4.0L 1GR 2nd Gen Oil Change Guide
Discussion in 'Technical Chat' started by chris4x4, Jul 8, 2008.
  1. Dec 11, 2017 at 6:58 AM
    #1001
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I used to use just the 5.1 gallon jugs, but then a buddy came by and didn't like the tick so he poured a half bottle in and it quieted it down a good bit. I'd say stick to using 5.5qts. A little over the hard to read dip stick isn't going to hurt.
  2. Feb 26, 2018 at 12:42 PM
    #1002
    Tacoma4Ewa
    Tacoma4Ewa Active Member
    2004 Toyota Tacoma Pre-runner Double Cab
    None
    Wow, I never thought about that for the oil filter, I always just drain all the oil from the pan first, and then remove my oil filter, and wipe off the excess oil, this is a great idea! Thanks!
  3. Mar 3, 2018 at 6:24 AM
    #1003
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Mobil 1 has the $12 rebate again on a 5 qt jug. It’s on sale at Walmart for $25 so after rebate, a 5 qt jug is only ~$13 depending on tax. Match this up with a $4 oem oil filter and you got a cheap oil change with SYNTHETIC oil!!!
  4. Mar 3, 2018 at 10:54 AM
    #1004
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    Calling all help, and input to those who have experience directly or seen this....
    I noticed this this sludge a little while ago in the oil neck underneath the cap, but it wasn't nearly this bad....
    I didn't think too much of it because when I checked it I knew I use the truck to commute which is an 8 minute drive time, 15-20 minutes total per day. I know that moisture gets into the plastic oil neck and if the engine doesn't get to operating temp it won't allow burn off/evaporation.
    However when checking it today-- bear in mind I drove for the better part of an hour and the truck was fully warmed up, I popped the cap off after getting home and saw this (pictured below)....
    Is this due to the VERY SHORT commutes, and am I able to unscrew the neck, take it off and clean the sludge out and then watch it from here on out or should I be more concerned with any water/coolant in the engine mixing with the oil?
    The dipstick does NOT have any sludge on it FWIW
    I've been noticing it's a bit sluggish to start up when cold FYI
    Also the truck is ~500 miles away from hitting 60k
  5. Mar 3, 2018 at 1:14 PM
    #1005
    yote
    Mark
    Tacoma, WA
    Solid input, thank you.
    I took the neck off and cleaned it already- it went quicker than expected so that was nice.
    Yeah I’ve got an motor oil, diff fluids/oil change, tire rotation and spark plug change at the 60k mark
    DoorDing likes this.
  6. Mar 3, 2018 at 2:22 PM
    #1006
    yote
    Mark
    Tacoma, WA
    Yeah might as well do it while you've got it all apart
  7. Mar 3, 2018 at 2:23 PM
    #1007
    yote
    Mark
    Tacoma, WA
    Update on the oil gunk.
    Took the plastic oil neck off:
    Luckily there's absolutely no sign of gunk within the engine
  8. Mar 3, 2018 at 2:44 PM
    #1008
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Weird sceince there.
  9. Mar 3, 2018 at 4:14 PM
    #1009
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    I dont under stand why used a oil filler neck.....
  10. Mar 3, 2018 at 4:21 PM
    #1010
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Take it for a LONG drive once a week or so. Long enough to get HOT and it will get rid of the goo. Happens with short trips mainly in the winter where the motor doesn't get hot enough to get rid of that.
  11. Mar 3, 2018 at 5:35 PM
    #1011
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    I always use a funnel... that filler neck just slows me down during the oil change.... me being OCD... TIme time timE
  12. Mar 3, 2018 at 5:45 PM
    #1012
    yote
    Mark
    Tacoma, WA
    I drove it continuously for about an hour today... maybe I need to get it up to highway speeds though
  13. Mar 10, 2018 at 8:36 AM
    #1013
    TacoToyota
    TacoToyota Member
    2001 Toyota Tacoma Prerunner
    Led Tail Lites ,custom wheels
    I drive 2001 Tacoma 3.4 v6 with 192,000 miles , what type of oil should I use that would be best for high mileage engine?
  14. Mar 25, 2018 at 6:11 PM
    #1014
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    I picked up a jug of Valvoline HM Synthetic at the Wally World for 22 bucks.
  15. May 5, 2018 at 5:54 AM
    #1015
    RedRed
    RedRed TACO TUESDAY!!!
    Red
    Lake Norman NC
    15 taco with stuff & things
    1.75" Billy's plus 1/4 spacer on both sides. 1" block in rear. 265/70/17 nitto g2 SCS matte dark bronze 6s
    :thumbsup:
    1Shifter likes this.
  16. May 6, 2018 at 10:22 AM
    #1016
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    Tired of the incompetence of the stealerships I’m going to start to do my own maintenance, thanks to this forum I have all the info needed. Thank you guys for all the tutorials. Now going back to the oil change. My plug has a big chunk of silicone. Anybody knows what’s that about??
    Also 5w-30w or 10w-30w?
    Also, what do I need to do to change to synthetic oil.D4A5F9AF-DB99-452D-9E6F-E302133C067F.jpg
    ChadsPride likes this.
  17. May 6, 2018 at 10:30 AM
    #1017
    verynearlypure
    verynearlypure Clean & Decent
    Ernest
    The Buckeye State
    2015 BRM DCSB TRD OR
    Ray 10’s & Basic Bastard Goodies
    Seems a little shady if you ask me.
  18. May 6, 2018 at 10:35 AM
    #1018
    El Tano
    Pasadena. CA
    10 Tacoma TRD sport
    A little bit overwhelmed here...
  19. May 6, 2018 at 10:59 AM
    #1019
    Naumoff42
    Naumoff42 Well-Known Member
    Ohio
    2015 TRD Offroad
    5W-30. FULL synthetic, don't buy blends because you have no idea what the dino to synthetic ratio is. Doesn't really matter what brand. I use Amsoil but you won't find that in your basic Auto parts store. Royal purple is really good as well. Also buy a good quality oil filter. There is a book on the wall that you look up your model of vehicle and it will list out part numbers for the correct sized filter.
    fökai671 likes this.
  20. May 6, 2018 at 11:06 AM
    #1020
    1Shifter
    Jeff
    09 PreRunner
    Any synthetic 5w30 will do the trick. Pick any name brand oil, Penn's, M1, Castroil or whichever and change it according to the book. I buy whatever is on sale a the WM and always use a OEM filter changed every 5k. I'd like to think my truck has a soul but I doubt it can tell the difference between oil. Also ya may want to look into getting a Fumoto valve to replace your drain plug
    ImpulseRed008 and RedRed like this.
