4.0L 1GR 2nd Gen Oil Change Guide
Discussion in 'Technical Chat' started by chris4x4, Jul 8, 2008.
  1. Nov 20, 2010 at 7:33 AM
    #401
    28ØØ3
    28ØØ3 Well-Known Member
    boss
    somewhere endlessly searching for ways to offend B
    08 DCLB SR5 4WD
    VatoZone Especial
    Chris prefers fram :devil:
  2. Nov 20, 2010 at 7:34 AM
    #402
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    :p Hey...They SAY they are the BEST!
  3. Nov 20, 2010 at 7:35 AM
    #403
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    change mine once a year......that is the ultimate
  4. Nov 20, 2010 at 2:22 PM
    #404
    StaldineJ
    StaldineJ Member
    Montana
    2000 sr5 2.7L 5 speed
    Guys -
    what's the deal with the plug gasket or "crush washer"? I bought the truck used in 2004 from I guy I worked with, he changed the oil himself each time as the mileage-oil type-filter type-date written on the flap of a filter box indicate. There was no gasket of any kind when I bought it, or I would have found a replacement on the first oil change. Since 2004 I have done every oil change at 3000 miles over the course of about 55,000 miles and have never had a gasket on the drain bolt - ever. NOW I'm paranoid.
    Is there a part number? Can you buy a bunch at once online or something? Could I just use an O ring? I've never had a leak to this point... but I'd like to keep it that way!
  5. Nov 22, 2010 at 2:17 PM
    #405
    Trachito
    Trachito Well-Known Member
    New Orleans
    autozone has a pack of like 6 plastic washers for the oil drain plug for like 2 bucks or so.
  6. Dec 13, 2010 at 12:31 PM
    #406
    TheTacoTruck
    TheTacoTruck Well-Known Member
    Scott
    Central PA
    05 TRD 6-Spd
    Quick question, I'm sure it was asked but I didn't want to go through 21 pages to find the answer.
    -Is the 5/16" tube, is that the inner or the outer diameter. Home depot has two different tubes where one is the inner and the other is the outer! Thanks for the help!
  7. Dec 13, 2010 at 12:33 PM
    #407
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Inner.
  8. Dec 14, 2010 at 6:20 AM
    #408
    river rat
    river rat Tool Geek
    Midwest
    '11 Timberland Mica regular cab.
    I just go to the dealer parts counter every couple years and buy a few, and keep them in a ziplock baggy with my oil filter wrench.
  9. Dec 21, 2010 at 10:34 PM
    #409
    Cortland
    Cortland Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    I just changed my oil this afternoon, it is super easy to do!
  10. Jan 5, 2011 at 3:15 PM
    #410
    lugnut
    lugnut Member
    Never knew about that plug at the bottom of the filter holder. I'll be *&%@#$. I have been taking my oil evacuator, hooking up the air hose, and laying the suction tube in the oil filter holder to catch the oil as it comes out. Kind of like that suction tube the dentist uses. It works.
  11. Jan 5, 2011 at 3:45 PM
    #411
    lugnut
    lugnut Member
    Gold Plugs LLC makes a replacement magnatic drain plug. No - I got nothing to do with them. Did buy the thing. String magnet. Can't hurt.
  12. Jan 21, 2011 at 7:10 PM
    #412
    Halo913
    Halo913 Well-Known Member
    Adrian
    Tucson AZ
    Tacoma sport 4x4
    Pro-comp full suspension 3 inch lift, Built right UCA's
    Thank u for this post helped me a lot. This was my first oil change for my truck. I ended up using a Fram filter and Royal Purple oil!
  13. Jan 21, 2011 at 7:13 PM
    #413
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  14. Feb 2, 2011 at 2:40 AM
    #414
    Bullzi511Tacoma06
    Bullzi511Tacoma06 KCCO
    Southeast Louisiana
    2016 MGM Doublecab SR5
    Oil change later on today :)
  15. Mar 9, 2011 at 4:39 PM
    #415
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    Changed the oil & filter for the first time on my 2011 DC with the V6. Wow, after 13 years with my '98 3.4 V6, this oil change is a piece of cake. The location of the oil filter is the biggest difference. Also, so glad the Tacomas don't have the cartridge style filters like the 4.0L V6's in the 4Runners.
    A big thanks to chris4x4 for his how to write up and all the answers he has provided.
  16. Mar 14, 2011 at 8:08 AM
    #416
    boatswain
    boatswain Well-Known Member
    carl
    palmerton,PA.
    2018 Tacoma TRD Sport access cab, magnetic grey metallic.
    synthetic or regular oil, from the factory? this question has been asked more than once. I installed an aftermarket cam in my 427 chevy. the instructions specifically stated NOT to use synthetic oil during break in. apparently the lubricating quality is that good that it does'nt allow proper break in. It may not be a cost thing, they would just add it onto the price of the vehicle.
  17. Mar 14, 2011 at 8:15 AM
    #417
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Engines are "broken in" at the factory, and they come from the factory with dyno oil.
  18. Mar 14, 2011 at 10:29 AM
    #418
    boatswain
    carl
    palmerton,PA.
    thats good to know. so you could drive a new vehicle home and change over to synthetic right away, if you chose to do so. not that it makes any sense, but it seems that most guys are switching to it ASAP. just bought an "09" tacoma in dec. with 2,027 mi., oil was changed once, sticker says due 4,589. I was going to do 1, maby 2, reg. oil changes before making the switch to syn. I may be wasting my time, but old habits die hard.
  19. Mar 15, 2011 at 7:09 AM
    #419
    boatswain
    carl
    palmerton,PA.
    just found another thread -ENGINE BREAK IN. - MURPHMAN and I must be on the same page. or maby its because we're both older. either way,these forums are a wealth of information. never too old to learn.
  20. Mar 20, 2011 at 10:52 AM
    #420
    loves.her.truck
    loves.her.truck Well-Known Member
    Blu
    San Diego
    06 Prerunner trd
    I just did my first oil change eveeeeerrrr :D!!!!
    & all thanks to this threaaaddd, wohoooooo!! Thank you, so much <3!
    Grant it, it was a little (a lot) messy but, it gone done. My friend was there for support & emergency help but, he said I did great! :)
    Thanks boys!
    <3
