, per some posts here - not the fact, but my truck is only raised a little over 1"
    6 - The filter drain rubber cap, I put a dab of dielectric grease in it - slides on and off now with no problem
    7 - Also took out the AFE Pro Dry AF and cleaned it, still looked like new with only 2500 miles on it
    8 - All in all, no big deal - now on to the "drive shafts" and greasing them, but that is for another "Thread" -
    9 - I can see how one might possibly mistake the Transmission drain for the Oil Pan drain, just gotta remember the Oil Pan is under the engine NOT the Tranny :)
  9. Oct 7, 2010 at 11:45 AM
    #389
    fvtalon
    fvtalon Well-Known Member
    Southern BC
    07 DC TRD/Yamaha
    285/65/18 BFG ATs on MKWs Leer Cap
    I just browsed this whole thread. Quite entertaining. :laughing:
    Anyways, here's my 2 cents:
    I just did my first '07 V6 oil change (before you ask, yes, I bought it used 5000kms ago). What an easy change. I gotta say the first time I popped the hood before I bought the truck I saw that drain nipple on the oil filter housing and figured out what it was for. It works good, I want to install a permanent one. For the people wondering about the missing rubber cap I don't see it being a problem as long as you wipe that filter housing out when you finish draining so it doesn't drip oil on your belts.
    For the guys spilling oil out of their drain pan are these all lifted trucks or what? I've never had that issue. My drain pan is a maybe 18" black plastic one, it's open with a bit of a hump in the bottom. The only spillage I get is when I position it poorly or when the oil drains down to a very fine constant stream towards the end and the breeze steers it out of the pan. I like to change hot or warm whenever I can too. Maybe the hump in the bottom is helping diffuse the splash back? Maybe a screen on some blocks, like a cookie cooling tray would help break up the steady stream and reduce that? Don't put it back in the kitchen when you're done though!
    As for the guy cranking the filter on with a wrench, do not do that, ever! In one of my other cars some years have a sandwich type oil to water cooler between the filter and the filter housing, like what tow package Tacos have. I don't know about Tacos but on the other cars over time, when you over tighten the filter it crushes the cooler, which ruptures the lines inside and leaks oil into the coolant and vice versa. Also, this causes the oil filter to come loose and then back off and spew all the oil all over the car and the road.
    I always ensure all the old gasket came off, always lightly oil the new gasket and always hand tighten the filter to contact plus a half turn or so and I've never had an issue. I've been changing my own oil since I started driving 10 or so years ago. Oh, I also oftentimes reuse the drain plug washer with no issues, I always wipe the plug and washer down while I'm waiting for the oil to drain then wipe off the pan before I screw it back in.
  10. Oct 7, 2010 at 11:54 AM
    #390
    fvtalon
    Southern BC
    07 DC TRD/Yamaha
    Oh, one thing I forgot, I didn't realize how handy those static cling reminders were. There was one on the truck from the previous owner's last change. Ebay to the rescue. I've got 100 generic oil change reminder static clings coming for about $10 shipped.
  11. Oct 7, 2010 at 3:30 PM
    #391
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Why? Does the 5K dash reminder not work for you?
  12. Oct 8, 2010 at 12:14 AM
    #392
    fvtalon
    Southern BC
    07 DC TRD/Yamaha
    I suppose because I have yet to see it come on? *shrug* The guy I bought the truck from brought it in for an oil change and general mechanical inspection before he sold it to me, then I've put on 5500kms or so and just changed it because that's the standard interval. I imagine it will come on eventually. I guess if it's a 5k mile (not km) light it will come on in a few weeks.
    At any rate, besides the Taco I've got 3 other cars including the wife's. I was writing mileage down on a white board in the garage but she's never out there to look at it so she never knows when it's time for an oil change. The stickers will be handy for those cars too.
  13. Oct 8, 2010 at 3:53 PM
    #393
    vermintrex
    vermintrex Well-Known Member
    Vancouver
    TRD SPORT Shorty
    BFG A/T KO 265/70/17, '11 FJ wheels, 5100's all four corners, Eibach springs, 1/4" Taco lean spacer, Leer 100XR, WeatherTech liners, trimmed mud flaps and I farted in it.
    Another boring oil change story.
    Easy peasy !
    The rubber oil filter drain cap was a bitch to take off, used an empty juice container jammed in against the rad hose to catch the overflow. Still had to use some shop rags to absorb a little bit of residual that refused to drain.. ...worked perfect.
    Re-used the plug washer, it never came off when I removed the plug.
    Oil drained out without splashing..~ 3 hours after running the motor..almost cold. I installed the new filter first (Fram xg3614), then backed the oil filler cap off a bit before draining.
    Used Castrol Syntec 5w30 synthetic.
    yeah, that's about it.
    Have a good weekend.
  14. Oct 8, 2010 at 3:53 PM
    #394
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    You, Sir are a gentleman, answering him like you did.
  15. Oct 9, 2010 at 6:34 AM
    #395
    SCFirefighter
    Stephan
    Cary, NC
    Eh? What's wrong with asking about the stickers? I'm sorry if I offended your delicate senses with a perfectly normal question.
  16. Oct 23, 2010 at 9:14 PM
    #396
    Big O
    Big O Well-Known Member
    Owen
    Dallas , Texas
    ' 06 X Runner ( Red )
    K & N Air Filter , Magnaflow Muffler , Full Synthetic Oil R/P ,block,trans & differencial , New LED taillights, TRD Short Shifter, a Boulekos Sprint Booster !
    Hey Guys ,
    One think I've been doin' on all my vehicles for several years now is after I'm through with the whole process ,I
    stick a couple of little but, strong magnets on the bottem & side of the filter body .
    I'm not sure if they are doing any thing , but they might catch some metal traveling in the oil & hold 'em 'til the next oil change .
    Big O
  17. Oct 23, 2010 at 9:38 PM
    #397
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont think a magnet would do that much. Its best to have any contaminants suspended in the oil, so it comes out when you drain it. If it was stuck to a magnetic area, when you removed the magnet, it may still stay against the pan, to due any residual magnatisim on the pan, and not come out. Could eventually form a large metalic ball O shit that could cause more damage down the line. If this was truly affective, it would have a magnetic plug, like the front and rear diff do.
  18. Oct 24, 2010 at 6:03 AM
    #398
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    He was suggesting putting the magnets on the filter body...so I think the idea is it would hold the particles in the filter and gets discarded with the filter.
    But I still agree your point's valid...any particles the magnet would catch, the filter would too and oil bypassed on cold starts doesn't even get that far. Just don't see the magnet doing much at all...but at least it doesn't appear to be harmful.
    By the way, this reminds me of the aftermarket oil plug replacements with magnets in them that used to be someowhat popular. Wonder if anyone still makes/sells them?
  19. Nov 20, 2010 at 6:57 AM
    #399
    ncabrera
    ncabrera Member
    Nerio Cabrera
    Alexandria,Kentucky
    07 PreRunner
    Do you really have to use Toyota motor oil and filter or, you can use different kind.The truck is still under warranty and I'm noy sure what to do.
  20. Nov 20, 2010 at 7:00 AM
    #400
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can use whatever oil and filter you like.
