4.0L 1GR 2nd Gen Oil Change Guide
Discussion in 'Technical Chat' started by chris4x4, Jul 8, 2008.
  1. Feb 21, 2015 at 10:21 AM
    #841
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Factory skid plate? No. Aftermarket? Depends, but probably.
  2. Feb 21, 2015 at 1:16 PM
    #842
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    A lot of aftermarket ones have holes so you don't have to remove it.
  3. Feb 22, 2015 at 12:29 PM
    #843
    Sandman614
    Tim
    '06 SR5 Off Road
    Sounds like the hole is a little tight.. :anonymous:
    Yea the drain/barb on my filter catch fills with mud.
  4. Mar 8, 2015 at 10:18 AM
    #844
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Great thread.
    Changed my 09 TRD Sport for the first time.
    Easy peasy. I just cut a plastic water bottle in half and used as the oil filter drip pan.
    Went with Mobil 1 and OEM filter. Great idea using the oil container as a funnel. Works great!
    Cost me $46 for oil and filter and another $25 in a new catch pan and oil filter wrench.
    Only spillage was when I accudently knocked over the jug of old oil. Doh!
  5. Mar 8, 2015 at 3:43 PM
    #845
    amati5
    amati5 Well-Known Member
    2010 Prerunner TRD
    There is a $12 rebate for any 5 qrtz Mobil1 now, expired Mar 15. You can do it online with a pic of the receipt.
  6. Apr 18, 2015 at 11:31 AM
    #846
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Thanks for the help guys. Great thread. Just did my first oil change in my taco (after Toyota care was over). I'm no stranger to doing my own maintenance. Did all my own service on my last truck (F-150) and when I saw the filter placement on our truck I thought to myself, "what idiot would put a filter at the top of the engine? That's going to make a huge mess when I pull it!" Thanks to this thread, was done and all cleaned up in less than 15 min. Thanks Chris!
    Free bump!
  7. Apr 23, 2015 at 10:31 PM
    #847
    Lifeofbrian
    Lifeofbrian Longing for the far East
    Brian
    Westminster, CO
    2010 TUNDRA 5.7 Rock Warrior
    Stuff
    new tacoma owner here, thanks for this information. im going to do the first change this sat.
    lots of experience with chevy but not with toyota so this helped a ton.
  8. Jun 5, 2015 at 2:19 PM
    #848
    Jtac15
    Jtac15 Well-Known Member
    Long island
    2022 Trd OR
    Never had a tac so the upside down filter is new to me. Where can i get the tubing to drain the oil from? Looks like itll save some mess.
  9. Jun 5, 2015 at 2:21 PM
    #849
    tacosupreme17
    tacosupreme17 Well-Known Member
    Brad
    ON, Canada
    06 TRD 4x4
    Oem head unit mod
    I just use a plastic water bottle it works pretty well
  10. Jun 5, 2015 at 2:22 PM
    #850
    Jtac15
    Long island
    2022 Trd OR
    Just holding underneath? Then replace plug?
    K Williams likes this.
  11. Jun 5, 2015 at 2:23 PM
    #851
    CBiscuit14
    CBiscuit14 Professional Lurker
    South Dakota
    08 DC TRD Sport 4X4
    A local hardware store should have tubing. The last time I just placed an empty bottle under the filter drain. It was actually a little easier and cleaner than using the tubing.
  12. Jun 5, 2015 at 2:24 PM
    #852
    tacosupreme17
    Brad
    ON, Canada
    06 TRD 4x4
    Oem head unit mod
    you can usually wedge it in there so it will stay in place and collect the oil. let it drain out then give it a quick wipe to get rid of the last bit of oil and your good to go.
  13. Jun 5, 2015 at 2:25 PM
    #853
    Jtac15
    Long island
    2022 Trd OR
    Thanks . Doin first oil change on truck this weekend. This should make things neater and cleaner.
  14. Jun 5, 2015 at 2:26 PM
    #854
    tacosupreme17
    Brad
    ON, Canada
    06 TRD 4x4
    Oem head unit mod
    Anytime. Best of luck its super easy.
  15. Jun 10, 2015 at 9:43 AM
    #855
    KSJ08
    KSJ08 Well-Known Member
    2015 White Access TRD Sport
    My 2008 FJ had filter like the 2015 Tacoma Great, The 2012 FJ had a plastic filter bowl under fwd faxtory skid panel, that you use a 3/8 drive to remove plug, screw in a plastic drain tool that came W/new filter, then you unsrew plastic bowl & replace paper element. what a PITA !! WTF were the toyo engineers thinking. I was SO happy when I popped the hood before I bought the Tacoma to see the filter back on top!! The 2012 FJ came facotry 0-20 full synthetic. I drive 100+ mi to work & home daily so I stuck to the 10,000mi change. I haven't looked to see if the Tacoma has dino or synthetic in it. Filler cap says 5-20. I use 1 one the empty new oil qt bottles to catch any oil from filter scupper at least I did on 08 FJ worked great.
  16. Jul 1, 2015 at 10:18 AM
    #856
    imjustabill1970
    imjustabill1970 Twitter: imjustabill1970
    bill
    clarksville, tn
    2017 TRD Off Road DCSB
    SUSPENSION: Icon Stage 4 with tubular UCAs WHEELS: Black ProComp 69 TIRES: BFG KO2s at 265/75/16 Partially debadged Diaz Fabrication Model T up front
    Great post. Maybe I missed it in the 40+ pages of the thread...how do you reset the dash notification?
    Thanks.
  17. Jul 1, 2015 at 10:28 AM
    #857
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    1. Turn the ignition key to the "OFF" position with the odometer reading shown (For details, see "Odometer and two trip meters" on page 143 in this Section.) (Note 2: 2011 + models require using the TRIP A reading)
    2. Turn the ignition key to the "ON" position while holding down the trip meter knob.
    Hold the knob for at least 5 seconds. The odometer indicates "000000" and the light goes off.
  18. Jul 13, 2015 at 7:07 AM
    #858
    imjustabill1970
    bill
    clarksville, tn
    Where can I find the "5/16" ID 5ft long tube", is that available from an auto parts store?
    Later.
  19. Jul 13, 2015 at 2:19 PM
    #859
    imjustabill1970
    bill
    clarksville, tn
    Okay, never done an oil change before on my own, so forgive the ignorance please and thank you. My 2014 doesn't seem to have the plug at the bottom of my filter. Any idea why?
    Thanks.
  20. Jul 13, 2015 at 2:23 PM
    #860
    imjustabill1970
    bill
    clarksville, tn
    Oh, so once I remove the oil filter, the oil in that area will just drain on it's own?
    Later.
