4.0L 1GR 2nd Gen Oil Change Guide
Discussion in 'Technical Chat' started by chris4x4, Jul 8, 2008.
  1. Dec 14, 2008 at 6:48 PM
    #41
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I just did an oil change, and I reused the OEM gasket. Im going to see if a leak develops and report my findings. Im with you as I HATE oil leaks, or leaks of any kind. :)
  2. Dec 14, 2008 at 7:18 PM
    #42
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    I just did the gear oil change yesterday on my 5 speed, both the drain and fill pulg have the aluminum washer. I used ONE full wrap of teflon tape on both just for peace of mind. Reused the original washer. Drove all day today, no leaks.
  3. Dec 15, 2008 at 6:27 AM
    #43
    spaghettiedy
    spaghettiedy Well-Known Member
    Pittsburgh
    09 DC LB Sport in Black 4x4
    Gray Weathertechs, LG Wet Okoles, Tacome OEM Bedmat
    I over-looked Chris's DIY guide before changing my oil for the 1st time this weekend. Thanks! I noticed that he cut a M1 quart to make a funnel, and I didn't have a funnel so I did the same. The freaking plastic M1 quart threads exactly into the oil spout! I don't know if just Toyota is smart enough to figure this out, or I just never looked at previous vehicles. I may just be a dumb-ass, and the rest of the world already knew this.
    RedDemolisher likes this.
  4. Dec 15, 2008 at 6:54 AM
    #44
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I found this out years ago. It works on my Tacoma ( both of them) and my Dodge. :D
  5. Dec 15, 2008 at 7:05 AM
    #45
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    Aww no way!!! I had no idea about the M1 bottle. I always just cut a 16oz water bottle and used it as a funnel.
  6. Dec 15, 2008 at 7:12 AM
    #46
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL, the thing I like about useing the M1 bottle as a funell is that it will hold a quart of M1 upside down and let it drain into the engine while Im doing something else. I dont have to sit and hold it until its empty. Not that it takes along time, but I can just dump one in it, and do something else.
  7. Dec 15, 2008 at 7:17 AM
    #47
    Dark Knight
    Jeff
    NC/SC
    just in time on this idea too, gota change the oil this week.
  8. Dec 15, 2008 at 12:56 PM
    #48
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    I took advantage of the unseasonable temps here and changed mine today. I didn't have a crush washer since I bought a box of 10 oem filters online but the one I put on last time didn't come off when I took the drain plug out. Is this cool to reuse the one I put on last change? It didn't fall into the pan :help:
  9. Dec 15, 2008 at 12:58 PM
    #49
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    it will be fine. i used one on my 06 2 or 3 times without a problem....no leaky!!:D
  10. Dec 15, 2008 at 1:00 PM
    #50
    Dark Knight
    Jeff
    NC/SC
    I have never changed my washer and have never had problems, (fingers crossed)
  11. Dec 15, 2008 at 1:07 PM
    #51
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    Stock for now
    Cool, thanks guys!
  12. Dec 15, 2008 at 8:37 PM
    #52
    Monkeysuncle
    Kevin
    Florida
    I may have used the wrong term, the crush washer was used in the Volkswagen air cooled oil change(imagine a washer that is hollow) once you applied pressure (torque)to it, it "crushed down", almost like a lock washer, helping the drain plug to seal. Those were one time used items. On the tacoma the washer may just act like a washer, spreads the clamping power over a larger area. I think the dealership and books say to buy a new one with every oil change but then again , they want your money, albeit .98 cents.
  13. Dec 31, 2008 at 6:47 AM
    #53
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  14. Jan 3, 2009 at 2:30 PM
    #54
    andyfontaine1972
    andyfontaine1972 New Member
    andy
    northern ca
    2007 tacoma pre 4 dr long bed
    Awesome info, too late for the first time but greatly appreciated!! next itme I'll know
  15. Jan 10, 2009 at 8:39 AM
    #55
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    pyrite 6-speed 2012 offroad
    driver mod
    how do you reset the computer after an oil change?
  16. Jan 10, 2009 at 8:53 AM
    #56
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Put the key in the ignition, push and hold down the ODO button, turn key past the Accs. to the "ON" position, and wait until the ODO goes to "00000".
  17. Jan 22, 2009 at 4:19 PM
    #57
    JAG
    JAG Well-Known Member
    Bump, just in case no one saw the DIY Thread/Sticky. Awesome info. Doing it myself this next go round. I had been letting the dealer do it since I have had some problems with Express Oil Change, but I am going to save my money and more importantly make sure it is done right! Thanks for the info Chris!
  18. Jan 22, 2009 at 4:30 PM
    #58
    tammikm
    tammikm Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    are there grease fittings we should be greasing with each oil change ? 06 DC 4x4....
    thanks
    Hay Lobos likes this.
  19. Jan 22, 2009 at 4:50 PM
    #59
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Some Tacomas have grease fittings along the drive shaft, in the "U" joints, others dont. Take a look at your "U" joints, and feel around for a grease zerk. If you feel one, give it a little grease. :)
  20. Jan 25, 2009 at 8:09 AM
    #60
    mcoffeen
    mcoffeen New Member
    Georgia
    Silver PreRunner SR5 TRD
    What is the best way to remove the oil filter drain plug? Does it unscrew or just pull off? Neither seem to be working for me.
