4.0L 1GR 2nd Gen Oil Change Guide
Discussion in 'Technical Chat' started by chris4x4, Jul 8, 2008.
  1. Sep 27, 2017 at 3:52 PM
    #981
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    :thumbsup:
  2. Oct 22, 2017 at 12:17 PM
    #982
    Naumoff42
    Naumoff42 Well-Known Member
    Ohio
    2015 TRD Offroad
    I change mine after letting it sit over night. By then all the oil in the filter has drained back into the pan and there is no mess when you remove it. No cup needed. :thumbsup:
  3. Oct 22, 2017 at 2:04 PM
    #983
    wanna taco
    wanna taco What's my name?
    alan
    SF Bay Area
    '15 DCSB TRD Sport 4x2 Barcelona Red!
    TRD Sport with a whole Shitload of TwoBitDiddlySquat Running Boards/Roof Rack/Bed Mat; Tint all around; W/Tech Liners; Extant Hard Trifold; P&L; Relentless tailgate mod; Amp Bed Step; TracOne; Rear headrest Delete; rear window lock rod; tailgate EZ hose clamp; Kahtec 3rd lite flasher; Muth Signal Mirrors; 894 (38W) Fog Reverse Bulbs; Seat belt extenders; Seat belt chime silenced; Fumoto Kwik Valve; RideRites/Daystars; Eyebolts; SS D Rings; Viair 70P; Lund hitch Bed Extender; Custom Windshield Rock Chips; ...
    Not bad... Driveway is on a slant, so ramps under the front level the truck, and don't want to leave the truck on ramps overnight. With a soda bottle under the drain hole, I crack the filter just loose enough to let in air. By the time the crankcase is drained, so is the filter.
  4. Nov 18, 2017 at 2:21 PM
    #984
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    Good stuff OP this was so simple. Finally replaced with Mobil 1 and a fumoto valve to make it easy with skids. Apparently my oil filter drain rubber plug was missing from the last time the stealership did my change under warranty. Never going back to them as they suck. Now to find a stupid little plug somewhere to replace.
  5. Nov 19, 2017 at 6:44 AM
    #985
    vram74
    vram74 Well-Known Member
    05 Prerunner SR5
    My dealership keeps leaving that plug off as well. Replaced I don’t know how many times. Guess I’m going to have to take it off before the change.
    ready6delta[QUOTED] likes this.
  6. Nov 26, 2017 at 11:39 AM
    #986
    JPaules
    JPaules Member
    Jacob
    06 White Tacoma Prerunner
    I just filled up with 6 quarts and it still doesn't seem like it's full enough
  7. Nov 26, 2017 at 11:45 AM
    #987
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Did you run the engine??
    5.5 quarts in mine
    ready6delta likes this.
  8. Nov 26, 2017 at 11:52 AM
    #988
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Why do you say that?
  9. Nov 26, 2017 at 1:05 PM
    #989
    JPaules
    JPaules Member
    Jacob
    I filled it with 5 quarts. Ran it for a bit then checked it. Filled it with half of the 6th checked it. Then poured in the rest of the bottle. Still wasn't on the dipstick
  10. Nov 26, 2017 at 1:10 PM
    #990
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    The dipstick is notoriously hard to read with fresh clean oil on it. More than one person has thought there wasn't anything on it when in fact they were already overfilled. Sanding the dipstick makes it easier to read.
    JGO, Crom, SonnyBones and 3 others like this.
  11. Dec 7, 2017 at 8:49 AM
    #991
    Scrapla
    Scrapla Rebel Without a Clue
    South Florida
    2007 Tacoma PreRunner 4.0 V6
    1.5" lift, ARB bumper
    The easiest way to read the dip stick is to let to remove it and let it sit outside of the tube for about 10-15min. I change my oil, run the engine a bit, check the stick then rest it on top of the engine cover and sit back for a few to allow the oil in the tube to drain back down. It works like a charm every time. I also always use 5 quarts and its spot on, maybe because I don't drain enough to get that other .5 quart out or the fact I'm on a slight incline in my driveway.
  12. Dec 7, 2017 at 8:50 AM
    #992
    Scrapla
    South Florida
    When you go to the dealer and just ask for 5w-30 is that oil conventional or synthetic? I don't recall seeing it on the label.
  13. Dec 7, 2017 at 8:59 AM
    #993
    ready6delta
    JACOB
    Dealer probably uses conventional unless you ask for synthetic. I believe conventional is what it calls for on second gens.
  14. Dec 7, 2017 at 9:00 AM
    #994
    Scrapla
    South Florida
    I recently just started buying the big jug of 5w-30 conventional Valvoline or whatever is on sale from AutoZone instead of the individual quarts from the dealer. Thanks for the reply.
    1Shifter likes this.
  15. Dec 7, 2017 at 9:43 AM
    #995
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    It's cheaper at walmart Normally
    ready6delta and 303tacoma like this.
  16. Dec 7, 2017 at 12:03 PM
    #996
    Link6
    Link6 Well-Known Member
    Lansdale, PA
    2015 Black DCSB SpoRt! 6-spd
  17. Dec 7, 2017 at 12:34 PM
    #997
    Scrapla
    South Florida
    Anyone else run conventional and change every 3k or "Maint Req" light?
  18. Dec 8, 2017 at 6:28 AM
    #998
    ready6delta
    JACOB
    this is what I do as well, then just snag a 1 qt here and there on sale.
    I was changing every 5000 with conventional at dealer which was recommended and when my light came on in my 2014 but I hate the stealer ship and its much easier and less hassle at home with synthetic. currently only dribing 12-15000 miles per year so I only have to change oil 2 x maybe 3.
  19. Dec 8, 2017 at 7:17 AM
    #999
    Sandman614
    Tim
    '06 SR5 Off Road
    :notsure: $2 difference, I'll just grab a jug while I'm in walmart
    https://www.walmart.com/ip/Mobil-1-5W-30-High-Mileage-Full-Synthetic-Motor-Oil-5-qt/17018131
  20. Dec 11, 2017 at 6:50 AM
    #1000
    Naumoff42
    Ohio
    2015 TRD Offroad
    This last oil change I put in 5.5 quarts and I was a hair over the full line on the dipstick. Next time I'm going to try just putting 5 quarts in and seeing how it looks. Sure would be easier to just use full bottles as well.
