4.0L 1GR 2nd Gen Oil Change Guide
Discussion in 'Technical Chat' started by chris4x4, Jul 8, 2008.
  1. Apr 20, 2009 at 9:07 AM
    #101
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yeah, I have heard this many times. Not sure what kind of Gorilla they employ to install the oil filters, but it does seem they are WAY over tightened from the factory.
  2. Apr 20, 2009 at 1:42 PM
    #102
    jonny
    jonny Betty White Edition Heep ZJ
    i was pissed the first time removing my oil filter.....it was on there sooo tight :mad:
  3. Apr 20, 2009 at 1:56 PM
    #103
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    This wrench will remove ANY oil filter in ANY location on ANY vehicle no matter how tight. I have thrown away all my filter removal gadgets in favor this ONE TOOL and it has worked on my last 12 vehicles. It can be used from the side OR top of the filter. A MUST HAVE TOOL.
  4. Apr 20, 2009 at 2:01 PM
    #104
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i gotta agree.....a good filter wrench is a must have!!
  5. Apr 20, 2009 at 3:18 PM
    #105
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I prefer these:
  6. Apr 20, 2009 at 3:23 PM
    #106
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Requires multiple sizes depending on the filter as well as a socket wrench and extension, thus too many tools. VERY prone to stripping and slipping. Inefficient in comparison. Been there, done that with these. Until you graduate to the filter wrench, you won't experience real filter sex.
  7. Apr 22, 2009 at 7:40 PM
    #107
    river rat
    river rat Tool Geek
    Midwest
    '11 Timberland Mica regular cab.
    Both for me, thanks. I'll try once with the big over-filter socket. If a no-go I have a Vice-Grip plier like that. Clamp, rip, swear, re-clamp, rip and spin.
    Then I use the big socket to put the new one on because it's easier to count up the 1/4 turns without my hand up in there.
  8. Apr 22, 2009 at 7:43 PM
    #108
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have used every kind of filter wrench out there. I have had the best luck with the ones I have pictured. You DO need to use the right size for the filter, or you can strip it. As for "Too many tools", Your already gonna have a socket wrench out, so you should have a small extension handy.
  9. Apr 23, 2009 at 6:17 AM
    #109
    Joe B
    Joe B Well-Known Member
    If accessible by hand,I install and take off the oil filter by hand with a piece of sandpaper.:)
  10. Apr 23, 2009 at 6:18 AM
    #110
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have done that in the past. Good way to be sure you dont over tighten the filter. :)
  11. Apr 30, 2009 at 9:51 PM
    #111
    russell
    russell Member
    Bardstown Kentucky
    Tacoma 2-w drive
    none
    I used mobil one untill the temp droped below 0 and I experienced slight binging
    in the engine for about 2 minutes on start up, I switched to castrol
  12. Apr 30, 2009 at 9:55 PM
    #112
    leo08pirate
    leo08pirate Katzo production
    Leo
    Oceanside CA
    08 PreRunner 4.0L
    TRD exaust - Tinted Windows - TRD Intake - Alpine type S speakers
    do you guys think its better for toyota to do all this because they check everything or is it a waste of money
    send me a email with the answer please
    i think im just wasting my money
  13. Apr 30, 2009 at 10:06 PM
    #113
    russell
    russell Member
    Bardstown Kentucky
    Tacoma 2-w drive
    none
    Well thats a personal decision you'll have to make, I change my own at the house, I pour the dirty oil back in the original container and recycle
    to Walmart, I pick up my oil on a routine basis and the whole process
    of changing takes less the 30 minutes at about 30 dollars,
    it's convenient and takes less time than going to the dealer,
    I believe that there isn't a free lunch except the sweat of your own brow,
    so I do a lot of things and besides I'm a tight wad, a friend told me
    I was tighter tahn the bark on a hickory tree.
  14. May 1, 2009 at 5:14 AM
    #114
    river rat
    river rat Tool Geek
    Midwest
    I do it because I want it done right. It ain't rocket science, but it's still a critical little operation.
    It's good to have the dealer check things periodically, but few mechanics fill the filter with oil before installing it. No time and no oil to do it, because the oil comes from a central hose system with a pre-set volume as set or requested by the mechanic.
    They don't keep quarts of various oil weights on the toolbox even if they had time to fill the filter. (ask me how I know)
    ...So you get a really dry, valve rattling start every 5000 miles. (Or rather the mechanic does as they pull it out of the service bay)
  15. May 1, 2009 at 5:24 AM
    #115
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Ditto. If you've ever had a teenager forget to put the oil filler cap back on or tighten the oil pan bolt or spill oil all over your engine....you'll do it yourself. Remember, the dealer's don't put their best mechanics on the oil change crew.
  16. May 1, 2009 at 4:25 PM
    #116
    river rat
    river rat Tool Geek
    Midwest
    True. I was doing most of the OCs at a dealer because I was the noob. They didn't want to pay the big bucks guys for doing any more of that than they had to. Makes sense.
    Still, I had only like 12 minutes to get it done. Not a problem if I didn't have to requisition filters and oil on the computer and fill out paperwork, too, all in that time. Sheesh.
  17. May 1, 2009 at 4:35 PM
    #117
    Landon
    Landon Active Member
    Brandon, Mississippi
    07 prerunner blacked out
    Black Bull bar, Tinted windows
    i thought it was 5.2 qaurtz you put in
  18. May 4, 2009 at 11:32 AM
    #118
    Pyro-Rob
    Pyro-Rob Active Member
    North of Denver, CO
    09 DC TRD Sport Mag Gray Metallic
    Ideal Turn-Key Clamp (to secure tailgate), On Anytime Fogs, DTRL, Hood Scoop Running Lights, more in the works
    Ditto on doing it yourself to make sure it's done right. That way I know what oil was put in, I know that all the zerks I know about got greased, etc.
    I might take it to a dealer once in a while to get it a once-over so that if there is something I might have missed, it gets checked.
    Besides, with driving 135 miles/day for work, I can't afford to have a dealer change it once a month or once every two months.
    --->Rob
  19. May 5, 2009 at 5:23 AM
    #119
    MotoTacoma
    MotoTacoma Adrenaline Addict
    Pencilveineeya
    14 Tundra TRD OR, 05 GX470
    tacoma sold 11/13/13 GX470 has 2” Dobinsons IMS w/JBA UCA, Baja Designs S1 ditch lights, more to come!
    i'll be doing my first oil change this weekend, nice to know to pick up the hose before i got started.. good work! thanks
  20. May 12, 2009 at 8:53 PM
    #120
    Pyro-Rob
    North of Denver, CO
    Did my first oil change today. The 2nd Gen is so much easier to change than the 1st Gen. The filter is where you can get to it, remove it without draining into your arm pit, and you don't have to remove the bottom shroud to get to the oil plug.
    I'm glad Toyota saw the shortcomings of the older design and cleaned it up!
    Also, I noticed the filter I took off was a 90915-20004. I had a bunch of 90915-YZZD3's left over from my 2004 1st Gen. I would like to try to find a larger capacity filter/higher filtering capacity filter, than the stock one, since I drive 135 miles/day.
    Anyone see a problem with the YZZD3? Any other filters?
    Anyone see a problem using Mobile 1 15W-50 during the hot CO summers?
    Thanks,
    --->Rob
