4.0L 1GR 2nd Gen Oil Change Guide
Discussion in 'Technical Chat' started by chris4x4, Jul 8, 2008.
  1. Aug 26, 2011 at 12:45 PM
    #441
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    great thread man, would have never looked for that plug under the
    filter. Bought mine 4 months ago, popped the hood and thought, wtf is
    the oil filter diong way up here!?!?! :D
  2. Aug 27, 2011 at 2:46 PM
    #442
    Scorn
    Scorn Well-Known Member
    Indiana
    TRS Sport Dbl Cab
    I went out and checked my 2009 Taco and there is a rubber plug that slides down off the filter drain plug.
    I am not that sharp of a mechanic but want to change my own oil. Does that rubber plug slide off and then hook up the 5/16 hose on the filter drain plug.
    Thanks
  3. Sep 2, 2011 at 1:23 PM
    #443
    colder
    colder Well-Known Member
    MN
    2011 Access Cab TRD Sport
    Anyone know what the recommended torque is for the drain plug?
  4. Sep 2, 2011 at 1:35 PM
    #444
    colder
    MN
    Follow-up - found in another thread: 30 ft/lbs
  5. Sep 2, 2011 at 1:38 PM
    #445
    jrdbrn
    jrdbrn Well-Known Member
    Jared
    Louisiana
    '21 TRD Off Road
    People who don't to bother with a tube.. a water bottle works the same.
  6. Sep 3, 2011 at 9:42 AM
    #446
    Scorn
    Indiana
    TRS Sport Dbl Cab
    I have a 2009 4WD AT with 30K, bought it with 15K and just did my first oil change and I want to thank everyone for there help. :):):)
    It went smooth after I found my old filter wrench, the one you can use a socket with.
    I used a syn blend and I hope that's alright, the stealership also used a syn blend, at least that's what they said.
    Can I go to a full synthetic with 35K miles on the next oil change?
  7. Sep 3, 2011 at 11:05 AM
    #447
    JKD
    JKD Well-Known Member
    You can do that. You could change back and forth all you want. You could run synthetic in even years and regular oil in odd years. Regular oil in months that end in "y". You could make a new rule that you can only wear white pants and run regular oil before labor day, gray pants and synthetic oil from then until memorial day. [​IMG]
  8. Sep 6, 2011 at 9:03 AM
    #448
    Big O
    Big O Well-Known Member
    Owen
    Dallas , Texas
    ' 06 X Runner ( Red )
    K & N Air Filter , Magnaflow Muffler , Full Synthetic Oil R/P ,block,trans & differencial , New LED taillights, TRD Short Shifter, a Boulekos Sprint Booster !
    Remenber, 'vetts come with full synth from the factory.
    One can swith back in forth , but why would one want to ? I run full syn in all of my machines. Hell, I even run it in my lawn mower.
  9. Sep 18, 2011 at 5:47 PM
    #449
    TacoSport
    TacoSport opinions are like assholes; everyones got one.
    NE
    2011 TRD SSM Sport DCSB w/Tow
    After reading the original post and noticing a step was missing I.e. add oil to filter before installing. I then read the first 100 posts and last 10 and nobody made mention of it. Not a step I ever miss.
  10. Sep 18, 2011 at 5:50 PM
    #450
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Dont really need to. Plus, the filter goes on with the open end down, so it would pour out anyway when you put it on.
  11. Sep 18, 2011 at 5:50 PM
    #451
    BlkTaco47
    BlkTaco47 Unhinged
    i've always done it that way but the filter is
    inverted on the taco, wouldn't work.
  12. Sep 18, 2011 at 5:52 PM
    #452
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Been changing my own oil for years and have never done that and have never had any issues.
  13. Sep 18, 2011 at 5:54 PM
    #453
    TacoSport
    NE
    Not saying to fill it with oil, just put some in and roll it around so it is not dry, which is fairly standard in the industry.
  14. Sep 18, 2011 at 6:26 PM
    #454
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont see the need, as fresh oil hits it in a couple seconds, or less when you start it.
  15. Sep 18, 2011 at 6:30 PM
    #455
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    i changed my oil today. was at my house up at school so i don't have all my tools up here yet :( borrowed a ratchet from the neighbor and drained the oil into empty coffee cans. before i put the new filter in i just dipped the bottom of it in the old oil and screwed her in there.
  16. Sep 18, 2011 at 6:32 PM
    #456
    BlkTaco47
    BlkTaco47 Unhinged
    dipped the NEW filter into the OLD oil??? :eek:
  17. Sep 18, 2011 at 6:32 PM
    #457
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, I'll rub a little oil on the gasket, but thats about it.
  18. Sep 18, 2011 at 6:34 PM
    #458
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    and the oil plug gasket goes...?
  19. Sep 18, 2011 at 6:35 PM
    #459
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    On the oil plug....Do I need to hold peoples hands?
  20. Sep 18, 2011 at 6:35 PM
    #460
    jgwheeler17
    NC
    neglect, mostly.
    what's it really hurting? i asked myself. i was a clean coffee can, just enough to get the seal wet, i thought it was a good idea. . . and i had already put the other jug of new oil in the barn.
