4.0L 1GR 2nd Gen Oil Change Guide
Discussion in 'Technical Chat' started by chris4x4, Jul 8, 2008.
  1. May 20, 2012 at 4:45 AM
    #581
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Thanks. That is very good information. I like the trick "simply see if the bottle cap will screw onto the Toyota oil cap. If it screws on then the bottle should screw into the valve cover." I have long used oil bottles for funnels but I bought Shell syn because it was on sale. These bottles don't screw in and when forced it cross threaded and some plastic dropped into the valve cover:eek:. Anyway thanks again for the trick.
  2. May 20, 2012 at 7:36 AM
    #582
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Thats what Im using in the pics. Most 1 quart oil bottles will thread into the oil fill location.
  3. May 21, 2012 at 8:20 PM
    #583
    BBYE V8
    BBYE V8 Please keep TW beautiful: search & stay on topic
    Brian
    StL, MO
    07 AC 4x4 2.7 5sp SR5
    I've finally read a few more pages of this thread and found I posted absolutely nothing that has't been mentioned before. :sorry: I'd whine about how long the thread is because of all the useless posts....but it looks like I'm part of the problem.:eek:
  4. Jun 9, 2012 at 12:33 PM
    #584
    K Williams
    K Williams Well-Known Member
    Long Island, NY
    2011 TRD Off Road V6 MT
    Banks Monster Exhaust URD Stage II Clutch
    Does an official record of all oil changes need to exist to keep the warranty in good standing? If it doesn't, I'm going to do all my oil changes in the future.
  5. Jun 9, 2012 at 12:38 PM
    #585
    K Williams
    Long Island, NY
    I just bought 10' of 5/16" ID tubing at Home Depot. They sell it in the plumbing aisle.
  6. Jun 9, 2012 at 12:56 PM
    #586
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Don't worry about the 0.4qts. Really, your engine will be fine :)
  7. Jun 9, 2012 at 12:57 PM
    #587
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Official?
    Just keep a written log. I write down the brand oil and viscosity, date, mileage, and oil filter used, and any other worthwhile notes in the back of my maintenance book. Use a small notebook if you'd rather.
    I do this for almost everything I change except wiper blades cabin filter etc.. or topping off random fluids unless there is something important to note.
    This helps you keep track of everything you've done. It's a good reference if you're selling the vehicle, and it's also a good reference if you have to deal with a warranty claim.
    I've no good reason but I decided to add all of my log into a google document, I go through and update it every once in a while.
    Heres a fictitious log I made for an example. You could go farther and include part numbers for air filter and spark plugs etc etc... or do it however you want, just an example for you.
  8. Jun 9, 2012 at 1:21 PM
    #588
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Hell while I'm at it, I'll throw my .02 in for some other shit.
    I've changed my oil since day 1 myself. I think like 20 times now. Not once have I replaced the crush washer on the drain bolt, and not once have I found a drop of oil on the pan.
    I've also changed my rear diff fluid probably 8 times, lol, and haven't changed either crush washer, same story with the front, though I've changed that less times, and have leaked no drops of oil. I clean all surfaces really well and just run em again and again. Just saying.
    Rather than a hose, I just stuff a water bottle between the fan shroud and the radiator hose, and hook the bottle under the nipple on the oil filter shroud deal. 20 times of doing that and never an issue. Do what works best for you though. Just an option.
    Personally I dump a 5qt jug in, and then about half of a 1 qt jug and it comes up perfect on the dip stick every time.
    Probably all been covered already but whatever, it's a party.
  9. Jun 9, 2012 at 1:52 PM
    #589
    PR45
    PR45 Well-Known Member
    Los Angeles
    PreRunner SR5 4cyl
    You can register your Toyota, (but not your Lexus or Scion) and keep a log on their site. Dealer service shows up there also.
    http://www.toyota.com/owners/web/pages/home
    Not sure if this was already mentioned, too laze to page back and look.
  10. Jun 11, 2012 at 1:07 AM
    #590
    Big O
    Big O Well-Known Member
    Owen
    Dallas , Texas
    ' 06 X Runner ( Red )
    K & N Air Filter , Magnaflow Muffler , Full Synthetic Oil R/P ,block,trans & differencial , New LED taillights, TRD Short Shifter, a Boulekos Sprint Booster !
    U can do 'em. I also write a note on my reciet noting which vehicial & the milage at the time .
  11. Jul 3, 2012 at 4:28 AM
    #591
    mwtaco
    mwtaco Well-Known Member
    07DCSB Black
    I read every single post on this thread then went out and changed the oil on my 2007 v6. Because of this thread, I did it without a splattering a single drop of oil.
    I replaced the drain plug gasket for 1.19$ from local dealer. I did inspect the existing one and it looked like new. If it weren't for that gasket, I wouldn't have to visit my dealer. I could buy everything aftermarket at advance auto.
    It really is hard to read the oil dipstick.
    I thought about using tubing leading from the oil filter drain, but to avoid having to make a trip to the store and hunt for it, i used the other tip which was a water bottle. worked flawlessly. wouldve been a huge mess without this tip. don't forget to remove the bottle when you are done though.
    cost analysis:
    oil filter and gasket 7.50$
    mobil1 full synthetic 6 quarts 26$
    vs.
    dealer charge oil change "special" with dino oil 32.95$ (not really a "special" IMO)
  12. Jul 3, 2012 at 11:37 PM
    #592
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Check out this thread:
    http://www.tacomaworld.com/forum/te...-oil-filter-made-thailand-vs-competition.html
    I only buy the factory filter now. My dealership sells it for under $5.00 and they throw in the plug gasket for free
  13. Jul 18, 2012 at 1:06 PM
    #593
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I changed my own oil yesterday for the first time in over 10 years. I was very glad to have the stealer to it for me all that time. Lately the stealer was so busy that the wait to get service was becoming a problem. That, plus the ease and value of the Fumoto F-103 drain valve and access to a garage it's just too easy to do myself now. Plus the peace of mind of doing it myself and knowing it was done correctly.
    I paid $30.00 for six quarts for Penzoil 5-30W full synthetic oil which included a $15.00 rebate. So my net price is $15.00 plus tax for the oil.
    Stealer sold me 6 oil filters @ $3.84 each.
    Did the oil change last night and installed the valve. Even without the valve I only spilled three drops and that was on dirt. :) Yay!
    This guide was helpful.
  14. Jul 24, 2012 at 6:20 AM
    #594
    TacoJoe12
    TacoJoe12 New Member
    Joe
    Salt Lake City, Utah
    06 TRD Access Cab
    HID's (fogs, headlights), K&M Drop Panel Filt., lots of audio upgrades.
    Glad to of stumbled upon this. Honestly. The whole upside down filter was freaking me out. I just used a little cup underneath the drain and it seemed to work fine! I forgot how nice not having to put a sedan on jack stands was....
  15. Jul 28, 2012 at 9:02 PM
    #595
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    how the hell we supposed to get this filter off?.. i tried both hands, a claw type filter wrench, and a strap wrench.. all i'm doing is damaging the damn filter
  16. Jul 28, 2012 at 9:34 PM
    #596
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    I know that the first filter removal is tough. The factory has a special gorilla that torques the filters down. I use a pair of filter pliers and usually will dent the old filter a little bit, but it doesn't matter as it's going in the trash can anyways.
    Good luck.
  17. Jul 28, 2012 at 10:27 PM
    #597
    wileyC
    Centerville, OH
    how much damage is too much before i can't drive it somewhere for help?... tried channel lock pliers too (a bit undersized though), but seem to just keep tearing it up.. am i gripping it in the wrong place?... there's hardly any room for range of motion...
  18. Jul 28, 2012 at 10:31 PM
    #598
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Get yourself a chisel punch or a screw driver, set it into the base, and tap that filter around. If you punch a hole though then you're in it for the money. Not a big deal IMO but if you're skills aren't up to par don't punch a hole. Keep to carefully tapping at the base with the chisel. You'll get it broken free.
    Get the channel locks at the base too where it won't collapse on ya. Pipe wrench if you have to. IMO though a chisel at the base is easiest. Just angle it so it'll spin the filter off.
  19. Jul 28, 2012 at 10:32 PM
    #599
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Also it doesn't take much effort to pull that plastic engine cover up out of the way if it's impeding your range of motion.
  20. Jul 28, 2012 at 10:37 PM
    #600
    wileyC
    Centerville, OH
    you want me to use a chisel?... i dunno, ...i'm not one for destructive measures, ...i guess i'm worried i'll be stuck if i destroy it but can't get it off...
