4.0L 1GR 2nd Gen Oil Change Guide
Discussion in 'Technical Chat' started by chris4x4, Jul 8, 2008.
  1. Sep 23, 2013 at 8:25 AM
    #741
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I was doing the anytime camera mod and had 2 wires mixed up, so the light came on. Did this the first time, and again when I changed to switch. So I don't think I shorted it out, but will double check.
    Edit: if I did short something out wouldn't tat short out all the dash lights and not specifically one light?
    Edit #2: went out and took a look, all lights come on with ignition, so cant be a blown fuse or anything. Looked at the manual, and the "how to" to reset the service button is like how you guys are saying but in brackets it says "USA only". Does this mean to beuno for Canadian?
    Edit #3: looked at this video, and my light isn't on and doesn't display. -->http://www.youtube.com/watch?v=OqChsgaMq_w. May help someone out
  2. Sep 23, 2013 at 8:30 AM
    #742
    fenderpicks
    fenderpicks Well-Known Member
    Ordered my fumoto valve the other day to change my oil for the 1st time.
    However the thread on the fumoto seem so small.....
    My other car that was a sedan had a fatter thread than this fumoto.....
    Is our tacomas oil drain bolt that small?
    PS: i finally went under and took a look at the truck....
    Is the oil pan the super small one lol....?
    It looks absurdly small, and i see the metal tube the dip stick connect it to... so im pretty certain that small pan is the oil...
  3. Sep 23, 2013 at 12:11 PM
    #743
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    It's the one closest to the front of your truck. If you have a factory skid plate, it will be a little harder to find than the pictures in this thread show.
  4. Sep 23, 2013 at 1:20 PM
    #744
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Called the dealer, and wanted to ask what was going on. The first dealer I called tried the whole reset thing with me, and thought it was a bulb, or something was up with the calibration. The second dealer I called said the Canadian vehicles do not have a service light... This would make sense since in the manual it says 'USA only'.
    Any Canadian taco owners know anything about this?
  5. Sep 23, 2013 at 2:08 PM
    #745
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Yeah, it's the smaller one closer to the front of the truck. The one a little further back in the transmission....don't take that one out on accident. I've seen a few folks do that on here.
  6. Sep 23, 2013 at 5:44 PM
    #746
    fenderpicks
    I know which one is the trans....
    The trans pan is a long rectangle shaped.
    I am just worried this one i am looking at , is something other than engine and trans lol....
    There only 2 drain plugs right?
    Trans and engine?
  7. Sep 23, 2013 at 6:39 PM
    #747
    bjboucher
    Brad
    San Antonio, Texas
    Only 2 that are pointing straight down. If you found the tranny one, the oil plug is just on the other side of the cross member, closer to the engine. Or find that center jack point that is clear in the original post, it's just a little behind that. I believe it's a 14mm bolt.
  8. Sep 24, 2013 at 11:51 AM
    #748
    fenderpicks
    Fawk man, I hate the VERY 1ST OIL FILTER
    It is always on so damn tight.
    Now i need to wait for a oil removal tool from Amazon to proceed with my oil change -_-
    Happens EVERYTIME on a brand new car.
    They find a gorilla to put that b!!tch on during assembly
  9. Sep 24, 2013 at 12:48 PM
    #749
    bjboucher
    Brad
    San Antonio, Texas
    You don't have automotive stores where you live? lol
  10. Sep 24, 2013 at 5:05 PM
    #750
    fenderpicks
    I do, lol
    i will go pick one up tonight....
    73mm is the size right
  11. Nov 3, 2013 at 5:53 PM
    #751
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    I just changed my oil on my truck. Do you guys torque the bolt to spec or just hand tighten. I've done the oil change myself twice and just hand tightened but I wanted to see what others do as well. I'm sure Chris4x4 will probably advise me to torque to spec lol.
  12. Nov 3, 2013 at 5:53 PM
    #752
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    :anonymous: I torque mine
  13. Nov 3, 2013 at 6:01 PM
    #753
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Many "old school" folks tend to the "finger tight + 3/4 turn with a wrench" rule, but I do recommend using a torque wrench. Too little torque, and the plug can fall out, and too much can lead to stripped threads.
  14. Nov 3, 2013 at 6:05 PM
    #754
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    Good idea as always! Thank you Chris4x4. I tend to overtighten so I'm sure torquing would be a good rule of thumb.
  15. Nov 3, 2013 at 6:09 PM
    #755
    K Williams
    K Williams Well-Known Member
    Long Island, NY
    2011 TRD Off Road V6 MT
    Banks Monster Exhaust URD Stage II Clutch
    Torque to Toyota specs.
  16. Nov 8, 2013 at 6:53 AM
    #756
    CBiscuit14
    CBiscuit14 Professional Lurker
    South Dakota
    08 DC TRD Sport 4X4
    I was changing my oil last night for the first time since buying my truck. I noticed that when I removed the old oil filter, virtually no oil drained out. I'm guessing that could be because the way the filter is positioned....since the truck had been sitting for a few hours, maybe the oil drained out? Which leads me to believe that the POS filter that the non-Toyota dealer put on for the last change may not have had an anti-drainback valve. Do you think this is the case or is there some concern not having any oil draining from the filter?
    I used a Toyota OEM filter for my change after reading some reviews on here.
  17. Nov 8, 2013 at 7:05 AM
    #757
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I use Toyo OE filters and when I remove mine, even after a couple hours waiting for it to cool off some, I get a small pool of oil in the catch around the filter.
  18. Nov 8, 2013 at 2:56 PM
    #758
    ImpulseRed008
    Susan
    SC
    I use toyota filters and usually only get a few ounces out of the filter.
  19. Dec 16, 2013 at 5:28 PM
    #759
    quantum
    quantum Well-Known Member
    FYI, I used to exclusively use Mobil 1, but since i switched to Penzoil Platinum, I have had zero metal shavings on the magnetic drain plug. Engine seems to run quieter as well. YMMV
  20. Dec 31, 2013 at 6:06 PM
    #760
    TR90125
    TR90125 Well-Known Member
    North Texas
    2013 DCSB TRD Sport
    Bone stock for now....
    Just wanted to thank the OP for posting this up. Although an oil change isn't rocket science, I'm no mechanic....Lol
    My 13 is still under the free maintenance plan, but I hate wasting my time getting to the dealership and enjoy doing my own work. Also switched up to Mobil 1.
