4.0L, Cheapest place to order OEM Headgasket Kit?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yo'ta, Jul 5, 2018.
  1. Jul 5, 2018 at 7:38 AM
    Yo'ta
    Yo'ta [OP] Well-Known Member
    '05 Taco 4.0 needs head gasket.
    Dealer wants $473 for the "improved" headgasket kit (not including head bolts), seems a little steep... O'Reilly wants $236 (not OEM, obviously)
    Anyone got an idea where to order a genuine Toyota OEM gasket kit for a better price than $473?
    JL
  2. Jul 5, 2018 at 7:40 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Did O'riellys offer replacement head bolts? If not, put them on the list.
    As the OEM are torque to yield, and stretch quite a bit, during the torque sequence process. They should be replaced.
    loginfailed likes this.
  3. Jul 5, 2018 at 7:53 AM
    RicanTacoma
    RicanTacoma Well-Known Member
    Andres
    Fountain, Colorado
    2014 DCSB OR
  4. Jul 5, 2018 at 8:04 AM
    Yo'ta
    @Torspd, thanks for the quick reply. Yes, head bolts are on the list, not worried about getting them from O'Reilly's, etc. [BTW- Dealer wanted $16/per bolt for 16 bolts= $256, O'Reilly's and other parts stores are around $8-9/bolt]
    Was just looking for best price on a factory/OEM head gasket kit since the dealer wants $473.00
    Good news!- Toyotapartsstore.com has factory/OEM headgasket kits for $213.
    Has anyone dealt with Toyota Parts Store before? Are they legit?
    JL
    BassAckwards and Torspd like this.
  5. Jul 5, 2018 at 8:13 AM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    BassAckwards likes this.
  6. Jul 5, 2018 at 8:15 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    ^^^ this is exactly what id do. Send him a message and he will get back with you. Hes the parts manager out at camelback toyota in AZ
  7. Jul 5, 2018 at 9:39 AM
    Yo'ta
    @Wheeliet and @rjbiii - I sent a PM to Gunny and thank you both for the referral!
